* | libcpu/sparc/.../access_le.c: Add include file to fix warning | Joel Sherrill | 2013-09-23 | 1 | -0/+1 |
* | bsps: Fix cache manager support | Sebastian Huber | 2013-09-10 | 2 | -0/+9 |
* | RTEMS: Delete ChangeLog files. | Gedare Bloom | 2013-03-08 | 1 | -276/+0 |
| | | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain. | ||||
* | Require automake-1.12.2. | Ralf Corsépius | 2012-07-19 | 1 | -1/+1 |
* | Require autoconf-2.69. | Ralf Corsépius | 2012-07-19 | 1 | -1/+1 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 3 | -5/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 2 | -6/+0 |
* | SPARC: added libcpu lowlevel access and byteorder routines/definitions | Daniel Hellstrom | 2012-03-21 | 6 | -0/+244 |
| | | | | | | | | | | | | The low level routines can be used in different occasions, it will be required when accessing PCI. Note the difference between byteorder.h (inlined functions) and access.S where the functions will be declared in the library archive librtemscpu.a. Function names starting with _ are in library and can be referenced by function pointers. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> | ||||
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -8/+0 |
* | 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-11 | 2 | -1/+6 |
| | | | | | * cache/cache.c: Use "__asm__" instead of "asm" for improved c99-compliance. | ||||
* | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-02 | 2 | -2/+6 |
| | | | | * configure.ac: Require autoconf-2.68, automake-1.11.1. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 2 | -27/+27 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-28 | 1 | -1/+1 |
* | 2008-09-30 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-30 | 2 | -1/+5 |
| | | | | * preinstall.am: Regenerated. | ||||
* | 2008-09-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-26 | 2 | -1/+5 |
| | | | | * Makefile.am: Remove superfluous $(top_srcdir). | ||||
* | Cleanup. | Ralf Corsepius | 2008-07-14 | 1 | -6/+0 |
* | 2007-07-31 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-07-31 | 2 | -1/+8 |
| | | | | | | | PR 1249/build * configure.ac: Jerry Needell <jerry.needell@unh.edu> reported that the leon3 was left out of the cache enable logic. Thus the cache management support code was empty on LEON3 CPUs. | ||||
* | Regenerate. | Ralf Corsepius | 2007-01-08 | 1 | -1/+1 |
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 2 | -1/+5 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 2 | -2/+6 |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | ||||
* | 2006-05-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-05-16 | 2 | -3/+5 |
| | | | | * configure.ac: Use RTEMS_AMPOLISH3. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -0/+2 |
* | Remove all-local:. | Ralf Corsepius | 2006-01-12 | 1 | -2/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -2/+2 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 1 | -4/+0 |
* | 2005-11-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-04 | 2 | -2/+4 |
| | | | | * configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP. | ||||
* | New. | Ralf Corsepius | 2005-05-11 | 1 | -0/+22 |
* | 2005-05-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-11 | 2 | -0/+10 |
| | | | | | | * preinstall.am: New. * Makefile.am: Include preinstall.am. * configure.ac: Reflect changes above. | ||||
* | Include preinstall.am. | Ralf Corsepius | 2005-05-11 | 1 | -14/+4 |
* | Remove. | Ralf Corsepius | 2005-05-11 | 1 | -1/+0 |
* | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-07 | 2 | -3/+7 |
| | | | | * Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | ||||
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 2 | -37/+10 |
| | | | | * Makefile.am: Remove build-variant support. | ||||
* | 2004-10-19 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-10-19 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_ENABLE_BARE. | ||||
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 2 | -1/+5 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-01 | 3 | -2/+7 |
| | | | | | * reg_win/window.S: Include <rtems/asm.h> instead of <asm.h>. * syscall/syscall.S: Include <rtems/asm.h> instead of <asm.h>. | ||||
* | 2004-03-26 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-26 | 2 | -1/+5 |
| | | | | * configure.ac: Add 2nd argument (rtems_updir) to RTEMS_TOP. | ||||
* | Remove refs to Makefile*. | Ralf Corsepius | 2004-03-09 | 1 | -2/+0 |
* | Unused. | Ralf Corsepius | 2004-03-08 | 2 | -4/+0 |
* | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-06 | 2 | -1/+4 |
| | | | | * Makefile.am: Don't include .../lib.am. | ||||
* | 2004-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-18 | 6 | -116/+89 |
| | | | | | | | | | | | * syscall/Makefile.am: Remove. * reg_win/Makefile.am: Remove. * cache/Makefile.am: Remove. * Makefile.am: Merge-in Makefile.ams above. Use automake compilation rules. * configure.ac: Reflect changes above. Add subdir-objects to AUTOMAKE_OPTIONS. Require automake >= 1.8.2. | ||||
* | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-14 | 2 | -0/+8 |
| | | | | | * cache/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. | ||||
* | 2003-12-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-16 | 2 | -12/+16 |
| | | | | * cache/Makefile.am: Eliminate VPATH. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -2/+5 |
| | | | | * cache/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -2/+6 |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-02 | 4 | -3/+9 |
| | | | | | | * cache/Makefile.am: Remove all-local: $(ARCH). * reg_win/Makefile.am: Remove all-local: $(ARCH). * syscall/Makefile.am: Remove all-local: $(ARCH). | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 1 | -3/+3 |
| | | | | * ChangeLog: Fix bogus entries. | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 1 | -10/+11 |
| | | | | | | * cache/Makefile.am: Reformat. Use dirstamps for preinstallation. * reg_win/Makefile.am: Reformat. * syscall/Makefile.am: Reformat. | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 3 | -2/+6 |
| | | | | | | * sparc/cache/Makefile.am: Reformat. Use dirstamps for preinstallation. * sparc/reg_win/Makefile.am: Reformat. * sparc/syscall/Makefile.am: Reformat. | ||||
* | 2003-10-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-22 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_CANONICAL_HOST. |
