path: root/c/src/lib/libcpu/sparc (follow)
* This set of changes is the build of what was required to convert toJoel Sherrill1997-04-012-0/+72
| | | | | | | | | | | | | | | | | | | | GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved.
* Changes to reflect new revision of erc32 per Jiri Gaisler's suggestions.Joel Sherrill1996-12-021-19/+17
| | | | This is current as of sis 2.6.
* patches to erc32.h to correct handling of timer mirror from Jiri Gaisler.Joel Sherrill1996-10-141-3/+3
* ERC32_Force_interrupt implementation replaced per Jiri Gaisler's experienceJoel Sherrill1996-08-081-0/+5
| | | | on the real erc32 hardware.
* typos fixedJoel Sherrill1995-10-312-0/+272
* SPARC port passes all testsJoel Sherrill1995-10-301-0/+503
