cache/Makefile.am: Reflect having moved automake.
reg_win/Makefile.am: Reflect having moved automake.
syscall/Makefile.am: Reflect having moved automake.
* include/erc32.h: Remove (Unused).
* include/.cvsignore: Remove (Obsolete).
* cache/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Eliminate *_O_FILES.
* reg_win/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* syscall/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* configure.ac: Add RTEMS_PROG_CCAS.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* cache/Makefile.am: Use .$(OBJEXT) instead of .o.
* reg_win/Makefile.am: Use .$(OBJEXT) instead of .o.
* syscall/Makefile.am: Use .$(OBJEXT) instead of .o.
* tbr/Makefile.am: Remove.
* tbr/.cvsignore: Remove.
* tbr/tbr.c: Remove.
* tbr/tbr.h: Remove.
* configure.ac: Remove tbr subdir.
* Makefile.am: Remove tbr subdir.
* tbr/Makefile.am: New file.
* tbr/.cvsignore: New file.
* tbr/tbr.c: New file.
* tbr/tbr.h: New file.
* configure.ac: Add tbr subdir.
* Makefile.am: Add tbr subdir.
* cache/Makefile.am: Remove AUTOMAKE_OPTIONS.
* reg_win/Makefile.am: Remove AUTOMAKE_OPTIONS.
* syscall/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.in: Remove.
* cpu_asm.S: Small patch to fix a bug in the rtems sparc port. The
bug has been there all the time, but only hits the leon bsp since the
leon cpu has a 5-stage pipeline (erc32 has 4 stages).
* cache/Makefile.am: Use 'PREINSTALL_FILES ='.
* cache/Makefile.am: Use 'CLEANFILES ='.
* include/Makefile.am, syscall/Makefile.am, cache/Makefile.am:
* cache/.cvsignore: Add cache.h.
* cache/Makefile.am: Removed automake warning by introducing a
simple variable.
* cache/cache.h: Fix reference to MC68040 and put in stubs
for missing support routines. The functionality of these
routines needs to be addressed.
* Makefile.am, configure.in: Added support for instruction
cache enabling based on CPU model.
* cache/.cvsignore, cache/Makefile.am, cache/cache.c,
cache/cache_.h: New files.
* reg_win/Makefile.am, syscall/Makefile.am: Include compile.am
are now in libcpu. This primarily required moving erc32 specific
information from score/cpu files to libcpu/sparc and the erc32 BSP.
that contains:
* Removes MKLIB
handling)
converted to automake.
which does the following:
patches
NOTES:
inside of those Makefiles.
directories.
to this at the moment.
esp. some powerpc cpu-models
them to $(PROJECT_INCLUDE)/
./bootstrap
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
dependencies of "Makefile".
--enable-maintainer-mode.
+ interrupt masking correction
+ FPU rev.B workaround
+ minor erc32 related fixes
future.
cd <rtems-source-tree>
