* | Whitespace removal. | Ralf Corsepius | 2009-11-28 | 1 | -1/+1 |
* | 2008-09-30 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-30 | 2 | -1/+5 |
| | | | | * preinstall.am: Regenerated. | ||||
* | 2008-09-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-26 | 2 | -1/+5 |
| | | | | * Makefile.am: Remove superfluous $(top_srcdir). | ||||
* | Cleanup. | Ralf Corsepius | 2008-07-14 | 1 | -6/+0 |
* | 2007-07-31 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-07-31 | 2 | -1/+8 |
| | | | | | | | PR 1249/build * configure.ac: Jerry Needell <jerry.needell@unh.edu> reported that the leon3 was left out of the cache enable logic. Thus the cache management support code was empty on LEON3 CPUs. | ||||
* | Regenerate. | Ralf Corsepius | 2007-01-08 | 1 | -1/+1 |
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 2 | -1/+5 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 2 | -2/+6 |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | ||||
* | 2006-05-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-05-16 | 2 | -3/+5 |
| | | | | * configure.ac: Use RTEMS_AMPOLISH3. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -0/+2 |
* | Remove all-local:. | Ralf Corsepius | 2006-01-12 | 1 | -2/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -2/+2 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 1 | -4/+0 |
* | 2005-11-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-04 | 2 | -2/+4 |
| | | | | * configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP. | ||||
* | New. | Ralf Corsepius | 2005-05-11 | 1 | -0/+22 |
* | 2005-05-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-11 | 2 | -0/+10 |
| | | | | | | * preinstall.am: New. * Makefile.am: Include preinstall.am. * configure.ac: Reflect changes above. | ||||
* | Include preinstall.am. | Ralf Corsepius | 2005-05-11 | 1 | -14/+4 |
* | Remove. | Ralf Corsepius | 2005-05-11 | 1 | -1/+0 |
* | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-07 | 2 | -3/+7 |
| | | | | * Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | ||||
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 2 | -37/+10 |
| | | | | * Makefile.am: Remove build-variant support. | ||||
* | 2004-10-19 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-10-19 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_ENABLE_BARE. | ||||
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 2 | -1/+5 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-01 | 3 | -2/+7 |
| | | | | | * reg_win/window.S: Include <rtems/asm.h> instead of <asm.h>. * syscall/syscall.S: Include <rtems/asm.h> instead of <asm.h>. | ||||
* | 2004-03-26 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-26 | 2 | -1/+5 |
| | | | | * configure.ac: Add 2nd argument (rtems_updir) to RTEMS_TOP. | ||||
* | Remove refs to Makefile*. | Ralf Corsepius | 2004-03-09 | 1 | -2/+0 |
* | Unused. | Ralf Corsepius | 2004-03-08 | 2 | -4/+0 |
* | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-06 | 2 | -1/+4 |
| | | | | * Makefile.am: Don't include .../lib.am. | ||||
* | 2004-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-18 | 6 | -116/+89 |
| | | | | | | | | | | | * syscall/Makefile.am: Remove. * reg_win/Makefile.am: Remove. * cache/Makefile.am: Remove. * Makefile.am: Merge-in Makefile.ams above. Use automake compilation rules. * configure.ac: Reflect changes above. Add subdir-objects to AUTOMAKE_OPTIONS. Require automake >= 1.8.2. | ||||
* | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-14 | 2 | -0/+8 |
| | | | | | * cache/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. | ||||
* | 2003-12-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-16 | 2 | -12/+16 |
| | | | | * cache/Makefile.am: Eliminate VPATH. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -2/+5 |
| | | | | * cache/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -2/+6 |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-02 | 4 | -3/+9 |
| | | | | | | * cache/Makefile.am: Remove all-local: $(ARCH). * reg_win/Makefile.am: Remove all-local: $(ARCH). * syscall/Makefile.am: Remove all-local: $(ARCH). | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 1 | -3/+3 |
| | | | | * ChangeLog: Fix bogus entries. | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 1 | -10/+11 |
| | | | | | | * cache/Makefile.am: Reformat. Use dirstamps for preinstallation. * reg_win/Makefile.am: Reformat. * syscall/Makefile.am: Reformat. | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 3 | -2/+6 |
| | | | | | | * sparc/cache/Makefile.am: Reformat. Use dirstamps for preinstallation. * sparc/reg_win/Makefile.am: Reformat. * sparc/syscall/Makefile.am: Reformat. | ||||
* | 2003-10-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-22 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_CANONICAL_HOST. | ||||
* | 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-21 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_CHECK_CPU. | ||||
* | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-18 | 2 | -1/+5 |
| | | | | * Makefile.am: Reflect having moved aclocal/. | ||||
* | Fix broken ChangeLog entries. | Ralf Corsepius | 2003-08-18 | 1 | -4/+4 |
* | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-16 | 5 | -11/+18 |
| | | | | | | | Makefile.am: Reflect having moved automake. cache/Makefile.am: Reflect having moved automake. reg_win/Makefile.am: Reflect having moved automake. syscall/Makefile.am: Reflect having moved automake. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 2 | -1/+5 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 2 | -1/+4 |
* | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-02-11 | 2 | -1/+5 |
| | | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | ||||
| | | | | * configure.ac: AC_PREREQ(2.57). | ||||
* | 2003-01-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-20 | 6 | -545/+9 |
| | | | | | | | | * include/erc32.h: Remove (Unused). * include/Makefile.am: Remove. * include/.cvsignore: Remove (Obsolete). * Makefile.am: Reflect changes above. * configure.ac: Reflect changes above. | ||||
* | 2002-12-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-15 | 2 | -2/+0 |
| | | | | | | | * cache/Makefile.am: Don't include @RTEMS_BSP@.cfg. Eliminate *_O_FILES. * reg_win/Makefile.am: Don't include @RTEMS_BSP@.cfg. * syscall/Makefile.am: Don't include @RTEMS_BSP@.cfg. | ||||
* | 2002-12-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-15 | 2 | -4/+8 |
* | 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-06 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_CHECK_BSP_CACHE. |
