* configure.ac: Use RTEMS_AMPOLISH3.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* preinstall.am: New.
* Makefile.am: Include preinstall.am.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Remove build-variant support.
* configure.ac: Remove RTEMS_ENABLE_BARE.
* reg_win/window.S: Include <rtems/asm.h> instead of <asm.h>.
* syscall/syscall.S: Include <rtems/asm.h> instead of <asm.h>.
* configure.ac: Add 2nd argument (rtems_updir) to RTEMS_TOP.
* Makefile.am: Don't include .../lib.am.
* syscall/Makefile.am: Remove.
* reg_win/Makefile.am: Remove.
* cache/Makefile.am: Remove.
* Makefile.am: Merge-in Makefile.ams above. Use automake compilation
rules.
Add subdir-objects to AUTOMAKE_OPTIONS.
Require automake >= 1.8.2.
* cache/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* cache/Makefile.am: Eliminate VPATH.
* cache/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* cache/Makefile.am: Remove all-local: $(ARCH).
* reg_win/Makefile.am: Remove all-local: $(ARCH).
* syscall/Makefile.am: Remove all-local: $(ARCH).
* ChangeLog: Fix bogus entries.
* cache/Makefile.am: Reformat. Use dirstamps for preinstallation.
* reg_win/Makefile.am: Reformat.
* syscall/Makefile.am: Reformat.
* sparc/cache/Makefile.am: Reformat. Use dirstamps for preinstallation.
* sparc/reg_win/Makefile.am: Reformat.
* sparc/syscall/Makefile.am: Reformat.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac: Remove RTEMS_CHECK_CPU.
cache/Makefile.am: Reflect having moved automake.
reg_win/Makefile.am: Reflect having moved automake.
syscall/Makefile.am: Reflect having moved automake.
* include/erc32.h: Remove (Unused).
* include/.cvsignore: Remove (Obsolete).
* cache/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Eliminate *_O_FILES.
* reg_win/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* syscall/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* configure.ac: Add RTEMS_PROG_CCAS.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* cache/Makefile.am: Use .$(OBJEXT) instead of .o.
* reg_win/Makefile.am: Use .$(OBJEXT) instead of .o.
* syscall/Makefile.am: Use .$(OBJEXT) instead of .o.
* tbr/Makefile.am: Remove.
* tbr/.cvsignore: Remove.
* tbr/tbr.c: Remove.
* tbr/tbr.h: Remove.
* configure.ac: Remove tbr subdir.
* Makefile.am: Remove tbr subdir.
* tbr/Makefile.am: New file.
* tbr/.cvsignore: New file.
* tbr/tbr.c: New file.
* tbr/tbr.h: New file.
* configure.ac: Add tbr subdir.
* Makefile.am: Add tbr subdir.
* cache/Makefile.am: Remove AUTOMAKE_OPTIONS.
* reg_win/Makefile.am: Remove AUTOMAKE_OPTIONS.
* syscall/Makefile.am: Remove AUTOMAKE_OPTIONS.
