Add the trap vector to the interrupt frame. Also rename the assembly
macro that accesses the field to be consistent with similar macros.
* ChangeLog: Fix ChangeLog with name and email address
* shared/score/interrupt.S: Pass ISR correct pointer to interrupt frame
* shared/cache/cache.c:
PR 1688/libcpu
* shared/score/interrupt.S: Fix bug in the sun4u _ISR_Dispatch code
that ends up cloberring the global registers. It manifests primarily
as a memory alignment error when the globals are used to read to/from
memory.
PR 1681/cpukit
* shared/score/interrupt.S: With the percpu patch, ASM uses
INTERRUPT_STACK_HIGH instead of _CPU_Interrupt_stack_high. The
sparc64 was still using the old variable, which was declared in its
cpu.h file. This patch to comment out the declaration and switch to
using INTERRUPT_STACK_HIGH.
PR 1573/cpukit
* shared/score/interrupt.S: Add a per cpu data structure which contains
the information required by RTEMS for each CPU core. This
encapsulates information such as thread executing, heir, idle and
dispatch needed.
* .cvsignore, ChangeLog, Makefile.am, configure.ac, preinstall.am,
shared/cache/cache.c, shared/cache/cache_.h,
shared/interrupts/installisrentries.c, shared/score/cpu.c,
shared/score/interrupt.S, shared/syscall/sparc64-syscall.S,
shared/syscall/sparc64-syscall.h: New files.
