path: root/c/src/lib/libcpu/sh/sh7045/score (follow)
* Added .cvsignore files.Joel Sherrill2000-06-141-0/+2
* Patch rtems-rc-20000614-sh.tar.gz from Ralf CorsepiusJoel Sherrill2000-06-143-10/+30
| | | | | | | | | | | | | | | | | | | | | <corsepiu@faw.uni-ulm.de> that migrates the SH port to multilib'ing. This patch involved moving a number of files in the CVS repository, adding new files, and deleting files from their previous location. Ralf gave good instructions (not repeated here) and here are his notes: Note 1: In this version, I did not change the installation points of the headers which are moved inside of the source-tree. This is a temporary hack for not breaking compatibility with 4.5 based BSPs, but will probably not last once having real multilibs (We would have include file conflicts when several BSPs/CPU_MODELS share a common installation prefix). Note 2: I hope not to have broken too much, but I would not be astonished if something goes wrong. Note 3: There are more patches to come :)
* Fixed comment thanks to John M. Mills <jmills@tga.com>.Joel Sherrill2000-01-051-6/+0
* Adding files not added as part of merger of SH2 port.Joel Sherrill1999-11-221-0/+321
* Patch from "John M. Mills" <jmills@tga.com> with subsequent cleanup fromJoel Sherrill1999-11-181-3/+10
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> that adds initial Hitachi SH-2 support to RTEMS. Ralf's comments are: Changes: ------ 1. SH-Port: * Many files renamed. * CONSOLE_DEVNAME and MHZ defines removed from libcpu. * console.c moved to libbsp/sh/shared, build in libbsp/sh/<BSP>/console applying VPATH. * CONSOLE_DEVNAME made BSP-specific, replacement is defined in bsp.h * MHZ define replaced with HZ (extendent resolution) in custom/*.cfg * -DHZ=HZ used in bspstart.c, only * Makefile variable HZ used in bsp-dependent directories only. 2. SH1-Port * clock-driver rewritten to provide better resolution for odd CPU frequencies. This driver is only partially tested on hardware, ie. sightly experimental, but I don't expect severe problems with it. * Polling SCI-driver added. This driver is experimental and completly untested yet. Therefore it is not yet used for the console (/dev/console is still pointing to /dev/null, cf. gensh1/bsp.h). * minor changes to the timer driver * SH1 specific delay()/CPU_delay() now is implemented as a function 3. SH2-Port * Merged * IMO, the code is still in its infancy. Therefore I have interspersed comments (FIXME) it for items which I think John should look after. * sci and console drivers partially rewritten and extended (John, I hope you don't mind). * Copyright notices are not yet adapted
* SH port submitted from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill1998-03-201-0/+311
