* mpc5xx/console-generic/console-generic.c, mpc8260/timer/timer.c,
new-exceptions/cpu.c, old-exceptions/cpu.c: Move interrupt_stack_size
field from CPU Table to Configuration Table. Eliminate CPU Table from
all ports. Delete references to CPU Table in all forms.
* new-exceptions/raw_exception.c, new-exceptions/raw_exception.h,
old-exception/cpu.c: define bsp_exceptions_in_RAM variable.
This is probably only used by the simulator (were else
can you install something to ROM ??).
* mpc5xx/clock/clock.c, mpc5xx/timer/timer.c, mpc8260/clock/clock.c,
mpc8260/cpm/brg.c, mpc8260/timer/timer.c, mpc8xx/clock/clock.c,
mpc8xx/console-generic/console-generic.c, mpc8xx/timer/timer.c,
new-exceptions/raw_exception.c, old-exceptions/cpu.c,
ppc403/clock/clock.c, ppc403/console/console.c,
ppc403/console/console.c.polled, ppc403/console/console405.c,
ppc403/ictrl/ictrl.c, ppc403/irq/ictrl.c, ppc403/timer/timer.c,
ppc403/tty_drv/tty_drv.c: Eliminate PowerPC specific elements from
the CPU Table. They have been replaced with variables named bsp_XXX
as needed.
* new-exceptions/cpu.c, rtems/powerpc/powerpc.h:
Remove CPU_MINIMUM_STACK_FRAME_SIZE.
Use PPC_MINIMUM_STACK_FRAME_SIZE instead.
* rtems/powerpc/powerpc.h: Add PPC_MINIMUM_STACK_FRAME_SIZE.
* cpu.c: Use _CPU_MSR_GET instead of _CPU_MSR_Value (Unify old/new
exception processing API).
* cpu.c (ppc_exception_vector_addr): Merge ppc603 and ppc603e cases.
* cpu.c, cpu_asm.S, irq_stub.S: #include <rtems/powerpc/powerpc.h>.
* cpu.c: Add _PPC_MSR_DISABLE_MASK.
* cpu.c, cpu_asm.S, irq_stub.S, rtems/score/ppc_offs.h:
Remove PPC_ABI_POWEROPEN.
Remove PPC_ABI_GCC27.
PR 696/bsps
* cpu.c: Include bsp.h.
* cpu.c, ppccache.c: Convert to using c99 fixed size types.
* cpu.c, cpu_asm.S: URL for license changed.
* cpu.c: Include declaration of variable i in ifdef USE_SPRG to
eliminate warning.
* cpu.c: Include <rtems/powerpc/cache.h>.
This was tracked as PR91.
* rtems/score/c_isr.inl: Deleted and contents merged into cpu.c.
* cpu.c: Received contents of c_isr.inl.
* Makefile.am: Deleted reference to c_isr.inl.
process was captured as PR50.
* ppc403/console/console405.c ppc403/tty_drv/.cvsignore,
ppc403/tty_drv/Makefile.am, ppc403/tty_drv/tty_drv.c,
ppc403/tty_drv/tty_drv.h: New files.
* Makefile.am, README, configure.ac, old_exception_processing/cpu.c,
old_exception_processing/cpu.h, ppc403/Makefile.am,
ppc403/clock/clock.c, ppc403/console/Makefile.am,
ppc403/console/console.c, ppc403/ictrl/ictrl.c, ppc403/ictrl/ictrl.h,
ppc403/timer/timer.c: Modified.
* mpc6xx/clock/c_clock.c, mpc6xx/clock/c_clock.h, mpc8xx/clock/clock.c,
mpc8xx/timer/timer.c, new_exception_processing/cpu.c,
new_exception_processing/cpu.h, new_exception_processing/cpu_asm.S,
old_exception_processing/cpu.c, old_exception_processing/cpu.h,
old_exception_processing/cpu_asm.S, old_exception_processing/rtems.S:
Fixed typo.
* new_exception_processing/cpu.h, old_exception_processing/cpu.c:
old_exception_processing/cpu.h, Added _CPU_Initialize_vectors().
In particular, spurious vector initialization had to be moved
on old exception processing model.
significant things:
and PowerPC
same code base.
As part of this effort, the mpc750 libcpu code is now shared with the
ppc6xx.
