* | Remove CVS-Ids. | Ralf Corsépius | 2012-07-19 | 3 | -6/+0 |
* | Require automake-1.12.2. | Ralf Corsépius | 2012-07-19 | 1 | -1/+1 |
* | Require autoconf-2.69. | Ralf Corsépius | 2012-07-19 | 1 | -1/+1 |
* | Remove CVS Id Strings (manual edits after script) | Joel Sherrill | 2012-05-11 | 1 | -2/+0 |
| | | | | | | These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns. | ||||
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 51 | -66/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 2 | -6/+0 |
* | libcpu misc m68k and sh - Correct formatting and remove weird Id strings | Joel Sherrill | 2012-05-03 | 5 | -49/+35 |
* | General - Remove extraneous blank line in license message | Joel Sherrill | 2012-05-03 | 8 | -8/+0 |
| | | | | | | | | | | | | | Many files had an extra blank line in the license text found in the file header. This patch removes that line. * The license and distribution terms for this file may be * found in the file LICENSE in this distribution or at * * http://www.rtems.com/license/LICENSE. The script that did this also turned off execute permission when it was turned on incorrectly. | ||||
* | libcpu/m68k/mcf532x - Remove bad $Id$ and clean up file header | Joel Sherrill | 2012-05-02 | 1 | -3/+3 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -8/+0 |
* | 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-11 | 6 | -28/+34 |
| | | | | | | * mcf5225x/network/fec.c, mcf5235/cache/cachepd.c, mcf532x/cache/cachepd.c, shared/cache/cache.c, shared/misc/m68kidle.c: Use "__asm__" instead of "asm" for improved c99-compliance. | ||||
* | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-02 | 2 | -2/+6 |
| | | | | * configure.ac: Require autoconf-2.68, automake-1.11.1. | ||||
* | 2010-04-05 Thomas Znidar <t.znidar@embed-it.com> | Joel Sherrill | 2010-04-05 | 7 | -1/+3899 |
| | | | | | | * Makefile.am, configure.ac, preinstall.am: Add mcf5225x support. * mcf5225x/include/fec.h, mcf5225x/include/mcf5225x.h, mcf5225x/network/fec.c: New files. | ||||
* | Fix hex constants. | Eric Norum | 2010-03-16 | 2 | -2/+6 |
* | adapted to new prototype for *_write function | Thomas Doerfler | 2009-12-17 | 3 | -10/+17 |
* | Whitespace removal. | Ralf Corsepius | 2009-12-08 | 2 | -35/+35 |
* | Whitespace removal. | Ralf Corsepius | 2009-12-04 | 41 | -591/+591 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 4 | -84/+84 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 16 | -75/+75 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 2 | -2/+2 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-28 | 1 | -1/+1 |
* | 2009/10/20 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2009-10-20 | 1 | -1/+1 |
| | | | | * shared/misc/m68kidle.c: somehow this change was never committed, sorry. | ||||
* | add MC_DMA support to MCF548x | Thomas Doerfler | 2009-10-15 | 12 | -0/+4408 |
* | * mcf5282/include/mcf5282.h: add missing (x) params to four macros, added ↵ | Thomas Doerfler | 2009-10-08 | 2 | -70/+75 |
| | | | | paranthesis around usage of x in some macros | ||||
* | *** empty log message *** | Till Straumann | 2009-09-10 | 1 | -0/+1 |
* | 2009-09-10 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2009-09-10 | 1 | -0/+5 |
| | | | | | * shared/misc/m68kidle.c: added "cc" clobber to inline asm; STOP instruction modifies CCR! | ||||
* | add cache definition for mcfv4e | Thomas Doerfler | 2009-07-17 | 2 | -0/+7 |
* | 2009-02-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-12 | 2 | -1/+6 |
| | | | | | * shared/misc/m68kidle.c: Change prototype of IDLE thread to consistently return void * and take a uintptr_t argument. | ||||
* | 2009-02-11 Till Straumann <strauman@slac.stanford.edu> | Joel Sherrill | 2009-02-11 | 3 | -3/+22 |
| | | | | | | PR 1369/bsps * Makefile.am, configure.ac: Fix name clashes when using MC68040 fpsp floating-point emulation. | ||||
* | 2008-09-30 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-30 | 2 | -0/+5 |
| | | | | * mcf5206/timer/timerisr.S: Make compile again. | ||||
* | *** empty log message *** | Thomas Doerfler | 2008-09-22 | 1 | -0/+5 |
* | 2008-09-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-19 | 4 | -0/+156 |
| | | | | | | * Makefile.am: Split out various BSPs bspstart.c contents. Move cache management code here. * mcf5223x/cache/cachepd.c, mcf5235/cache/cachepd.c: New files. | ||||
* | 2008-09-18 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-18 | 2 | -1/+4 |
| | | | | * mcf5206/timer/timerisr.S: Remove unnecessary include of bsp.h | ||||
* | 2008-09-08 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-08 | 2 | -31/+137 |
| | | | | | * mcf548x/include/Freescale_license.txt: Convert to UNIX CR/LF style, eliminate characters with 8th bit set. | ||||
* | corrected parameters for done signalling | Thomas Doerfler | 2008-09-08 | 2 | -7/+7 |
* | 2008-09-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-08 | 1 | -0/+4 |
| | | | | * mcf548x/include/mcf548x.h: Convert to Unix file format. | ||||
* | Convert to Unix file format. | Ralf Corsepius | 2008-09-08 | 1 | -4057/+4057 |
* | 2008-09-05 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-05 | 3 | -84/+8 |
| | | | | | | | | * mcf5206/clock/ckinit.c, mcf5272/clock/ckinit.c: The Shared Memory Driver no longer requires the special IOCTL in Clock_control. This was a hack which has existed since before the Classic API Timer Manager was implemented. All implementations of and references to Clock_control were removed. | ||||
* | 2008-09-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-05 | 1 | -0/+4 |
| | | | | * mcf5206/timer/timer.c, mcf5272/timer/timer.c: Convert to "bool". | ||||
* | Convert to "bool". | Ralf Corsepius | 2008-09-05 | 2 | -6/+6 |
* | Eliminate rtems_boolean. | Ralf Corsepius | 2008-09-02 | 2 | -5/+5 |
* | 2008-09-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-02 | 1 | -0/+5 |
| | | | | | * mcf5206/console/mcfuart.c, mcf5206/include/mcfuart.h: Eliminate rtems_boolean. | ||||
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 2 | -34/+0 |
| | | | | | | | | * arm/at91rm9200/timer/timer.c, arm/lpc22xx/timer/timer.c, arm/mc9328mxl/timer/timer.c, arm/s3c2400/timer/timer.c, arm/s3c24xx/timer/timer.c, bfin/timer/timer.c, m68k/mcf5206/timer/timer.c, m68k/mcf5272/timer/timer.c: Rename timer driver methods to follow RTEMS programming conventions. | ||||
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 5 | -28/+34 |
| | | | | | | * mcf5206/timer/timer.c, mcf5206/timer/timerisr.S, mcf5272/timer/timer.c, mcf5272/timer/timerisr.S: Rename timer driver methods to follow RTEMS programming conventions. | ||||
* | 2008-08-19 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-08-19 | 2 | -10/+18 |
| | | | | * m68040/fpsp/rtems_fpsp.c: Move extern outside of braces. | ||||
* | 2008-07-31 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-07-31 | 2 | -2/+6 |
| | | | | * shared/misc/m68kidle.c: Correct prototype of Idle threads. | ||||
* | Cleanup. | Ralf Corsepius | 2008-07-14 | 1 | -6/+0 |
* | added mcf548x BSP support | Thomas Doerfler | 2008-07-11 | 6 | -0/+4116 |
* | 2008-07-04 Matthew Riek <matthew.riek@ibiscomputer.com.au> | Joel Sherrill | 2008-07-04 | 5 | -1/+179 |
| | | | | | | | * Makefile.am, mcf532x/include/mcf532x.h, shared/cache/cache_.h: Add cache support for 5329. Enable the cache in copyback and write-through so we can assume that in BSP. * mcf532x/cache/cachepd.c: New file. | ||||
* | 2008-06-20 Matthew Riek <matthew.riek@ibiscomputer.com.au> | Joel Sherrill | 2008-06-20 | 5 | -0/+4483 |
| | | | | | | * Makefile.am, configure.ac, preinstall.am: Adding mcf5329 BSP and CPU support. * mcf532x/include/mcf532x.h: New file. |
