* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 2 | -6/+0 |
* | libcpu misc m68k and sh - Correct formatting and remove weird Id strings | Joel Sherrill | 2012-05-03 | 5 | -49/+35 |
* | General - Remove extraneous blank line in license message | Joel Sherrill | 2012-05-03 | 8 | -8/+0 |
| | | | | | | | | | | | | | Many files had an extra blank line in the license text found in the file header. This patch removes that line. * The license and distribution terms for this file may be * found in the file LICENSE in this distribution or at * * http://www.rtems.com/license/LICENSE. The script that did this also turned off execute permission when it was turned on incorrectly. | ||||
* | libcpu/m68k/mcf532x - Remove bad $Id$ and clean up file header | Joel Sherrill | 2012-05-02 | 1 | -3/+3 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -8/+0 |
* | 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-11 | 6 | -28/+34 |
| | | | | | | * mcf5225x/network/fec.c, mcf5235/cache/cachepd.c, mcf532x/cache/cachepd.c, shared/cache/cache.c, shared/misc/m68kidle.c: Use "__asm__" instead of "asm" for improved c99-compliance. | ||||
* | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-02 | 2 | -2/+6 |
| | | | | * configure.ac: Require autoconf-2.68, automake-1.11.1. | ||||
* | 2010-04-05 Thomas Znidar <t.znidar@embed-it.com> | Joel Sherrill | 2010-04-05 | 7 | -1/+3899 |
| | | | | | | * Makefile.am, configure.ac, preinstall.am: Add mcf5225x support. * mcf5225x/include/fec.h, mcf5225x/include/mcf5225x.h, mcf5225x/network/fec.c: New files. | ||||
* | Fix hex constants. | Eric Norum | 2010-03-16 | 2 | -2/+6 |
* | adapted to new prototype for *_write function | Thomas Doerfler | 2009-12-17 | 3 | -10/+17 |
* | Whitespace removal. | Ralf Corsepius | 2009-12-08 | 2 | -35/+35 |
* | Whitespace removal. | Ralf Corsepius | 2009-12-04 | 41 | -591/+591 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 4 | -84/+84 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 16 | -75/+75 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 2 | -2/+2 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-28 | 1 | -1/+1 |
* | 2009/10/20 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2009-10-20 | 1 | -1/+1 |
| | | | | * shared/misc/m68kidle.c: somehow this change was never committed, sorry. | ||||
* | add MC_DMA support to MCF548x | Thomas Doerfler | 2009-10-15 | 12 | -0/+4408 |
* | * mcf5282/include/mcf5282.h: add missing (x) params to four macros, added ↵ | Thomas Doerfler | 2009-10-08 | 2 | -70/+75 |
| | | | | paranthesis around usage of x in some macros | ||||
* | *** empty log message *** | Till Straumann | 2009-09-10 | 1 | -0/+1 |
* | 2009-09-10 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2009-09-10 | 1 | -0/+5 |
| | | | | | * shared/misc/m68kidle.c: added "cc" clobber to inline asm; STOP instruction modifies CCR! | ||||
* | add cache definition for mcfv4e | Thomas Doerfler | 2009-07-17 | 2 | -0/+7 |
* | 2009-02-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-12 | 2 | -1/+6 |
| | | | | | * shared/misc/m68kidle.c: Change prototype of IDLE thread to consistently return void * and take a uintptr_t argument. | ||||
* | 2009-02-11 Till Straumann <strauman@slac.stanford.edu> | Joel Sherrill | 2009-02-11 | 3 | -3/+22 |
| | | | | | | PR 1369/bsps * Makefile.am, configure.ac: Fix name clashes when using MC68040 fpsp floating-point emulation. | ||||
* | 2008-09-30 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-30 | 2 | -0/+5 |
| | | | | * mcf5206/timer/timerisr.S: Make compile again. | ||||
* | *** empty log message *** | Thomas Doerfler | 2008-09-22 | 1 | -0/+5 |
* | 2008-09-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-19 | 4 | -0/+156 |
| | | | | | | * Makefile.am: Split out various BSPs bspstart.c contents. Move cache management code here. * mcf5223x/cache/cachepd.c, mcf5235/cache/cachepd.c: New files. | ||||
* | 2008-09-18 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-18 | 2 | -1/+4 |
| | | | | * mcf5206/timer/timerisr.S: Remove unnecessary include of bsp.h | ||||
* | 2008-09-08 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-08 | 2 | -31/+137 |
| | | | | | * mcf548x/include/Freescale_license.txt: Convert to UNIX CR/LF style, eliminate characters with 8th bit set. | ||||
* | corrected parameters for done signalling | Thomas Doerfler | 2008-09-08 | 2 | -7/+7 |
* | 2008-09-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-08 | 1 | -0/+4 |
| | | | | * mcf548x/include/mcf548x.h: Convert to Unix file format. | ||||
* | Convert to Unix file format. | Ralf Corsepius | 2008-09-08 | 1 | -4057/+4057 |
* | 2008-09-05 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-05 | 3 | -84/+8 |
| | | | | | | | | * mcf5206/clock/ckinit.c, mcf5272/clock/ckinit.c: The Shared Memory Driver no longer requires the special IOCTL in Clock_control. This was a hack which has existed since before the Classic API Timer Manager was implemented. All implementations of and references to Clock_control were removed. | ||||
* | 2008-09-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-05 | 1 | -0/+4 |
| | | | | * mcf5206/timer/timer.c, mcf5272/timer/timer.c: Convert to "bool". | ||||
* | Convert to "bool". | Ralf Corsepius | 2008-09-05 | 2 | -6/+6 |
* | Eliminate rtems_boolean. | Ralf Corsepius | 2008-09-02 | 2 | -5/+5 |
* | 2008-09-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-02 | 1 | -0/+5 |
| | | | | | * mcf5206/console/mcfuart.c, mcf5206/include/mcfuart.h: Eliminate rtems_boolean. | ||||
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 2 | -34/+0 |
| | | | | | | | | * arm/at91rm9200/timer/timer.c, arm/lpc22xx/timer/timer.c, arm/mc9328mxl/timer/timer.c, arm/s3c2400/timer/timer.c, arm/s3c24xx/timer/timer.c, bfin/timer/timer.c, m68k/mcf5206/timer/timer.c, m68k/mcf5272/timer/timer.c: Rename timer driver methods to follow RTEMS programming conventions. | ||||
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 5 | -28/+34 |
| | | | | | | * mcf5206/timer/timer.c, mcf5206/timer/timerisr.S, mcf5272/timer/timer.c, mcf5272/timer/timerisr.S: Rename timer driver methods to follow RTEMS programming conventions. | ||||
* | 2008-08-19 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-08-19 | 2 | -10/+18 |
| | | | | * m68040/fpsp/rtems_fpsp.c: Move extern outside of braces. | ||||
* | 2008-07-31 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-07-31 | 2 | -2/+6 |
| | | | | * shared/misc/m68kidle.c: Correct prototype of Idle threads. | ||||
* | Cleanup. | Ralf Corsepius | 2008-07-14 | 1 | -6/+0 |
* | added mcf548x BSP support | Thomas Doerfler | 2008-07-11 | 6 | -0/+4116 |
* | 2008-07-04 Matthew Riek <matthew.riek@ibiscomputer.com.au> | Joel Sherrill | 2008-07-04 | 5 | -1/+179 |
| | | | | | | | * Makefile.am, mcf532x/include/mcf532x.h, shared/cache/cache_.h: Add cache support for 5329. Enable the cache in copyback and write-through so we can assume that in BSP. * mcf532x/cache/cachepd.c: New file. | ||||
* | 2008-06-20 Matthew Riek <matthew.riek@ibiscomputer.com.au> | Joel Sherrill | 2008-06-20 | 5 | -0/+4483 |
| | | | | | | * Makefile.am, configure.ac, preinstall.am: Adding mcf5329 BSP and CPU support. * mcf532x/include/mcf532x.h: New file. | ||||
* | 2008-06-19 Matthew Riek <matthew.riek@ibiscomputer.com.au> | Chris Johns | 2008-06-19 | 5 | -3377/+3383 |
| | | | | | | | | * mcf52235/include/mcf52235.h: Removed. Moved to the more generic mcf5223x.h. * mcf5223x/include/mcf5223x.h: New. Was mcf52235.h. * Makefile.am, configure.ac, preinstall.am: Changed from mcf52235 to mcf5223x. | ||||
* | 2008-06-10 Matthew Riek <matthew.riek@ibiscomputer.com.au> | Chris Johns | 2008-06-11 | 5 | -0/+3386 |
| | | | | | * mcf52235/include/mcf52235.h: New. * preinstall.am, configure.ac, Makefile.am: Add 52235 support. | ||||
* | 2007-12-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-11 | 3 | -42/+48 |
| | | | | | | * mcf5206/clock/ckinit.c, mcf5272/clock/ckinit.c: Eliminate copies of the Configuration Table. Use the RTEMS provided accessor macros to obtain configuration fields. | ||||
* | 2007-11-22 Chris Johns <chrisj@rtems.org> | Chris Johns | 2007-11-22 | 2 | -1/+5 |
| | | | | * m68k/mcf5235/include/mcf5235.h: Remove '/' from define label. | ||||
* | 2007-06-04 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-04 | 3 | -94/+7 |
| | | | | | | * Makefile.am: Now use the m68k memcpy and memset recently added to newlib instead of our own. * shared/misc/memcpy.c: Removed. |
