* | Moved i386 and m68k cache management code to libcpu. Everything | Joel Sherrill | 2000-06-13 | 4 | -0/+269 |
| | | | | | | now is an implementation of the prototypes in rtems/rtems/cache.h. The libcpu/i386/wrapup directory is no longer needed. The PowerPC needs this done to it. | ||||
* | Added .cvsignore. | Joel Sherrill | 2000-06-13 | 2 | -0/+4 |
* | Added optimized version of memcpy.c to this directory since RTEMS makes | Joel Sherrill | 1998-06-12 | 1 | -0/+87 |
important distinctions between CPU models which are not made by gcc. These distinctions help give us a more optimized memcpy(). This is important for message queues and KA9Q. |
