* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -1/+0 |
* | Whitespace removal. | Ralf Corsepius | 2009-12-04 | 1 | -9/+9 |
* | Patch from Charles-Antoine Gauthier <charles.gauthier@iit.nrc.ca>. | Joel Sherrill | 1999-07-26 | 1 | -3/+3 |
| | | | | | | | | | | | | | | | | | | | to address m68k-rtemself for the MVME167. Here is the rtems patch I promissed you a long time ago to enable ELF with m68k. The target name I selected is m68k-rtemself. It preserves the m68k-rtems COFF target, and is parterned after the other ELF/COFF dual targets. The mvme167.cfg file causes the -qelf flag to be used during compilation if the name of the compiler contains rtemself. This flag is used in the bsp_specs file to select the elflinkcmds file rather than the linkcmds file. The former is for ELF, the latter for COFF. Some patches are required to the mc68040 FPSP code. Some of the assembler files contain instructions that were rejected by the m68k-rtemself-as assembler. This is a minor bug in the m68k ELF assembler, I think. | ||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to rename all | Joel Sherrill | 1998-12-14 | 1 | -0/+508 |
.s files to .S in conformance with GNU conventions. This is a minor step along the way to supporting automake. |
