* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 2 | -1/+5 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 3 | -3/+0 |
* | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-01 | 3 | -2/+7 |
| | | | | | * cpuModel.S: Include <rtems/asm.h> instead of <asm.h>. * idtr.S: Include <rtems/asm.h> instead of <asm.h>. | ||||
* | 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-31 | 2 | -1/+5 |
| | | | | * page.c: Convert to using c99 fixed size types. | ||||
* | 2004-03-26 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-26 | 2 | -1/+5 |
| | | | | * configure.ac: Add 2nd argument (rtems_updir) to RTEMS_TOP. | ||||
* | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-06 | 2 | -1/+4 |
| | | | | * Makefile.am: Don't include .../lib.am. | ||||
* | 2004-01-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-01-21 | 2 | -288/+5 |
| | | | | | PR 557/bsps * cpu.c: Removed. File appears to have been orphaned around June 2000 | ||||
* | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-21 | 5 | -27/+59 |
| | | | | | | | | | * Makefile.am: Split the blob of *.o into cache.rel, page.rel and score.rel. Add PREINSTALL_DIRS. Use automake compilation rules. * page.c, cpuModel.S: Remove stray blanks. * configure.ac: Require automake >= 1.8.2. Add AM_PROG_CC_C_O. Add subdir-objects to AUTOMAKE_OPTIONS. | ||||
* | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-14 | 2 | -0/+8 |
| | | | | | * Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. | ||||
* | 2003-12-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-16 | 2 | -12/+16 |
| | | | | * Makefile.am: Eliminate VPATH. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -2/+5 |
| | | | | * Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -2/+6 |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-02 | 2 | -1/+5 |
| | | | | * Makefile.am: Remove all-local: $(ARCH). | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 2 | -10/+25 |
| | | | | * Makefile.am: Reformat. Use dirstamps for preinstallation. | ||||
* | 2003-10-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-22 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_CANONICAL_HOST. | ||||
* | 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-21 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_CHECK_CPU. | ||||
* | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-04 | 8 | -7/+12 |
| | | | | | * cpu.c, cpu.h, cpuModel.S, cpuModel.h, displayCpu.c, idtr.S, page.c: URL for license changed. | ||||
* | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-18 | 2 | -1/+5 |
| | | | | * Makefile.am: Reflect having moved aclocal/. | ||||
* | Fix broken ChangeLog entries. | Ralf Corsepius | 2003-08-18 | 1 | -1/+1 |
* | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-16 | 2 | -3/+7 |
| | | | | Makefile.am: Reflect having moved automake. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 2 | -1/+5 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 2 | -1/+4 |
* | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-02-11 | 2 | -1/+5 |
| | | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | ||||
| | | | | * configure.ac: AC_PREREQ(2.57). | ||||
* | 2002-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-19 | 3 | -7/+8 |
| | | | | | | * Makefile.am: Don't include @RTEMS_BSP@.cfg. Eliminate *_O_FILES. * configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP. | ||||
* | 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-06 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_CHECK_BSP_CACHE. | ||||
* | 2002-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-01 | 2 | -0/+5 |
| | | | | * configure.ac: Add RTEMS_PROG_CCAS. | ||||
* | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-21 | 2 | -3/+9 |
| | | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | ||||
* | 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-08-11 | 2 | -2/+6 |
| | | | | * Makefile.am: Use .$(OBJEXT) instead of .o. | ||||
* | 2002-07-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-07-30 | 4 | -188/+9 |
| | | | | | | | * cpuModel.S: Include <rtems/score/registers.h> instead of <libcpu/registers.h>. * registers.h: Removed. * Makefile.am: Remove registers.h. | ||||
* | 2002-03-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-04-12 | 4 | -83/+13 |
| | | | | | | | * cache.c: Include <rtems/score/registers.h> instead of <libcpu/registers.h>. * cpu.h: Ditto. Remove parts moved to score/cpu/i386. * registers.h: Add BIG-FAT warning. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 3 | -3/+9 |
| | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2002-03-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-20 | 2 | -4/+11 |
| | | | | | * cpuModel.h: PR 146. Adding guards. Remove unnecessary headers. | ||||
* | 2002-01-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-01-04 | 3 | -2/+7 |
| | | | | | * i386/displayCpu.c: Include rtems/bspIo.h instead of bspIo.h. * i386/page.c: Include rtems/bspIo.h instead of bspIo.h. | ||||
* | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-12 | 1 | -0/+33 |
| | | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. | ||||
* | 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-12 | 1 | -32/+0 |
| | | | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. | ||||
* | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-11 | 2 | -1/+8 |
* | 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-09-27 | 2 | -2/+7 |
| | | | | | * Makefile.am: Use 'PREINSTALL_FILES ='. * Makefile.am: Use 'CLEANFILES ='. | ||||
* | 2001-02-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-03-01 | 3 | -6/+15 |
| | | | | | * Makefile.am: Apply include_*HEADERS instead of H_FILES. * .cvsignore: Add cache.h. | ||||
* | 2000-12-06 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-12-06 | 2 | -0/+5 |
| | | | | * displayCpu.c: Added include of <rtems.h> to eliminate warnings. | ||||
* | 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-09 | 2 | -1/+5 |
| | | | | * Makefile.am: Use ... instead of RTEMS_TOPdir in ACLOCAL_AMFLAGS. | ||||
* | 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-02 | 2 | -1/+5 |
| | | | | * Makefile.am: Switch to ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/aclocal. | ||||
* | 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-10-26 | 2 | -1/+6 |
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. | ||||
* | 2000-10-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-10-19 | 2 | -0/+6 |
| | | | | * page.c: Readd deleted comment lines. | ||||
* | 2000-10-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-10-18 | 2 | -4/+5 |
| | | | | * page.c: Replaced prototype of printk() with include of <bspIo.h>. | ||||
* | 2000-10-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-10-17 | 3 | -290/+6 |
| | | | | | * idt.c, Makefile.am: Moved idt.c to libbsp/i386/shared so i386 RTEMS can be multilib'ed. | ||||
* | 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-09-05 | 2 | -3/+9 |
| | | | | * Makefile.am: Include compile.am | ||||
* | Adding ChangeLogs. | Joel Sherrill | 2000-08-10 | 1 | -0/+3 |
* | Patch from John Cotton <john.cotton@nrc.ca> to correct cache | Joel Sherrill | 2000-06-14 | 3 | -29/+22 |
| | | | | | | routine naming to follow RTEMS package/object.method rule. This patch also eliminated calls to the obsolete routine m68k_enable_caching. | ||||
* | Prototypes for cache manager support functions now agree. | Joel Sherrill | 2000-06-13 | 2 | -7/+3 |
