* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 7 | -7/+7 |
* | RTEMS: Delete ChangeLog files. | Gedare Bloom | 2013-03-08 | 1 | -315/+0 |
| | | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain. | ||||
* | Require automake-1.12.2. | Ralf Corsépius | 2012-07-19 | 1 | -1/+1 |
* | Require autoconf-2.69. | Ralf Corsépius | 2012-07-19 | 1 | -1/+1 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 8 | -16/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 2 | -6/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -9/+0 |
* | 2011-10-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-10-23 | 2 | -2/+4 |
| | | | | * page.c: Remove unused var "dirCount". | ||||
* | 2011-03-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-03-14 | 2 | -8/+12 |
| | | | | * cpu.h: Remove warnings. | ||||
* | 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-11 | 4 | -22/+27 |
| | | | | | * cache.c, cpu.h, cpuModel.h: Use "__asm__" instead of "asm" for improved c99-compliance. | ||||
* | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-02 | 2 | -2/+6 |
| | | | | * configure.ac: Require autoconf-2.68, automake-1.11.1. | ||||
* | 2011-01-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-01-29 | 2 | -2/+6 |
| | | | | * page.c: Remove CVS-Header tag. Add CVS-Id | ||||
* | 2011-01-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2011-01-28 | 4 | -3/+8 |
| | | | | | * byteorder.h, cpu.h, page.c: Fix typo where license said found in found in. | ||||
* | 2009-10-28 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2010-07-06 | 2 | -0/+15 |
| | | | | * byteorder.h: added ld_le16, st_le16. | ||||
* | 2010-05-21 Vinu Rajashekhar <vinutheraj@gmail.com> | Joel Sherrill | 2010-05-21 | 3 | -34/+40 |
| | | | | | * cache.c, page.c: Use masks and shift operations instead of bit-fields. | ||||
* | 2010-04-15 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-04-15 | 4 | -131/+169 |
| | | | | | * cpuModel.S, cpuModel.h, displayCpu.c: Update to include more reserved bits and pick out a bit more information. | ||||
* | 2009-12-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-12-11 | 2 | -11/+7 |
| | | | | * page.c: Use bsp_mem_size. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-12-04 | 6 | -106/+106 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-28 | 1 | -1/+1 |
* | 2009-10-28 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2009-10-29 | 2 | -12/+24 |
| | | | | | * displayCpu.c: Fixed formatting for prettier printing; don't print more than 8 flags on a single line of output. | ||||
* | 2009-10-28 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2009-10-28 | 4 | -5/+29 |
| | | | | | | | * cpuModel.S, cpuModel.h, displayCpu.c: Save/cache CPUID:ECX (extended capabilities) in a new variable (x86_capability_x). Added more known flag description strings (printCpuInfo()) and let 'printCpuInfo()' dump the extended feature flags, too. | ||||
* | 2009-05-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-05-06 | 2 | -16/+39 |
| | | | | * page.c: Fixed warnings. | ||||
* | 2008-12-03 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-12-03 | 2 | -0/+21 |
| | | | | | | | | Michael South <msouth@msouth.org> PR 1344/bsps * cpuModel.h: Add use of TSC for nanoseconds granularity. i8254 is very slow on some systems. TSC use is auto-detected by default. | ||||
* | Add missing prototypes. | Ralf Corsepius | 2008-08-16 | 3 | -6/+6 |
* | 2008-08-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-08-16 | 1 | -0/+4 |
| | | | | * cache.c, displayCpu.c, page.c: Add missing prototypes. | ||||
* | Cleanup. | Ralf Corsepius | 2008-07-14 | 1 | -6/+0 |
* | 2007-03-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-03-28 | 2 | -1/+5 |
| | | | | * page.c: Redo print to not have cvs conflict marker. | ||||
* | Regenerate. | Ralf Corsepius | 2007-01-08 | 1 | -1/+1 |
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 2 | -1/+5 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 2 | -2/+6 |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | ||||
* | 2006-05-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-05-16 | 2 | -3/+5 |
| | | | | * configure.ac: Use RTEMS_AMPOLISH3. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -0/+2 |
* | Remove all-local:. | Ralf Corsepius | 2006-01-12 | 1 | -2/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -2/+2 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 1 | -4/+0 |
* | 2005-11-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-04 | 1 | -0/+2 |
| | | | | | * Makefile.am: Add preinstall.am * preinstall.am: New. | ||||
* | Add preinstall.am | Ralf Corsepius | 2005-11-04 | 1 | -23/+6 |
* | New | Ralf Corsepius | 2005-11-04 | 1 | -0/+34 |
* | 2005-11-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-04 | 2 | -0/+5 |
| | | | | * configure.ac: Add AMPOLISH3. | ||||
* | 2005-11-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-04 | 1 | -0/+4 |
| | | | | * byteorder.h: New. | ||||
* | New. | Ralf Corsepius | 2005-11-04 | 1 | -0/+22 |
* | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-07 | 2 | -3/+7 |
| | | | | * Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | ||||
* | 2005-01-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-03 | 2 | -1/+5 |
| | | | | * Makefile.am: Fix typo. | ||||
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 2 | -33/+8 |
| | | | | * Makefile.am: Remove build-variant support. | ||||
* | 2004-10-19 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-10-19 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_ENABLE_BARE. | ||||
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 2 | -1/+5 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 3 | -3/+0 |
* | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-01 | 3 | -2/+7 |
| | | | | | * cpuModel.S: Include <rtems/asm.h> instead of <asm.h>. * idtr.S: Include <rtems/asm.h> instead of <asm.h>. | ||||
* | 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-31 | 2 | -1/+5 |
| | | | | * page.c: Convert to using c99 fixed size types. |
