* at91rm9200/include/at91rm9200.h,
at91rm9200/include/at91rm9200_dbgu.h,
at91rm9200/include/at91rm9200_emac.h,
at91rm9200/include/at91rm9200_gpio.h,
at91rm9200/include/at91rm9200_mem.h,
at91rm9200/include/at91rm9200_pmc.h, s3c2400/include/s3c2400.h:
Convert C++ style comments to C style.
* mc9328mxl/include/mc9328mxl.h: Added UART register definitions.
* at91rm9200/irq/bsp_irq_init.c, mc9328mxl/clock/clockdrv.c,
mc9328mxl/irq/bsp_irq_asm.S, mc9328mxl/irq/bsp_irq_init.c,
mc9328mxl/irq/irq.c, mc9328mxl/irq/irq.h,
s3c2400/irq/bsp_irq_init.c: Changed interrupt handling
to use shared rtems_irq_connect_data struct.
* at91rm9200/clock/clock.c: Convert to using shared clock driver shell.
* configure.ac: Use RTEMS_AMPOLISH3.
* at91rm9200/clock/clock.c: The clock tick is not very precise on
at91rm9200. The attached patch improves the situation by:
(1) Not reloading the "period interval timer" register in the
interrupt handler since this is done automatically.
(2) Use integer rounding in the calculation of the "period interval
timer" register value to get as close as posible to the
CONFIGURE_MICROSECONDS_PER_TICK value.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
PR 776/bsps
* at91rm9200/irq/bsp_irq_asm.S, at91rm9200/irq/irq.h: Added code to
pass interrupt vector number to ISR on AT91RM9200
PR 727/bsps
* at91rm9200/clock/clock.c: Correct the equation so 10 milliseconds
tick is not 9.365 miliseconds long.
* lcd/lcd.c: removed.
* Makefile.am: Remove s3c2400/lcd/lcd.c
* s3c2400/lcd/lcd.c: Remove.
* s3c2400/clock/support.c: file "rewrote" to avoid GPL.
* Makefile.am: Add s3c2400/lcd/lcd.c, s3c2400/clock/support.c
* s3c2400/clock/clockdrv.c: Update to use get_PCLK()
* s3c2400/timer/timer.c: Update to use get_PCLK()
* at91rm9200/irq/irq.h, mc9328mxl/irq/irq.h, s3c2400/irq/irq.h:
Modified names and types to match rtems/irq.h. Note: rtems/irq.h
should be included after the addition of a parameter to ISRs.
* Makefile.am: Merge-in s3c2400/Makefile.am.
* preinstall.am: Regenerate.
* s3c2400/Makefile.am: Remove.
* configure.ac: Remove s3c2400/Makefile.
* Makefile.am: Merge-in mc9328mxl/Makefile.am.
* mc9328mxl/Makefile.am: Remove.
* configure.ac: Remove mc9328mxl/Makefile.
* Makefile.am: Merge-in at91rm9200/Makefile.am.
* at91rm9200/Makefile.am: Remove.
* configure.ac: Remove at91rm9200/Makefile.
* Makefile.am: Merge-in shared/Makefile.am.
* preinstall.am: New.
* shared/Makefile.am: Remove.
* mc9328mxl/irq/irq.c, s3c2400/irq/irq.c: Remove warnings.
* s3c2400/clock/clockdrv.c: Eliminate warning.
* Makefile.am, configure.ac: Added gp32 BSP.
* s3c2400/.cvsignore, s3c2400/Makefile.am, s3c2400/clock/clockdrv.c,
s3c2400/include/s3c2400.h, s3c2400/irq/bsp_irq_asm.S,
s3c2400/irq/bsp_irq_init.c, s3c2400/irq/irq.c, s3c2400/irq/irq.h,
s3c2400/timer/timer.c: New files.
* mc9328mxl/irq/irq.h: Fixed error in declaration of bsp_vector_table.
* at91rm9200/include/at91rm9200_emac.h: Cleanup.
* at91rm9200/Makefile.am, mc9328mxl/Makefile.am, shared/Makefile.am:
Eliminate CFLAGS_OPTIMIZE_V.
* at91rm9200/clock/clock.c, at91rm9200/irq/irq.c, at91rm9200/pmc/pmc.c,
mc9328mxl/clock/clockdrv.c, mc9328mxl/irq/irq.c, mc9328mxl/irq/irq.h,
shared/arm920/mmu.c: Remove warnings.
shared/Makefile.am: Remove build-variant support.
