* libc/newlibc.c: Removed _A29K specific ifdef.
* libc/Makefile.am: Include compile.am
* libio.c: Added O_NONBLOCK to list of flags.
all APIs.
* libc/fs_null_handlers.c: Added missing rmnod entry.
* libc/isatty.c, libc/imfs_handlers_directory.c, libc/creat.c,
libc/imfs_directory.c: Fixed style issues.
* libc/eval.c: Ditto.
* libc/fcntl.c: Ditto.
* libc/fsync.c: Ditto.
* libc/ioctl.c: Ditto.
* libc/ioman.c: Ditto.
* libc/link.c: Ditto.
* libc/memfile.c: Ditto.
* libc/mknod.c: Ditto.
* libc/symlink.c: Ditto.
-4 = {d = -4, i = {0xc0100000, 0x0}} s=1 e=0x80 m=0x100000 (0x0900000)
-3 = {d = -3, i = {0xc0080000, 0x0}} s=1 e=0x80 m=0x080000 (0x0880000)
-2 = {d = -2, i = {0xc0000000, 0x0}} s=1 e=0x80 m=0x000000 (0x0800000)
-1 = {d = -1, i = {0xbff00000, 0x0}} s=1 e=0x7f m=0x000000 (0x0800000)
0 = {d = 0, i = {0x00000000, 0x0}} s=0 e=0 m=0x000000 (0x0800000)
1 = {d = 1, i = {0x3ff00000, 0x0}} s=0 e=0x7f m=0x000000 (0x0800000)
2 = {d = 2, i = {0x40000000, 0x0}} s=0 e=0 m=0x000000 (0x0800000)
3 = {d = 3, i = {0x40080000, 0x0}} s=0 e=0 m=0x080000 (0x0880000)
C4X
-4 = {d = -4, i = {0x01800000, 0x0}} s=1 e=1 m=0x800000 (0x1000000)
-3 = {d = -3, i = {0x01c00000, 0x0}} s=1 e=1 m=0xa00000 (0x1400000)
-2 = {d = -2, i = {0x00800000, 0x0}} s=1 e=0 m=0x800000 (0x1000000)
-1 = {d = -1, i = {0xff800000, 0x0}} s=1 e=0xff m=0x000000 (0x1000000)
0 = {d = 0, i = {0x80000000, 0x0}} s=0 e=0 m=0x000000 (0x0800000)
1 = {d = 1, i = {0x00000000, 0x0}} s=0 e=0x7f m=0x000000 (0x0800000)
2 = {d = 2, i = {0x01000000, 0x0}} s=0 e=1 m=0x400000 (0x0800000)
3 = {d = 3, i = {0x01400000, 0x0}} s=0 e=1 m=0x600000 (0x0c00000)
4 = {d = 4, i = {0x02000000, 0x0}} s=0 e=2 m=0xXXXXXX (0x0000000)
0x1010 0000
0101 0000
0010 1002
the correct circumstances of DMA buffer size, serial
line interrupts, and ethernet interrupts the termios osend routine would
lock up waiting for the raw output buffer semaphore.
read function in the IMFS properly returns the inode number.
stat()'ing a symbolic link. This is needed to support the port
of the BSD commands like ls to RTEMS.
functionality to libc and update TODO.
ttyHead back link is set.
Jennifer Averett <jennifer.averett@oarcorp.com> to fix
appends (O_APPEND at open time) on in-memory files.
A call such as:
fd = open (file, O_APPEND | O_WRONLY);
did not append to the end of the file.
Jennifer Averett <jennifer.averett@oarcorp.com> to make sure
"/" is created with S_IFDIR set.
of all FIO constants and conflict with libnetworking code.
significant things:
and PowerPC
same code base.
Java folks including Oscar Martinez de la Torre <omt@wm.estec.esa.nl>.
that contains:
* Removes MKLIB
handling)
converted to automake.
Removed times() since the version in the C Library support code is
fine.
was made in the conversion of bcopy() to strncpy().
