path: root/c/src/lib/libbsp (follow)
* sparc64 niagara, usiii: Remove -D options from cfg file and move to bspopts.hJoel Sherrill2018-05-092-1/+13
| | | | Updates #3425.
* smdk2410: Move define of CPU_S3C2410 to bspopts.hJoel Sherrill2018-05-091-2/+5
| | | | Updates #3425.
* bsp/pc386: Remove bin2boot supportSebastian Huber2018-04-276-833/+0
| | | | | Update #3408. Close #3410.
* bsp/mcf5206elite: Do not install runtest scriptSebastian Huber2018-04-265-399/+0
| | | | | | | Provide the runtest script only as a part of the sources. This simplifies the build system. Test support should be included in the RTEMS Tester.
* bsps: Move documentation, etc. files to bspsSebastian Huber2018-04-26127-12218/+0
| | | | | | This patch is a part of the BSP source reorganization. Update #3285.
* bsps: Remove unmaintained times filesSebastian Huber2018-04-264-765/+0
* bsp/sparc64: Move asm.S to bsps and renameSebastian Huber2018-04-263-19/+2
* bsps/mips: Move liblnk to bspsSebastian Huber2018-04-265-248/+6
* bsps/powerpc: Move bsp-start-zero.S to bspsSebastian Huber2018-04-265-119/+4
* bsp/psim: Move align_h.S to bspsSebastian Huber2018-04-262-440/+1
* bsp/haleakala: Move assembler files to bspsSebastian Huber2018-04-263-322/+2
* bsp/qemuppc: Install linkcmds.baseSebastian Huber2018-04-251-0/+1
| | | | | Update #3339. Close #3411.
* bsps/arm: Remove unused filesSebastian Huber2018-04-2513-17990/+0
* bsps: Remove unused u-boot-generic-board-info.hSebastian Huber2018-04-251-132/+0
* bsp/beagle: Move source files to bspsSebastian Huber2018-04-255-1621/+4
* bsp/gumstix: Move fb.c to bspsSebastian Huber2018-04-252-240/+1
* bsp/lm3s69xx: Move ssi.c to bspsSebastian Huber2018-04-252-171/+1
* bsp/lpc176x: Move source files to bspsSebastian Huber2018-04-2513-2426/+13
* bsp/lpc24xx: Move source files to bspsSebastian Huber2018-04-2510-1963/+9
* bsp/lpc32xx: Move source files to bspsSebastian Huber2018-04-2512-1239/+11
* bsp/raspberrypi: Move source files to bspsSebastian Huber2018-04-257-1591/+4
* bsp/smdk2410: Move smc.c to bspsSebastian Huber2018-04-252-411/+1
* bsp/tms570: Move cpucounterread.c to bspsSebastian Huber2018-04-252-63/+1
* bsp/mcf5206elite: Move nvram.c to bspsSebastian Huber2018-04-252-174/+1
* bsp/mrm332: Move interr.c to bspsSebastian Huber2018-04-251-50/+0
* bsp/mrm332: Move spinit.c to bspsSebastian Huber2018-04-252-97/+1
* bsp/gen5200: Move source files to bspsSebastian Huber2018-04-257-3129/+4
* bsp/haleakala: Move mmu_405.c to bspsSebastian Huber2018-04-252-294/+1
* bsp/beatnik: Move source files to bspsSebastian Huber2018-04-258-2721/+4
* bsp/mvme3100: Move flashcfg.c to bspsSebastian Huber2018-04-252-117/+1
* bsp/mvme5500: Move source files to bspsSebastian Huber2018-04-254-545/+3
* bsp/virtex5: Move mmu.c to bspsSebastian Huber2018-04-252-582/+1
* bsp/virtex4: Move mmu.c to bspsSebastian Huber2018-04-252-568/+1
* bsp/gensh4: Move hw_init.c to bspsSebastian Huber2018-04-252-284/+1
* bsps: Move arm-cp15-set-ttb-entries.c to bspsSebastian Huber2018-04-2410-98/+9
* bsps: Move arm-cp15-set-exception-handler.c to bspsSebastian Huber2018-04-249-64/+8
* bsps: Move arm-a9mpcore-smp.c to bspsSebastian Huber2018-04-245-74/+4
* bsps: Move arm-pl050.c to bspsSebastian Huber2018-04-242-117/+1
* bsps: Move arm-pl011.c to bspsSebastian Huber2018-04-242-92/+1
* bsps: Move arm-pl111-fb.c to bspsSebastian Huber2018-04-243-278/+2
* bsps: Move arm-generic-timer-clock-config.c to bspsSebastian Huber2018-04-242-203/+1
* bsps: Move arm-a9mpcore-clock-config.c to bspsSebastian Huber2018-04-244-215/+3
* bsps: Move armv7m-cpucounter.c to bspsSebastian Huber2018-04-242-54/+1
* bsps: Move bspreset.c to bspsSebastian Huber2018-04-245-42/+4
* bsps/i386: Move shared files to bspsSebastian Huber2018-04-2411-4283/+8
* bsps/m68k: Remove unused filesSebastian Huber2018-04-242-109/+0
* bsps: Move spansionFlash.c to bspsSebastian Huber2018-04-242-478/+1
* bsps: Move intelFlash.c to bspsSebastian Huber2018-04-242-465/+1
* bsps: Move flash.c to bspsSebastian Huber2018-04-243-911/+2
* bsps: Move vpd.c to bspsSebastian Huber2018-04-243-324/+2
