* ChangeLog: New file.
* network/network.c: Fix to account for return value when
installing interrupts handler.
* startup/linkcmds: Modified to work better with gcc 2.8.1 and
gnat 3.13p.
* include/Makefile.am: Include coverhd.h so tmtests will compile.
* include/bsp.h: Disabled redefinition of
CONSOLE_DRIVER_TABLE_ENTRY. Some "FIXME:" comments added.
* console/config.c: New file. Definitions of externs referenced
from libbsp/shared/console.c.
* console/Makefile.am: Changed VPATH to point to
libbsp/shared. Added config.c to C_FILES and EXTRA_DIST.
* comm/tty_drv.c, comm/uart.c: Correct some minor cut and paste bugs.
* clock/clock.c: Ensure that clock ticks are long enough to
make forward progress. This was modified to improve results
on the RTEMS tests and the ACATS.
gnat 3.13p.
* tools/runtest.in: Recognize debug variant of monitor test.
gnat 3.13p.
* comm/tty_drv.c, comm/uart.c, comm/uart.h: Adds the capability
to use task driven serial I/O to ti386 BSPs. This patch leaves thex
default I/O mode to be IRQ. If you want to use task I/O mode,
then the tty_drv.c file needs to be modified. Basically, all
you need to change is the data values of the termios callbacks
structure. This callback structure is used in the tty1_open
and tty2_open functions. The values you need to set are commented
out in the source code.
* console/Makefile.am: Remove RTEMS_H_FILES.
* start/start16.S: include <bspopts.h> to get NEW_GAS.
* scitab/Makefile.am: Use @CPU_CLOCK_RATE_HZ@.
* comm/Makefile.am: Use *_HEADERS instead of *H_FILES.
* io/Makefile.am: Ditto.
* irq/Makefile.am: Ditto.
* pci/Makefile.am: Ditto.
* 3c509/Makefile.am: Dito.
* console/Makefile.am: Dito.
* start/start.S: Reverse sense of conditional compilation so the
code will compile for a cpu32.
* include/Makefile.am: Fixed typo.
* scitab/Makefile.am, startup/Makefile.am: Use CPU_CLOCK_RATE_HZ as
it is called in configure.in instead of HZ.
* configure.in: Correct typo.
* consolex/Makefile.am: Ditto.
* include/Makefile.am: Fix typo in include_HEADERS.
* configure.in: Remove CONSOLE_USE_POLLED, HAS_RTC.
* configure.in: Add bspopts.h, fix PACKAGE.
* include/.cvsignore: Add bspopts.h*, stamp-h*, coverhd.h.
* console/console.c, include/commproc.h, startup/start.S:
The printk/printf did not work when loaded by EPPCBUG. They did
work when loaded with the BDM debugger. I suspected EPPBUG
made some nasty things like patching Communication processor
microcode... Anyway, the attached patch:
1) Enables to have printk nearly immediately after boot,
2) Make printf work automagically (I do not know why except I make a
different initialization for printk that should be overwritten by
console init later ?)
I let the default to be using EPPCBUG embedded firmware to boot and
using this printk early enabler code (LOADED_BY_EPPCBUG and
EARLY_CONSOLE) are on.
* clock/Makefile.am, console/Makefile.am, spurious/Makefile.am,
wrapup/Makefile.am: Modified to include compile.am.
* startup/bspstart.c: Removed include of <libcsupport.h>
* include/.cvsignore: Add bspopts.h*, coverhd.h, stamp-h*.
* include/Makefile.am: Use *_HEADERS instead of *H_FILES, add
bspopts.h.
* include/.cvsignore: Add bspopts.h.
* include/bsp.h: Add bspopts.h.
* console/Makefile.am: Use *_HEADERS instead of H_FILES.
* .cvsignore, ChangeLog Makefile.am, README, bsp_specs,
clock/.cvsignore, clock/Makefile.am, clock/ckinit.c, configure.in,
console/.cvsignore, console/Makefile.am, console/console.c,
include/mrm332.h, misc/dotests, misc/gdbinit68, misc/interr.c,
spurious/.cvsignore, spurious/Makefile.am, spurious/spinit.c,
start/.cvsignore, start/Makefile.am, start/start.c, startup/.cvsignore,
startup/Makefile.am, startup/bspclean.c, startup/bspstart.c,
startup/except_vect_332_ROM.S, startup/linkcmds, startup/linkcmds_ROM,
timer/.cvsignore, timer/Makefile.am, timer/timer.c, times,
wrapup/.cvsignore, wrapup/Makefile.am: Initial files.
* start/start.S: Increased BAT0 mapping of RAM from 64 meg to
256 meg to allow operation on boards with larger RAM sizes.
* vectors/vectors_init.c: Modified to call 'generic' powerpc
vector function (mpc60x_vector_is_valid) instead of MPC750
specific function to allow operation on boards with CPUs other
than the MPC750.
* start/Makefile.am: Dito.
* network/Makefile.am: Dito.
* configure.in: remove shared/io/Makefile.
* configure.in: Add include/bspopts.h.
* console/Makefile.am: Use *_HEADERS instead of *H_FILES.
* irq/Makefile.am: Use *_HEADER instead of *H_FILES.
* include/Makefile.am: Add bspopts.h, Use *_HEADER instead of *H_FILES.
* configure.in: Add bspopts.h, AC_DEFINE CONSOLE_USE_INTERRUPTS,
* include/.cvsignore: Add bspopts.h*, stamp-h*, coverhd.h, tod.h.
* include/Makefile.am: Use *_HEADERS instead of *H_FILES, New
treatment of tod.h, coverhd.h.
* include/bsp.h: Add include bspopts.h.
* Assisted in design and debug by Joel Sherrill <joel@OARcorp.com>.
* start/regs.S, start/start.S: Now works on Mongoose-V. Missed
in previous patch.
* clock/clockdrv.c, console/conscfg.c: Corrected.
* include/bsp.h: Support for tm27 and addition of CPU_CLOCK_RATE.
* startup/bspstart.c: Properly set initial status register and
pending interrupts.
* timer/timer.c: Works now.
* configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]), adapt
bspopts.h handling to other sh-BSPs.
* include/.cvsignore: Add stamp-h*, bspopts.h*.
* include/Makefile.am: Use include_HEADERS instead of H_FILES.
* startup/bspstart.c: Reworked, based on the amos BSP.
* configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]), add
bspopts.h.
* startup/bspstart.c: Replace HZ w/ CPU_CLOCK_RATE_HZ.
add bspopts.h.
