which fixes a couple of bugs in RTEMS's old style Makefile.ins, which
apparently were introduced by moving the start directories and not
having adapted the Makefile.ins.
patch -p1 < rtems-rc-19991203-10.diff
which ontains all what was left over from the other patches (Primarily
minor configuration cleanups).
patch -p1 < rtems-rc-19991203-9.diff
./bootstrap
John Mills <jmills@tga.com>.
I got tired of having strange clock rates (e.g. #define
CONFIGURE_MICROSECONDS_PER_TICK 52489) and drifting times-of-day with
the gen68360 BSP so I changed the way the programmable-interval clock
interrupt works. The new version will have some jitter in the intervals
between individual calls to the rtems_clock_tick routine, but the
long-term average will match the CONFIGURE_MICROSECONDS_PER_TICK
which adds automake support to libbsp/bare.
delay loop in this BSP. Here is his response to a question about
the patch:
Yes, or that other machine has a different chipset with different
timing requirements on enabling Gate 20. I am strongly suspecting
that it may some how related to the video card I am using (on my
old P-75 target it was plain PCI VGA, on my new one it is Diamond Stealth
3D 2000).
dec21140 drivers from the i386/pc386 and powerpc/mcp750 (all Motorola
PowerPC boards) and move the network driver to libchip. This driver
should work on all PCI based uses of this chip.
to consistently use $(EXEEXT).
<corsepiu@faw.uni-ulm.de>:
The patch below provides
before)
rtems-rc-19991123-rc-2.diff
Attention:
As part of this effort, the mpc750 libcpu code is now shared with the
ppc6xx.
ppc6xx.
ppc6xx.
Renamed file shmsupp/intr.c in some BSPs to shmsupp/cause_intr.c to
avoid conflict with rtems/src/intr.c (Classic API Interrupt Manager).
Addtional major bugs:
* the PACKHEX etc problem
* prevents the *.rels being removed inside the build-tree
* a typo which only shows for when MP is activated
* Alters some custom/*cfg files
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
1. SH-Port:
* Many files renamed.
applying VPATH.
2. SH1-Port
3. SH2-Port
* Merged
you don't mind).
to be able to boot the archives located in powerpc-rtems/c/mcp750/bin.
This information was provided by Eric Valette <valette@crf.canon.fr>
for RTEMS.
independently of a BSP.
BSP needs to be eliminated.
