it work.
scripts (make/rtems.cfg)
Testing:
and disabled.
is used based on whether C++ is enabled or disabled.
gcc-target-default.cfg
by newlib.
component.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
to lib/include.
be resolved.
only required in a multiprocessor system. It was replace by the MPCI
Receive Server. As a result, the CPU Table field for extra stack for
the SYSI task was changed to be extra stack for the MPCI Receive Server.
like signal dispatching.
+ variable length messages
+ named devices
+ debug monitor
resulted in no output when the output was redirected until this was done.
Redirection is important because runtest redirects test output.
Added support for numerous environment variables which make it easier
to run a multi-node system using a single executable and to tailor
the size of the workspace and heap.
the count to "1" to indicate availability.
Interrupt support was added.
Problem where newlib's errno "overrides" that set by system calls
was addressed.
Fixed bug which resulted in all nodes using the same semaphore although
an array of semaphores was allocated.
