* | 2006-07-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-07-11 | 1 | -0/+5 | |
| | | | | | * clock/ckinit.c, timer/timer.c: Make sure LEON3_Timer_Regs is initialized for the timer driver. | |||||
* | 2006-07-11 Jerry Needell <jerry.needell@unh.edu> | Joel Sherrill | 2006-07-11 | 1 | -0/+10 | |
| | | | | | | * ChangeLog, Makefile.am, clock/ckinit.c, include/amba.h, include/bsp.h: Merge SPARC updates from 4.6 branch. Original modifications by Gaisler Enterprises. | |||||
* | 2006-06-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-06-25 | 1 | -0/+4 | |
| | | | | * startup/linkcmds: Add .rela.dyn sections. | |||||
* | 2006-04-12 Konrad Eisele <konrad@gaisler.com> | Joel Sherrill | 2006-04-12 | 1 | -0/+4 | |
| | | | | * include/leon.h: Add LEON_INTERRUPT_EXTERNAL_1 define. | |||||
* | 2006-03-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-03-08 | 1 | -0/+4 | |
| | | | | * startup/linkcmds: Add .gnu.linkonce.b.* section. | |||||
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 1 | -0/+4 | |
| | | | | * startup/linkcmds: Add sections required by newer gcc versions. | |||||
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 1 | -0/+5 | |
| | | | | | * configure.ac: Remove explicit ampolish3 support (now in RTEMS_BSP_CONFIGURE). | |||||
* | 2006-01-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-10 | 1 | -0/+5 | |
| | | | | | * configure.ac: Add ampolish3 support. * Makefile.am: Add preinstall.am. | |||||
* | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-09 | 1 | -0/+10 | |
* leon_smc91111/leon_smc91111.c, README, timer/timer.c, startup/ithread.S, startup/setvec.c, startup/spurious.c, startup/linkcmds, startup/bspstart.c, console/console.c, console/debugputs.c, console/consolereserveresources.c, bsp_specs, amba/amba.c, gnatsupp/gnatsupp.c, include/coverhd.h, include/tm27.h, include/leon.h, include/bsp.h, include/amba.h, Makefile.am, configure.ac, times, leon_open_eth/leon_open_eth.c clock/ckinit.c: Backport from rtems-4-6-branch. |
