* startup/boardinit.S: Include <rtems/asm.h> instead of <asm.h>.
* console/console.c: Include <rtems/ringbuf.h> instead of <ringbuf.h>.
* clock/ckinit.c, console/console.c, console/debugputs.c,
erc32sonic/erc32sonic.c, include/bsp.h, include/erc32.h,
startup/setvec.c, startup/spurious.c, timer/timer.c: Convert to
using c99 fixed size types.
* Makefile.am: Merge-in clock/Makefile.am, erc32sonic/Makefile.am,
startup/Makefile.am, console/Makefile.am, gnatsupp/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am.
Use automake compilation rules.
* clock/Makefile.am, erc32sonic/Makefile.am, startup/Makefile.am,
console/Makefile.am, gnatsupp/Makefile.am, timer/Makefile.am,
wrapup/Makefile.am: Remove.
* startup/Makefile.am: Ditto.
* wrapup/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Add dirstamp support to preinstallation.
* erc32sonic/Makefile.am: Cosmetics.
* gnatsupp/Makefile.am: Cosmetics.
* start/Makefile.am: Cosmetics.
* erc32sonic/Makefile.am: Remove all-local: $(ARCH).
* gnatsupp/Makefile.am: Remove all-local: $(ARCH).
* clock/ckinit.c, console/console.c, console/consolereserveresources.c,
console/debugputs.c, include/bsp.h, include/coverhd.h,
include/erc32.h, startup/erc32mec.c, startup/setvec.c, timer/timer.c:
URL for license changed.
erc32sonic/Makefile.am: Reflect having moved automake.
gnatsupp/Makefile.am: Reflect having moved automake.
* startup/Makefile.am: Remove USE_INIT_FINI.
* erc32sonic/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* gnatsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* erc32sonic/Makefile.am: Use .$(OBJEXT) instead of .o.
* gnatsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
* startup/erc32mec.c: New file.
* startup/Makefile.am: Reflect above.
* include/erc32.h: Converted SCORE_EXTERN to extern.
* tools/runtest.in: Lengthened timeout on test runs.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* erc32sonic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* gnatsupp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* Makefile.am, configure.in, gnatsupp/Makefile.am,
gnatsupp/gnatsupp.c, include/Makefile.am, include/bsp.h,
start/Makefile.am, startup/Makefile.am, startup/setvec.c,
wrapup/Makefile.am:
* erc32sonic: New directory.
* erc32sonic/Makefile.am, erc32sonic/erc32sonic.c,
erc32sonic/.cvsignore: New files.
* include/erc32.h: New file.
* startup/boardinit.S: New file.
Big update of SPARC support for ERC32 and LEON.
Added support for ERC32 without floating point.
Added SONIC support as configured on Tharsys ERC32 board.
The bsp's share various code in the shared directory:
gnat-support, start-up code, etc.
To decrease the foot-print, I removed the 16 kbyte start-up
stack that was put in .bss and never reused once the system
was up. The stack is now put between the heap and the
workspace. To reclaim it, the user can do a rtems_region_extend
to merge the stack to the heap region once the system is up.
* clock/Makefile.am, console/Makefile.am, gnatsupp/Makefile.am,
are now in libcpu. This primarily required moving erc32 specific
information from score/cpu files to libcpu/sparc and the erc32 BSP.
converted to automake.
that converts the sparc directory to automake.
Ralf's note: The implementation of libbsp/sparc/* gives a nearly minimal
example of the new configuration scheme.
dependencies of "Makefile".
--enable-maintainer-mode.
+ interrupt masking correction
+ FPU rev.B workaround
+ minor erc32 related fixes
ncurses, and zlib for RTEMS.
to support a.out and ELF.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
getting the spurious trap handling to work required a couple more
fixes - I have attached a patch against rtems-4.0.0 with the
necessary changes. I also added functionality so that the
address of the trapped instruction is reported and in case of
a data access error, the data address is also reported.
is now correct enough where this is not necessary. This was in to
cover up the deficiencies in figuring out how much memory a GNAT/RTEMS
application required. There is a good stab at this now.
