for details.
* Makefile.am, configure.ac: runtest for this BSP obsoleted by
rtems-testing/sim-scripts support. Please use those scripts.
* tools/.cvsignore, tools/ChangeLog, tools/Makefile.am,
tools/configure.ac, tools/runtest.in: Removed.
PR 1729/cpukit
* Makefile.am, configure.ac: Add next step in SMP support. This adds an
allocated array of the Per_CPU structures to support multiple cpus vs
a single instance of the structure which is still used if SMP support
is disabled. Configuration support is also added to explicitly enable
or disable SMP. But SMP can only be enabled for the CPUs which will
support it initially -- SPARC and i386. With the stub BSP support, a
BSP can be run as a single core SMP system from an RTEMS data
structure standpoint.
* configure.ac: Remove AC_CHECK_SIZEOF([void *]).
* configure.ac: Added AC_CHECK_SIZEOF macro.
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* Makefile.am, configure.ac: Add capability for bootcard.c BSP
Initialization Framework to ask the BSP where it has memory for the
RTEMS Workspace and C Program Heap. These collectively are referred
to as work area. If the BSP supports this, then it does not have to
include code to split the available memory between the two areas.
This reduces the amount of code in the BSP specific bspstart.c file.
Additionally, the shared framework can initialize the C Library, call
rtems_debug_enable(), and dirty the work area memory. Until most/all
BSPs support this new capability, if the BSP supports this, it should
call RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac.
When the transition is complete, this autoconf macro can be removed.
* configure.ac: Remove explicit ampolish3 support (now in
RTEMS_BSP_CONFIGURE).
* configure.ac: Add ampolish3 support.
* Makefile.am: Add preinstall.am.
* configure.ac: Add configuration for ENABLE_SIS_QUIRKS.
* Makefile.am: Merge-in clock/Makefile.am, erc32sonic/Makefile.am,
startup/Makefile.am, console/Makefile.am, gnatsupp/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am.
Use automake compilation rules.
* clock/Makefile.am, erc32sonic/Makefile.am, startup/Makefile.am,
console/Makefile.am, gnatsupp/Makefile.am, timer/Makefile.am,
wrapup/Makefile.am: Remove.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
Reflect changes to bsp.am.
* configure.ac: Remove BSPOPTS_*(NO_TABLE_MOVE).
Remove BSPOPTS_*(FPU_REVB).
* wrapup/Makefile.am: Remove tbr.
* configure.ac: Add BSPOPTS_*(NO_TABLE_MOVE).
Add BSPOPTS_*(FPU_REVB).
* wrapup/Makefile.am: Add tbr.
* erc32sonic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* gnatsupp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: Add RTEMS_BSPOPTS*(CONSOLE_USE_INTERRUPTS).
Add RTEMS_BSPOPTS*(SIMSPARC_FAST_IDLE).
Remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* include/bsp.h: include bspopts.h.
* configure.in: Remove.
