* wrapup/Makefile: Use GENERIC_FILES = to make automake-1.5 happy.
* network/network.c: Fix to account for return value when
installing interrupts handler.
* startup/linkcmds: Modified to work better with gcc 2.8.1 and
gnat 3.13p.
* clock/clock.c: Ensure that clock ticks are long enough to
make forward progress. This was modified to improve results
on the RTEMS tests and the ACATS.
gnat 3.13p.
gnat 3.13p.
* include/Makefile.am: Fixed typo.
* configure.in: Remove CONSOLE_USE_POLLED, HAS_RTC.
* console/console.c, include/commproc.h, startup/start.S:
The printk/printf did not work when loaded by EPPCBUG. They did
work when loaded with the BDM debugger. I suspected EPPBUG
made some nasty things like patching Communication processor
microcode... Anyway, the attached patch:
1) Enables to have printk nearly immediately after boot,
2) Make printf work automagically (I do not know why except I make a
different initialization for printk that should be overwritten by
console init later ?)
I let the default to be using EPPCBUG embedded firmware to boot and
using this printk early enabler code (LOADED_BY_EPPCBUG and
EARLY_CONSOLE) are on.
* start/start.S: Increased BAT0 mapping of RAM from 64 meg to
256 meg to allow operation on boards with larger RAM sizes.
* vectors/vectors_init.c: Modified to call 'generic' powerpc
vector function (mpc60x_vector_is_valid) instead of MPC750
specific function to allow operation on boards with CPUs other
than the MPC750.
* configure.in: Add bspopts.h, AC_DEFINE CONSOLE_USE_INTERRUPTS,
* include/.cvsignore: Add bspopts.h*, stamp-h*, coverhd.h, tod.h.
* include/Makefile.am: Use *_HEADERS instead of *H_FILES, New
treatment of tod.h, coverhd.h.
* include/bsp.h: Add include bspopts.h.
* include/bsp.h: Added include of <bsp/vectors.h>
* vectors/vectors.h: Corrected typos.
* network/network.c: Fix unnecessary double assignment.
* clock/.cvsignore, clock/Makefile.am, clock/p_clock.c,
include/8xx_immap.h, include/commproc.h, irq/.cvsignore,
irq/Makefile.am, irq/irq.c, irq/irq.h, irq/irq_asm.S,
irq/irq_init.c, vectors/.cvsignore, vectors/Makefile.am,
vectors/vectors.S, vectors/vectors.h,
vectors/vectors_init.c: New file.
* Switch the eth_comm BSP to use the "new exception processing model."
* Makefile.am, configure.in, console/console.c,
include/Makefile.am, include/bsp.h, network/network.c,
startup/Makefile.am, startup/bspstart.c, startup/linkcmds,
wrapup/Makefile.am: Switch the eth_comm BSP to use the
* configure.in, motorola_powerpc/Makefile.am,
motorola_powerpc/configure.in: These modifications are in
support of switching the mpc8xx to the use the "new exception
processing model."
* Makefile.am, console/consoleIo.h, include/bsp.h:
These modifications are part of the conversion of the
mpc8xx CPU to the "new exception processing model."
* mpc8xx/exceptions/.cvsignore, mpc8xx/exceptions/Makefile.am,
mpc8xx/exceptions/asm_utils.S, mpc8xx/exceptions/raw_exception.c,
mpc8xx/exceptions/raw_exception.h: New files.
* configure.in, mpc6xx/mmu/bat.h, mpc8xx/Makefile.am,
mpc8xx/clock/clock.c,
mpc8xx/console-generic/console-generic.c,
mpc8xx/include/mpc8xx.h, mpc8xx/mmu/mmu.c,
new_exception_processing/cpu.h, shared/include/byteorder.h,
wrapup/Makefile.am: This is conversion of the
include/8xx_immap.h, include/commproc.h, include/mbx.h,
irq/.cvsignore, irq/Makefile.am, irq/irq.c, irq/irq.h,
irq/irq_asm.S, irq/irq_init.c, vectors/.cvsignore,
vectors/Makefile.am, vectors/vectors.S, vectors/vectors.h,
vectors/vectors_init.c: New files.
include/Makefile.am, network/network.c, startup/Makefile.am,
startup/bspstart.c, startup/imbx8xx.c, startup/linkcmds,
startup/mmutlbtab.c, startup/start.S, wrapup/Makefile.am:
The modifications to this BSP reflect the conversion of the
* mpc505/ictrl/Makefile.am, mpc6xx/clock/Makefile.am,
mpc6xx/exceptions/Makefile.am, mpc6xx/mmu/Makefile.am,
mpc8xx/include/Makefile.am, new_exception_processing/Makefile.am,
old_exception_processing/Makefile.am, pc403/ictrl/Makefile.am,
shared/include/Makefile.am, shared/src/Makefile.am:
Apply *_HEADERS instead of *H_FILES.
* shared/src/.cvsignore: Add cache.h.
* startup/genpvec.c: #include <chain.h> instead of "chain.h", fix
CVS-Id.
* include/chain.h: Remove.
* include/Makefile.am: Remove chain.h.
* startup/genpvec.c: #include <chain.h> instead of "chain.h".
* bootloader/Makefile.am: Modified to install bootloader so
make-exe rule can avoid writing to install point or assuming
BSP build tree is available.
* clock/clock.c: Use shared clock driver shell.
* console/console.c: Removed. Now use shared polling shell.
* console/console-io.c: New file.
* console/Makefile.am: Correct to use shared polling shell.
* startup/bspstart.c: Remove all fast idle references.
* new_exception_processing/cpu.h, old_exception_processing/cpu.c:
old_exception_processing/cpu.h, Added _CPU_Initialize_vectors().
In particular, spurious vector initialization had to be moved
on old exception processing model.
* timer/timer.c: Removed incorrect comments about ERC32.
* startup/bspstart.c, startup/bspstart.c: assoc.h, error.h, libio_.h,
libio.h, and libcsupport.h moved from libc to lib/include/rtems and
Also removed obsolete references to STACK_CHECKER_ON.
* startup/bspstart.c, startup/bspstart.c.nocache: assoc.h, error.h,
libio_.h, libio.h, and libcsupport.h moved from libc to
lib/include/rtems and now must be referenced as <rtems/XXX.h>.
Header file order was cleaned up while doing this.
* startup/bspstart.c: assoc.h, error.h, libio_.h, libio.h, and
* startup/82378zb.c, startup/FPGA.c: assoc.h, error.h, libio_.h,
* configure.in, Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros.
* console/console.c: Add mbx8xx_console_get_configuration() which
returns either nvram configuration or a static equivalent.
* Added full support for MPC505.
* mpc505/ictrl: New directory.
* configure.in, mpc505/Makefile.am: Modified to reflect ictrl addition.
* mpc505/ictrl/.cvsignore, mpc505/ictrl/Makefile.am,
mpc505/ictrl/ictrl.c, mpc505/ictrl/ictrl.h: New files.
* mpc505/timer/timer.c: Use <rtems.h>, not "rtems.h".
* mpc505/vectors/Makefile.am: alignment exception handler now included.
* mpc505/vectors/vectors.S: Now use constants for exception numbers.
* old_exception_processing/ppc_offs.h: New file.
* old_exception_processing/Makefile.am: Account for ppc_offs.h.
* old_exception_processing/cpu.h: Make Nest and Disable levels volatile.
* old_exception_processing/cpu_asm.S: Offsets moved to ppc_offs.h.
* console/console.c: Added BSP dependent routine
mbx8xx_console_use_maximum_buffer_size() required by mbx8xx
console-generic code. This avoids libcpu use of bsp.h.
* startup/linkcmds: Added lines so DWARF debug information
would be available. Otherwise gdb complains that the offsets
for the debug info are incorrect and doesn't load the files.
* mpc505/timer/Makefile.am, mpc505/vectors/Makefile.am,
mpc6xx/clock/Makefile.am, mpc6xx/exceptions/Makefile.am,
mpc6xx/mmu/Makefile.am, mpc6xx/timer/Makefile.am,
mpc6xx/wrapup/Makefile.am, ppc403/clock/Makefile.am,
ppc403/console/Makefile.am, ppc403/ictrl/Makefile.am,
ppc403/timer/Makefile.am, ppc403/vectors/Makefile.am,
shared/include/Makefile.am, shared/src/Makefile.am,
wrapup/Makefile.am, mpc8xx/clock/Makefile.am,
mpc8xx/console-generic/Makefile.am, mpc8xx/cpm/Makefile.am,
mpc8xx/mmu/Makefile.am, mpc8xx/timer/Makefile.am,
mpc8xx/vectors/Makefile.am, new_exception_processing/Makefile.am,
old_exception_processing/Makefile.am: Include compile.am
* start/start.S: Include proper files to compile.
* PCI_bus/Makefile.am, clock/Makefile.am, console/Makefile.am,
tod/Makefile.am, vectors/Makefile.am, wrapup/Makefile.am: Include
compile.am
vectors/Makefile.am, wrapup/Makefile.am: Include compile.am
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
nvram/Makefile.am, pci/Makefile.am, start/Makefile.am,
startup/Makefile.am, timer/Makefile.am, tod/Makefile.am,
universe/Makefile.am, vectors/Makefile.am, wrapup/Makefile.am:
Include compile.am
* dlentry/Makefile.am, flashentry/Makefile.am, startup/Makefile.am,
* bootloader/Makefile.am, clock/Makefile.am, console/Makefile.am,
irq/Makefile.am, motorola/Makefile.am, openpic/Makefile.am,
pci/Makefile.am, residual/Makefile.am, start/Makefile.am,
startup/Makefile.am, vectors/Makefile.am, wrapup/Makefile.am:
Include compile.am
* console/Makefile.am, network/Makefile.am, startup/Makefile.am,
* canbus/Makefile.am, console/Makefile.am, network/Makefile.am,
start/Makefile.am, startup/Makefile.am, wrapup/Makefile.am: Include
compile.am
