* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 13 | -29/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 2 | -0/+6 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 2 | -6/+0 |
* | General - Remove extraneous blank line in license message | Joel Sherrill | 2012-05-03 | 1 | -1/+0 |
| | | | | | | | | | | | | | Many files had an extra blank line in the license text found in the file header. This patch removes that line. * The license and distribution terms for this file may be * found in the file LICENSE in this distribution or at * * http://www.rtems.com/license/LICENSE. The script that did this also turned off execute permission when it was turned on incorrectly. | ||||
* | bsp/tqm8xx: Install header file <bsp/irq-info.h> | Sebastian Huber | 2012-04-02 | 2 | -0/+5 |
* | bsps: More accurate PowerPC clock driver | Sebastian Huber | 2012-04-02 | 1 | -2/+7 |
| | | | | | | The clock driver used previously the bsp_clicks_per_usec value. For a 33333333Hz time base frequency this leads to a relative error of one per cent for example due to integer truncation. | ||||
* | bsps: Add shared default IRQ handler | Sebastian Huber | 2012-03-24 | 2 | -8/+7 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 2 | -12/+0 |
* | 2011-06-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-06-18 | 2 | -1/+5 |
| | | | | * Makefile.am: Remove references to non-existing files. | ||||
* | 2011-06-07 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-06-07 | 3 | -17/+11 |
| | | | | * configure.ac, startup/bspstart.c: Use standard cache BSP options. | ||||
* | 2011-02-09 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-09 | 2 | -2/+8 |
| | | | | | * timer/timer.c: Include <rtems/btimer.h>. Fix benchmark_timer_read() definition. | ||||
* | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-02 | 2 | -2/+6 |
| | | | | * configure.ac: Require autoconf-2.68, automake-1.11.1. | ||||
* | 2010-08-03 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-08-03 | 2 | -1/+6 |
| | | | | * console/console.c: Add BSP_poll_char. | ||||
* | 2010-06-29 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-29 | 2 | -4/+4 |
| | | | | * configure.ac: Remove AC_CHECK_SIZEOF([void *]). | ||||
* | 2010-06-29 Joel Sherrill <Joel.Sherrill@OARcorp.com> | Jennifer Averett | 2010-06-29 | 2 | -0/+8 |
| | | | | * configure.ac: Added AC_CHECK_SIZEOF macro. | ||||
* | 2010-04-30 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-04-30 | 5 | -108/+12 |
| | | | | | | * include/irq-config.h: Removed file. * Makefile.am, preinstall.am: Reflect change above. * include/irq.h: Moved defines from 'include/irq-config.h'. | ||||
* | tqm8xx BSP fixes | Thomas Doerfler | 2010-01-19 | 6 | -93/+235 |
* | adapted to new prototype for *_write function | Thomas Doerfler | 2009-12-17 | 2 | -5/+11 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 13 | -174/+174 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-28 | 1 | -17/+17 |
* | Regenerate. | Ralf Corsepius | 2009-11-07 | 1 | -4/+4 |
* | 2009-11-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-11-06 | 4 | -5/+10 |
| | | | | | | * configure.ac: Add RTEMS_BSP_LINKCMDS. * Makefile.am: Rework linkcmds handling. * make/custom/tqm8xx.inc: Remove RTEMS_LINKCMDS, LDFLAGS. | ||||
* | Fix broken entries. | Ralf Corsepius | 2009-11-06 | 1 | -2/+2 |
* | various PowerPC code maintenance | Thomas Doerfler | 2009-11-03 | 3 | -28/+42 |
* | move timebase access functions from cpukit to libcpu | Thomas Doerfler | 2009-10-30 | 2 | -1/+5 |
* | Fix broken formating. | Ralf Corsepius | 2009-10-23 | 1 | -1/+2 |
* | 2009-10-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-23 | 1 | -0/+5 |
| | | | | | * console/console.c: Include <rtems/error.h>. * spi/spi.c: Remove m8xx_spi_softc_ptr (Unused). | ||||
* | Remove m8xx_spi_softc_ptr (Unused). | Ralf Corsepius | 2009-10-23 | 1 | -1/+1 |
* | Include <rtems/error.h>. | Ralf Corsepius | 2009-10-23 | 1 | -1/+1 |
* | Update for exception support changes. | Thomas Doerfler | 2009-10-23 | 5 | -26/+28 |
* | various maintenance changes | Thomas Doerfler | 2009-10-21 | 3 | -0/+999 |
* | interrupt handler type change | Thomas Doerfler | 2009-10-21 | 9 | -111/+74 |
* | 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-21 | 2 | -3/+4 |
| | | | | * make/custom/tqm8xx.inc: Remove RTEMS_BSP_FAMILY. | ||||
* | 2009-10-20 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-20 | 2 | -1/+5 |
| | | | | * configure.ac: Don't add -ansi -fasm to CFLAGS. | ||||
* | 2009-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-17 | 4 | -2/+9 |
| | | | | | | | * make/custom/tqm8xx.inc: New (Renamed from tqm8xx.cfg). * make/custom/tqm8xx.cfg: Removed. * make/custom/pghplus.cfg, make/custom/tqm8xx_stk8xx.cfg: Include make/custom/tqm8xx.inc. | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+14 |
| | | | | * make/custom/pghplus.cfg: New (relocated from /make/custom). | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 3 | -0/+42 |
| | | | | | * make/custom/tqm8xx.cfg: New (relocated from /make/custom). * make/custom/tqm8xx_stk8xx.cfg: New (relocated from /make/custom). | ||||
* | 2009-09-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-15 | 2 | -2/+5 |
| | | | | * configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS. | ||||
* | 2009-09-09 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-09-10 | 3 | -54/+10 |
| | | | | | | PR 1435/bsps * Makefile.am: Use shared implementation of bsp_idle_thread(). * startup/bspidle.c: Removed. | ||||
* | 2009-08-26 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-08-26 | 4 | -26/+58 |
| | | | | | | * Makefile.am, startup/bspstart.c: Rename BSP specific idle thread to bsp_idle_thread and split into its own file. * startup/bspidle.c: New file. | ||||
* | 2009-08-07 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-08-07 | 2 | -0/+9 |
| | | | | | * console/console.c: Disable call to rtems_interrupt_catch until it is fixed. | ||||
* | 2009-07-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-07-16 | 2 | -1/+8 |
| | | | | | | * configure.ac: Rename BSP_BOOTCARD_OPTIONS to RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs have the same options. | ||||
* | 2009-05-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-05-08 | 2 | -4/+10 |
| | | | | | | * startup/bspgetworkarea.c: Switch from ssize_t to uintptr_t for bsp_get_work_area() since the work area is larger than a single allocatable object. | ||||
* | 2009-04-28 Chris Johns <chrisj@rtems.org> | Chris Johns | 2009-04-28 | 2 | -2/+9 |
| | | | | * startup/start.S: Update for boot_card command line change. | ||||
* | 2009-03-09 Sebastian Huber <sebastian.huber@embedded-brains.de> | Joel Sherrill | 2009-03-09 | 2 | -0/+6 |
| | | | | * include/bsp.h: Added missing include. | ||||
* | 2009-02-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-12 | 2 | -1/+6 |
| | | | | | * startup/bspstart.c: Change prototype of IDLE thread to consistently return void * and take a uintptr_t argument. | ||||
* | 2009-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-11 | 2 | -1/+6 |
| | | | | | * bsp_specs: Remove stray % from '*startfile:' having crept in previous change. | ||||
* | 2008-12-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-12-05 | 2 | -2/+5 |
| | | | | * bsp_specs: Cosmetics. | ||||
* | 2008-12-04 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-12-04 | 2 | -2/+9 |
| | | | | | | * bsp_specs: Move -e start from *link to *startfile to avoid warning for undefined entry symbol when linking relocatables with binutils 2.19. | ||||
* | 2008-12-04 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-12-04 | 2 | -4/+8 |
| | | | | | * bsp_specs: Remove -e start from %link. Remove start_g.o. |
