* old_exception_processing/cpu.h: Renamed delay() to rtems_bsp_delay().
Renamed delay_in_bus_cycles() to rtems_bsp_delay_in_bus_cycles().
* shared/include/cpu.h: Renamed delay() to rtems_bsp_delay().
* new_exception_processing/Makefile.am: Use 'PREINSTALL_FILES ='.
* old_exception_processing/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/mmu/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/clock/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/exceptions/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc8xx/include/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc8xx/exceptions/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/include/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/src/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/src/Makefile.am: Use 'CLEANFILES ='.
* mpc505/ictrl/Makefile.am, mpc6xx/clock/Makefile.am,
mpc6xx/exceptions/Makefile.am, mpc6xx/mmu/Makefile.am,
mpc8xx/include/Makefile.am, new_exception_processing/Makefile.am,
old_exception_processing/Makefile.am, pc403/ictrl/Makefile.am,
shared/include/Makefile.am, shared/src/Makefile.am:
Apply *_HEADERS instead of *H_FILES.
* shared/src/.cvsignore: Add cache.h.
* new_exception_processing/cpu.h, old_exception_processing/cpu.c:
old_exception_processing/cpu.h, Added _CPU_Initialize_vectors().
In particular, spurious vector initialization had to be moved
on old exception processing model.
* Added full support for MPC505.
* mpc505/ictrl: New directory.
* configure.in, mpc505/Makefile.am: Modified to reflect ictrl addition.
* mpc505/ictrl/.cvsignore, mpc505/ictrl/Makefile.am,
mpc505/ictrl/ictrl.c, mpc505/ictrl/ictrl.h: New files.
* mpc505/timer/timer.c: Use <rtems.h>, not "rtems.h".
* mpc505/vectors/Makefile.am: alignment exception handler now included.
* mpc505/vectors/vectors.S: Now use constants for exception numbers.
* old_exception_processing/ppc_offs.h: New file.
* old_exception_processing/Makefile.am: Account for ppc_offs.h.
* old_exception_processing/cpu.h: Make Nest and Disable levels volatile.
* old_exception_processing/cpu_asm.S: Offsets moved to ppc_offs.h.
* mpc505/timer/Makefile.am, mpc505/vectors/Makefile.am,
mpc6xx/clock/Makefile.am, mpc6xx/exceptions/Makefile.am,
mpc6xx/mmu/Makefile.am, mpc6xx/timer/Makefile.am,
mpc6xx/wrapup/Makefile.am, ppc403/clock/Makefile.am,
ppc403/console/Makefile.am, ppc403/ictrl/Makefile.am,
ppc403/timer/Makefile.am, ppc403/vectors/Makefile.am,
shared/include/Makefile.am, shared/src/Makefile.am,
wrapup/Makefile.am, mpc8xx/clock/Makefile.am,
mpc8xx/console-generic/Makefile.am, mpc8xx/cpm/Makefile.am,
mpc8xx/mmu/Makefile.am, mpc8xx/timer/Makefile.am,
mpc8xx/vectors/Makefile.am, new_exception_processing/Makefile.am,
old_exception_processing/Makefile.am: Include compile.am
were needed to move exception processing to score/cpu.
from score/cpu to libcpu because the determination of which to use is
based on RTEMS_CPU_MODEL. Thus it can not be determined based solely on
multilib information.
_Interrupt_Manager_initialization.
significant things:
and PowerPC
same code base.
<corsepiu@faw.uni-ulm.de>:
The patch below provides
before)
rtems-rc-19991123-rc-2.diff
Attention:
As part of this effort, the mpc750 libcpu code is now shared with the
ppc6xx.
