* Makefile.am, preinstall.am: Use shared stub coverhd.h
* include/coverhd.h: Removed.
* Makefile.am: Eliminate bsp.am.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Remove noinst_PROGRAMS (Unused).
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* Makefile.am, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* startup/bspgetworkarea.c: Removed.
* Makefile.am, configure.ac, startup/bspstart.c, startup/linkcmds: Add
use of bsp_get_work_area() in its own file and rely on BSP Framework
to perform more initialization.
* startup/bspgetworkarea.c: New file.
* Makefile.am: Rework to avoid .rel files.
* Makefile.am, startup/bspstart.c: Moved most of the remaining CPU
Table fields to the Configuration Table. This included
pretasking_hook, predriver_hook, postdriver_hook, idle_task,
do_zero_of_workspace, extra_mpci_receive_server_stack,
stack_allocate_hook, and stack_free_hook. As a side-effect of this
effort some multiprocessing code was made conditional and some style
clean up occurred.
* Makefile.am: Merge c_rtems_main() into boot_card(). This eliminated a
file and simplified initialization.
* configure.ac: Add ampolish3 support.
* Makefile.am: Add preinstall.am.
* Makefile.am: Don't include subdirs.am.
* Makefile.am: Merge-in wrapup/Makefile.am.
* wrapup/Makefile.am: Remove.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am, wrapup/Makefile.am: Remove build-variant support.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
PR 611/bsps
* Makefile.am, include/bsp.h, wrapup/Makefile.am: Follow conventions
for tm27 and do not add another macro definition.
* startup/tm27supp.c: New file.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
times, clock/p_clock.c, console/console.c, include/.cvsignore,
include/bsp.h, include/coverhd.h, irq/irq.h, startup/bspstart.c,
startup/iss555.c, startup/linkcmds, startup/start.S,
wrapup/.cvsignore, wrapup/Makefile.am: New files.
