* beatnik/include/bsp.h, beatnik/irq/irq.h, beatnik/pci/gt_pci_init.c,
ep1a/console/polled_io.c, ep1a/irq/openpic_xxx_irq.c,
gen5200/include/irq.h, gen5200/irq/irq.c, gen5200/startup/bspstart.c,
haleakala/irq/irq.c, mbx8xx/irq/irq.c, mbx8xx/irq/irq.h,
motorola_powerpc/include/bsp.h, mpc8260ads/irq/irq.c,
mpc8260ads/irq/irq.h, mvme3100/include/bsp.h, mvme3100/irq/irq.h,
mvme3100/start/start.S, mvme5500/include/bsp.h, mvme5500/irq/irq.h,
psim/include/bsp.h, psim/include/coverhd.h, psim/irq/irq.h,
psim/shmsupp/addrconv.c, psim/shmsupp/getcfg.c,
psim/startup/linkcmds, psim/tools/psim-gdb-top.in,
psim/tools/psim-top.in, psim/tools/runtest-top.in, qemuppc/irq/irq.h,
score603e/irq/irq.c, shared/bootloader/bootldr.h,
shared/bootloader/em86.c, shared/bootloader/em86real.S,
shared/bootloader/exception.S, shared/bootloader/head.S,
shared/bootloader/lib.c, shared/bootloader/misc.c,
shared/bootloader/mm.c, shared/bootloader/pci.c,
shared/console/console.c, shared/console/consoleIo.h,
shared/console/inch.c, shared/console/keyboard.h,
shared/console/polled_io.c, shared/irq/i8259.c, shared/irq/irq.h,
shared/irq/openpic_i8259_irq.c, shared/motorola/motorola.c,
shared/motorola/motorola.h, shared/openpic/openpic.c,
shared/openpic/openpic.h, shared/pci/pci.c,
shared/residual/residual.c, shared/start/start.S, ss555/irq/irq.h:
Fix typo where license said found in found in.
PR 1573/cpukit
* irq/irq.c: Add a per cpu data structure which contains the
information required by RTEMS for each CPU core. This encapsulates
information such as thread executing, heir, idle and dispatch needed.
* irq/irq.h, startup/bspstart.c: Remove warnings.
* Makefile.am, configure.ac, preinstall.am, PCI_bus/PCI.c,
PCI_bus/PCI.h, PCI_bus/flash.c, PCI_bus/universe.c, console/85c30.c,
console/85c30.h, console/console.c, console/consolebsp.h,
console/tbl85c30.c, include/bsp.h, include/gen2.h,
include/irq-config.h, include/tm27.h, irq/FPGA.c, irq/irq.h,
irq/irq_init.c, start/start.S, startup/Hwr_init.c,
startup/bspstart.c, startup/linkcmds, timer/timer.c, tod/tod.c,
vme/VMEConfig.h: Updated and tested with latest interrupt source.
Modified with latest memory allocation, but this needs testing.
* irq/no_pic.c: New file.
* irq/irq.c: Add bsp_interrupt_handler_default() so this BSP will link.
* PCI_bus/PCI.c, PCI_bus/PCI.h, PCI_bus/flash.c, console/85c30.h,
console/console.c, console/consolebsp.h, console/tbl85c30.c,
include/gen2.h, irq/FPGA.c, irq/irq.c, irq/irq.h, irq/irq_init.c,
pci/no_host_bridge.c, startup/bspclean.c, startup/bspstart.c,
startup/genpvec.c, startup/vmeintr.c: File head clean up.
* Makefile.am, preinstall.am, PCI_bus/universe.c, console/console.c,
include/bsp.h, irq/FPGA.c, irq/irq.c, startup/Hwr_init.c,
startup/bspstart.c, startup/vmeintr.c: Modifications required to run
on hardware. Some cleanup.
* irq/FPGA.c: Remove unnecessary includes of rtems/libcsupport.h and
rtems/libio.h.
* Makefile.am, README, configure.ac, console/85c30.c,
console/console.c, console/consolebsp.h, include/bsp.h,
start/start.S, startup/bspstart.c, startup/genpvec.c,
startup/linkcmds, timer/timer.c, tod/tod.c: Initiate update and
testing. Runs hello but does not run ticker yet.
* ep1a/irq/irq.c, gen5200/irq/irq.c, gen83xx/irq/irq_init.c,
mbx8xx/irq/irq.c, mpc8260ads/irq/irq.c, mvme5500/irq/irq.c,
psim/irq/no_pic.c, score603e/irq/irq.c, shared/irq/irq_supp.h,
shared/irq/openpic_i8259_irq.c, virtex/irq/irq_init.c:
let C_dispatch_irq_handler() return zero to indicate to
low-level exception handling code that the exception
was handled (not used yet).
* irq/irq.h, irq/irq_init.c: Removed the definition
of ASM_IRQ_VECTOR_BASE; this symbol was only use to
initialize the irqBase member of the rtems_irq_global_settings
struct. However, irqBase is an rtems_irq_symbolic_name,
so using BSP_LOWEST_OFFSET is more appropriate.
* ep1a/irq/irq.c, gen5200/irq/irq.c, mbx8xx/irq/irq.c,
mpc8260ads/irq/irq.c, mvme5500/irq/irq.c, psim/irq/irq.c,
score603e/irq/irq.c, shared/irq/irq.c:
test for non-NULL-ness before calling 'on'/'off'
methods so that users don't have to provide
no-ops if they don't want this feature.
* PCI_bus/universe.c, console/console.c, include/bsp.h, irq/FPGA.c,
startup/bspstart.c, startup/genpvec.c, startup/spurious.c: Eliminate
DEBUG_puts.
PR 1257/bsps
* irq/irq.c: Code outside of cpukit should use the public API for
rtems_interrupt_disable/rtems_interrupt_enable. By bypassing the
public API and directly accessing _CPU_ISR_Disable and
_CPU_ISR_Enable, they were bypassing the compiler memory barrier
directive which could lead to problems. This patch also changes the
type of the variable passed into these routines and addresses minor
style issues.
* vme/vmeconfig.c (removed), vme/VMEConfig.h (added):
cleaned up vme support - use files from libbsp/powerpc/shared/vme
and define BSP specifica in VMEConfig.h.
Use VME DMA support implemented by vmeUniverse and
libbsp/powerpc/shared/vme/vme_universe_dma.c
* irq/irq.c, include/gen2.h:
removed _BSP_vme_bridge_irq variable and BSP_PIC_DO_EOI definition.
Support for VME IRQ software priorities was incomplete/incorrect
on this BSP.
* irq/irq.c, irq/irq.h: Modified to use rtems/irq.h.
* irq/irq_init.c: Name change to support common PCI interface
* Add/move files for the Update to new exception model.
NOTE: These modifications have not been tested on hardware.
* irq/FPGA.c, irq/irq.c, irq/irq.h, irq/irq_init.c: New files.
* startup/FPGA.c: Removed.
