Add and use _CPU_SMP_Start_processor(). Add and use
_CPU_SMP_Finalize_initialization(). This makes most
_CPU_SMP_Initialize() functions a bit simpler since we can calculate the
minimum value of the count of processors requested by the application
configuration and the count of physically or virtually available
processors in the high-level code.
The CPU port has now the ability to signal a processor start failure.
With the support for clustered/partitioned scheduling the presence of
particular processors can be configured to be optional or mandatory.
There will be a fatal error only in case mandatory processors are not
present.
The CPU port may use a timeout to monitor the start of a processor.
Rename rtems_smp_process_interrupt() into
_SMP_Inter_processor_interrupt_handler(). Delete unused header file
<rtems/bspsmp.h>.
Rename rtems_smp_secondary_cpu_initialize() into
_SMP_Start_multitasking_on_secondary_processor(). Move declaration to
<rtems/score/smpimpl.h>.
Since the per-CPU SMP lock must be acquired and released to send the
message a single interrupt broadcast operations offers no benefits. If
synchronization is required, then a SMP barrier must be used anyway.
Rename bsp_smp_initialize() into _CPU_SMP_Initialize() since every CPU
port must supply this function.
Instead of SPRG0 (= special purpose register 272) use the new global
symbol _PPC_INTERRUPT_DISABLE_MASK to store the interrupt disable mask.
The benefit is that it is now possible to disable interrupts without
further run-time initialization in boot_card().
At least on Freescale e500 cores this leads also to a faster execution
since the mfmsr and mfspr instruction require four cycles to complete.
The instructions to load the mask value can execute while the mfmsr is
in progress.
This requires at least Binutils 2.24.
Add and use _Per_CPU_Get_by_index() and _Per_CPU_Get_index(). Add
_Per_CPU_Send_interrupt(). This avoids direct access of
_Per_CPU_Information.
Delete bsp_smp_interrupt_cpu().
Add and use _SMP_Get_current_processor() and
rtems_smp_get_current_processor().
Change type of current processor index from int to uint32_t to match
_SMP_Processor_count type.
Termios notifies now the driver about an inactive transmit with the
length argument set to zero.
Delete ppc_exc_vector_base. Add and use
ppc_exc_initialize_with_vector_base().
In case the VMA and LMA regions differ, the LMA start address is now no
longer aligned with the alignment of the input sections:
http://sourceware.org/bugzilla/show_bug.cgi?id=15222
Conflicts:
Replace the "NIRVANA" region with the more verbose "UNEXPECTED_SECTIONS"
region. Move the region definition into the "linkcmds.base" files.
New BSP option BSP_USE_DATA_CACHE_BLOCK_TOUCH.
for details.
The clock driver used previously the bsp_clicks_per_usec value. For a
33333333Hz time base frequency this leads to a relative error of one per
cent for example due to integer truncation.
* make/custom/qoriq.inc: Remove -W* flags.
PR 1926/bsps
* timer/timer.c: New file.
* Makefile.am: Reflect change above.
PR 1917/bsps
* Makefile.am, console/console-config.c, console/uart-bridge-master.c,
console/uart-bridge-slave.c, startup/bspstart.c: Modifications to add
dynamic tables for libchip serial drivers.
