* Makefile.am, configure.ac: Rework psim scripts to share code for
creating device trees and actually running the tests. Overhaul the
device tree generated to always include a block of Flash and a
Real-Time Clock. When running MP tests enable the shared memory and
semaphore devices.
* psim-bottom, psim-gdb-bottom, psim-gdb-top.in, psim-shared,
psim-top.in, runtest-bottom, runtest-top.in: New files.
* psim, psim-gdb, runtest: Removed.
* Makefile.am: Add transform and bsptools_bindir hacks.
* configure.ac: Add RTEMS_ENV_RTEMSBSP.
* configure.in: Remove.
