Several GCC tests faild due to the outdated previous linker command
file.
for details.
* Makefile.am, configure.ac: runtest for this BSP obsoleted by
rtems-testing/sim-scripts support. Please use those scripts.
* tools/.cvsignore, tools/ChangeLog, tools/Makefile.am,
tools/configure.ac, tools/psim-bottom, tools/psim-gdb-bottom,
tools/psim-gdb-top.in, tools/psim-shared, tools/psim-top.in,
tools/runtest-bottom, tools/runtest-top.in: Removed.
* Makefile.am, start/start.S: Added AltiVec support
(only effective if user modifies psim.cfg: CPU_CFLAGS
choosing a CPU architecture with AltiVec or directly
adding -maltivec, -mabi=altivec).
* start/start.S: removed '.file' statement which
confused gdb.
* Makefile.am, configure.ac: Disable network interface when networking
is disabled.
* Makefile.am, bsp.h, network/if_sim.c, network/README:
added driver for NIC emulation.
* Makefile.am, preinstall.am, irq/no_pic.c (REMOVED),
irq/irq.h, irq/irq_init.c:
use openpic from 'shared' area instead of no_pic.
* inlude/psim.h:
Added 'extern' declaration for (linker-script defined) RamBase
and RamSize symbols. Let CPP macros expand to these symbols
instead of static constants.
Added register definitions for OpenPIC in the register area.
Added register definitions for ethernet controller in the register
area.
* startup/linkcmds: Increased RamSize to 16M. Increased 'RAM'
memory region to 32M (there is really no disadvantage in making
this large). Added comment explaining the inter-relation between
RamSize, the size of the memory region, the device-tree property
"oea-memory-size" and the DBAT setting.
* tools/psim-shared: Try to determine RamSize from executable
and set 'oea-memory-size' accordingly. May be overridden if 'RAM_SIZE'
envvar is set.
Added openpic to device-tree.
Added ethernet controller to device-tree (commented because a PSIM
patch is currently required to use this device).
* startup/bspstart: Increase DBAT0 mapping to size of 32M.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Remove noinst_PROGRAMS (Unused).
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* Makefile.am, start/start.S: bsp_cleanup() had the same code which was
executed when you returned from boot_card() to start.S. So just use
the stub bsp_cleanup() implementation and remove a file.
* startup/bspclean.c: Removed.
* Makefile.am, include/bsp.h, startup/bspstart.c, startup/linkcmds: Use
PowerPC level shared bsp_get_work_area() implementation.
* startup/bspgetworkarea.c: Removed.
* Makefile.am, startup/bspstart.c: Add use of bsp_get_work_area() in
its own file and rely on BSP Framework to perform more
initialization. Remove unnecessary includes of rtems/libio.h and
rtems/libcsupport.h.
* startup/bspgetworkarea.c: New file.
* Makefile.am, preinstall.am, shmsupp/getcfg.c, shmsupp/lock.c,
startup/linkcmds: Now running mptests using new memory layout with
updates patches against gdb 6.8.
* include/psim.h, startup/psim_registers.c: New files.
* Makefile.am: Remove another duplicate reference.
* Makefile.am: Remove duplicate reference.
* Makefile.am, configure.ac, startup/bspstart.c: Add capability for
bootcard.c BSP Initialization Framework to ask the BSP where it has
memory for the RTEMS Workspace and C Program Heap. These collectively
are referred to as work area. If the BSP supports this, then it does
not have to include code to split the available memory between the
two areas. This reduces the amount of code in the BSP specific
bspstart.c file. Additionally, the shared framework can initialize
the C Library, call rtems_debug_enable(), and dirty the work area
memory. Until most/all BSPs support this new capability, if the BSP
supports this, it should call
RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac. When
the transition is complete, this autoconf macro can be removed.
* Makefile.am: Do not use intermediate .rel files unless from libcpu or
a network driver. This simplifies the Makefile.am and avoids pulling
in unneeded code.
* Makefile.am: use new irq_bspsupport.rel which was
split out of exc_bspsupport.rel to provide finer-grained
control over what BSPs want to use.
* Makefile.am, irq/irq_init.c: use vector/interrupt
support from libcpu/powerpc/new-exceptions/bspsupport.
* Makefile.am: irq_supp.h was moved from shared/irq to
* Makefile.am, irq/no_pic.c: Spacing.
* Makefile.am, startup/bspstart.c: Moved most of the remaining CPU
Table fields to the Configuration Table. This included
pretasking_hook, predriver_hook, postdriver_hook, idle_task,
do_zero_of_workspace, extra_mpci_receive_server_stack,
stack_allocate_hook, and stack_free_hook. As a side-effect of this
effort some multiprocessing code was made conditional and some style
clean up occurred.
* Makefile.am, irq/irq.h, irq/no_pic.c: install
and use new <irq/irq_supp.h> header.
* irq/irq.h, irq/irq.c (removed), irq/no_pic.c (added),
irq/irq_init.c, Makefile.am: The PSIM BSP (currently)
has no support for an interrupt controller or interrupts
other than the decrementer. Removed all definitions for PCI + ISA
interrupts and all unnecessary code (leftovers from copying).
Separated PIC-specific bits into 'no_pic.c' which allows us
to use 'irq.c' (i.e., more code) from 'shared'.
* startup/bspstart.c, Makefile.am: Initialize BATs and enable MMU
to come closer to what other BSPs do. This allows us to use the
shared irq_asm.S. No more individual assembly code :-)
* Makefile.am: Modify to avoid pulling in too much into minimum
executable.
* Makefile.am, irq/irq.h: Merge c_rtems_main() into boot_card(). This
eliminated a file and simplified initialization.
* Makefile.am: Remove superfluous -DASM.
* configure.ac: Add ampolish3 support.
* Makefile.am: Add preinstall.am.
* Makefile.am: Don't include subdirs.am.
* Makefile.am: Merge-in wrapup/Makefile.am.
* wrapup/Makefile.am: Remove.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am, wrapup/Makefile.am: Remove build-variant support.
PR 581/bsps
* Makefile.am, bsp_specs, configure.ac, include/bsp.h, include/tm27.h,
start/start.S, startup/bspstart.c, startup/linkcmds,
tools/Makefile.am, tools/psim, vectors/vectors.S, wrapup/Makefile.am:
Convert PSIM to new exception model.
* irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c: New files.
* startup/setvec.c, timer/timer.c: Removed.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Cosmetics.
* Makefile.am: Add $(TMPINSTALL_FILES) to all-local.
