path: root/c/src/lib/libbsp/powerpc/ppcn_60x (follow)
* Patch from Andrew Bray <andy@chaos.org.uk>:Joel Sherrill1999-04-061-1/+4
| | | | | | In your various bsp_specs files, even when ecrti.o is defined as a startfile, ecrtn.o is not defined as an endfile. Instead it seems to be in the library list - untidy.
* Towards automake XI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-03-1914-43/+168
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | This patch is the most scary of all proposals I've been mailing to you this week until now. It consists of 3 parts: 1. a patch 2. a perl script (acpolish) 3. a shell script wrapper to invoke the perl-script. The perl-script reads in each Makefile.in and modifies them ("polishes/beautifies" them :-). These modifications are not easy to describe: Basically, it hard-codes some automake Makefile-variables and rules into RTEMS autoconf-Makefile.ins (Note: autoconf vs. automake!!) and converts some settings/variables to configure scripts' requirements (Yes, plural). E.g. it adds the automake standard variables $top_builddir and $subdir, adds dependency rules for automatic re-generation of Makefiles from Makefile.in, adds support variables for relative paths to multiple configure scripts etc. The patch is a one-line patch to enable the support of the new features added by acpolish. The shell script is a wrapper which pokes around inside of the source tree for Makefile.ins and invokes acpolish on all autoconf-Makefile.ins. acpolish is designed to be able to run several times on the same Makefile.in and may once become a more general tool to convert RTEMS Makefile.in to automake. Therefore, I'd like to keep it inside of source tree. (e.g. as contrib/acpolish or c/update-tools/acpolish). However, it doesn't make sense to export it outside of RTEMS. To apply this: cd <source-tree> patch -p1 -E < <path-to-patch>/rtems-rc-19990318-1.diff tar xzvf <path-to>/rtems-rc-polish.tar.gz ./rtems-polish.sh ./autogen Note: The path contrib/acpolish is hard-coded into rtems-polish.sh, if you decide to put it in an alternative place, please modify rtems-polish.sh to reflect this change. Later: cvs rm make/rtems.cfg (It isn't used anymore) cvs add contrib cvs add contrib/acpolish cvs commit I've tested this intensively, but naturally I can't exclude bugs. Ralf. PS.: Most probably, this is the last "Towards automake" patch. The next one probably will be a real automake patch.
* Towards automake X patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-03-191-0/+5
| | | | | | | | | | | | | | | | | | | This one once again changes the scheme to preinstall bsp_specs. It moves generating PROJECT_ROOT/lib/bsp_specs to libbsp/<cpu>/<bsp>/wrapup/Makefile.in. I.e. it decentralizes generation of bsp_specs to a bsp-dependent directory, because preinstalling bsp_specs in a centralized Makefile like it has been done until now does not harmonize well with spliting the toplevel configure script in cpu and bsp-dependent configure scripts and automake. First apply the patch (rtems-rc-19990318-0.diff) below, then run the reorg-bsp_specs.sh script. IMO, this one is comparatively harmless and eases automake support significantly.
* Missed this file in the merge.Joel Sherrill1999-02-181-0/+412
* Part of the automake VI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-02-1814-2/+30
* ./clock/Makefile.in,vJoel Sherrill1999-02-1868-0/+13249
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | ./clock/clock.c,v ./console/Makefile.in,v ./console/config.c,v ./console/console.c,v ./console/console.h,v ./console/debugio.c,v ./console/i8042.c,v ./console/i8042_p.h,v ./console/i8042vga.c,v ./console/i8042vga.h,v ./console/ns16550.c,v ./console/ns16550.h,v ./console/ns16550_p.h,v ./console/ns16550cfg.c,v ./console/ns16550cfg.h,v ./console/vga.c,v ./console/vga_p.h,v ./console/z85c30.c,v ./console/z85c30.h,v ./console/z85c30_p.h,v ./console/z85c30cfg.c,v ./console/z85c30cfg.h,v ./include/Makefile.in,v ./include/bsp.h,v ./include/chain.h,v ./include/coverhd.h,v ./include/extisrdrv.h,v ./include/nvram.h,v ./include/pci.h,v ./include/tod.h,v ./network/Makefile.in,v ./network/amd79c970.c,v ./network/amd79c970.h,v ./nvram/Makefile.in,v ./nvram/ds1385.h,v ./nvram/mk48t18.h,v ./nvram/nvram.c,v ./nvram/prepnvr.h,v ./nvram/stk11c68.h,v ./pci/Makefile.in,v ./pci/pci.c,v ./start/Makefile.in,v ./start/start.s,v ./startup/Makefile.in,v ./startup/bspclean.c,v ./startup/bspstart.c,v ./startup/bsptrap.s,v ./startup/device-tree,v ./startup/genpvec.c,v ./startup/linkcmds,v ./startup/rtems-ctor.cc,v ./startup/sbrk.c,v ./startup/setvec.c,v ./startup/spurious.c,v ./startup/swap.c,v ./timer/Makefile.in,v ./timer/timer.c,v ./tod/Makefile.in,v ./tod/cmos.h,v ./tod/tod.c,v ./universe/Makefile.in,v ./universe/universe.c,v ./vectors/Makefile.in,v ./vectors/README,v ./vectors/align_h.s,v ./vectors/vectors.s,v ./wrapup/Makefile.in,v ./Makefile.in,v ./README,v ./STATUS,v ./bsp_specs,v
* ./clock/Makefile.in,vJoel Sherrill1999-02-181-0/+114
./clock/clock.c,v ./console/Makefile.in,v ./console/config.c,v ./console/console.c,v ./console/console.h,v ./console/debugio.c,v ./console/i8042.c,v ./console/i8042_p.h,v ./console/i8042vga.c,v./console/i8042vga.h,v ./console/ns16550.c,v ./console/ns16550.h,v ./console/ns16550_p.h,v ./console/ns16550cfg.c,v ./console/ns16550cfg.h,v ./console/vga.c,v ./console/vga_p.h,v ./console/z85c30.c,v ./console/z85c30.h,v ./console/z85c30_p.h,v ./console/z85c30cfg.c,v ./console/z85c30cfg.h,v ./include/Makefile.in,v ./include/bsp.h,v ./include/chain.h,v ./include/coverhd.h,v ./include/extisrdrv.h,v ./include/nvram.h,v ./include/pci.h,v ./include/tod.h,v ./network/Makefile.in,v ./network/amd79c970.c,v ./network/amd79c970.h,v ./nvram/Makefile.in,v ./nvram/ds1385.h,v ./nvram/mk48t18.h,v ./nvram/nvram.c,v ./nvram/prepnvr.h,v ./nvram/stk11c68.h,v ./pci/Makefile.in,v ./pci/pci.c,v ./start/Makefile.in,v ./start/start.s,v ./startup/Makefile.in,v ./startup/bspclean.c,v ./startup/bspstart.c,v ./startup/bsptrap.s,v ./startup/device-tree,v ./startup/genpvec.c,v ./startup/linkcmds,v ./startup/rtems-ctor.cc,v ./startup/sbrk.c,v ./startup/setvec.c,v ./startup/spurious.c,v ./startup/swap.c,v ./timer/Makefile.in,v ./timer/timer.c,v ./tod/Makefile.in,v ./tod/cmos.h,v ./tod/tod.c,v ./universe/Makefile.in,v ./universe/universe.c,v ./vectors/Makefile.in,v ./vectors/README,v ./vectors/align_h.s,v ./vectors/vectors.s,v ./wrapup/Makefile.in,v ./Makefile.in,v ./README,v ./STATUS,v ./bsp_specs,v
