In your various bsp_specs files, even when ecrti.o is defined as a
startfile, ecrtn.o is not defined as an endfile. Instead it seems to
be in the library list - untidy.
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
and automake.
reorg-bsp_specs.sh script.
significantly.
./clock/clock.c,v
./console/Makefile.in,v
./console/config.c,v
./console/console.c,v
./console/console.h,v
./console/debugio.c,v
./console/i8042.c,v
./console/i8042_p.h,v
./console/i8042vga.c,v
./console/i8042vga.h,v
./console/ns16550.c,v
./console/ns16550.h,v
./console/ns16550_p.h,v
./console/ns16550cfg.c,v
./console/ns16550cfg.h,v
./console/vga.c,v
./console/vga_p.h,v
./console/z85c30.c,v
./console/z85c30.h,v
./console/z85c30_p.h,v
./console/z85c30cfg.c,v
./console/z85c30cfg.h,v
./include/Makefile.in,v
./include/bsp.h,v
./include/chain.h,v
./include/coverhd.h,v
./include/extisrdrv.h,v
./include/nvram.h,v
./include/pci.h,v
./include/tod.h,v
./network/Makefile.in,v
./network/amd79c970.c,v
./network/amd79c970.h,v
./nvram/Makefile.in,v
./nvram/ds1385.h,v
./nvram/mk48t18.h,v
./nvram/nvram.c,v
./nvram/prepnvr.h,v
./nvram/stk11c68.h,v
./pci/Makefile.in,v
./pci/pci.c,v
./start/Makefile.in,v
./start/start.s,v
./startup/Makefile.in,v
./startup/bspclean.c,v
./startup/bspstart.c,v
./startup/bsptrap.s,v
./startup/device-tree,v
./startup/genpvec.c,v
./startup/linkcmds,v
./startup/rtems-ctor.cc,v
./startup/sbrk.c,v
./startup/setvec.c,v
./startup/spurious.c,v
./startup/swap.c,v
./timer/Makefile.in,v
./timer/timer.c,v
./tod/Makefile.in,v
./tod/cmos.h,v
./tod/tod.c,v
./universe/Makefile.in,v
./universe/universe.c,v
./vectors/Makefile.in,v
./vectors/README,v
./vectors/align_h.s,v
./vectors/vectors.s,v
./wrapup/Makefile.in,v
./Makefile.in,v
./README,v
./STATUS,v
./bsp_specs,v
./clock/clock.c,v
./console/i8042.c,v
./console/i8042vga.c,v./console/i8042vga.h,v
./console/vga.c,v
./console/vga_p.h,v
./include/bsp.h,v
./include/chain.h,v
./include/nvram.h,v
./include/pci.h,v
./include/tod.h,v
./nvram/ds1385.h,v
./nvram/mk48t18.h,v
./nvram/nvram.c,v
./nvram/prepnvr.h,v
./pci/Makefile.in,v
./pci/pci.c,v
./start/start.s,v
./startup/sbrk.c,v
./startup/swap.c,v
./timer/timer.c,v
./tod/Makefile.in,v
./tod/cmos.h,v
./tod/tod.c,v
./vectors/README,v
./Makefile.in,v
./README,v
./STATUS,v
./bsp_specs,v
