Update #3285.
Update #3285.
Update #3285.
Update #2408.
Update #3285.
Update #3285.
Update #3285.
Update #3387.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
upgrade to that version.
Close #3387.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Use only one timer driver variant based on the standard PowerPC time
base.
Update #3285.
The only consumer of this variable was the ppc403 clock driver used by
the
* haleakala,
* virtex, and
* virtex4
BSPs which set bsp_timer_internal_clock unconditionally to true.
Update #3285.
Update #3285.
Update #3285.
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
EXTRA_DIST += foobar
in fragments.
Update #3254.
Update #3254.
Updates #3520.
Updates #3250.
maintain.
Update #3254.
BSP_PRESS_KEY_FOR_RESET=0
BSP_RESET_BOARD_AT_EXIT=1
BSP_PRINT_EXCEPTION_CONTEXT=1
BSPs can use the bsp_fatal_extension() to provide BSP-specific fatal
error handling. There is no need for a _BSP_Fatal_error().
Close #3246.
Due to a new rtems_panic() implementation, it is possible to replace the
PowerPC-specific BSP_panic() with rtems_panic(). Remove BSP_panic()
implementations.
Close #3245.
Update #3239.
The BSP_output_char should output a char and not mingle with high level
processing, e.g. '\n' to '\r\n' translation. Move this translation to
rtems_putc(). Remove it from all the BSP_output_char implementations.
Close #3122.
Change bsp_interrupt_vector_enable() and bsp_interrupt_vector_disable()
to not return a status code. Add bsp_interrupt_assert() and use it to
validate the vector number in the vector enable/disable implementations.
Update #2833.
warnings
