PR 833/bsps
* irq/irq_asm.S: Currently, all (new exception) BSPs explicitely enable
the FPU across the user ISR but DONT save/restore the FPU context.
Any use of the FPU fron the user handler (e.g., due to GCC
optimizations) result in corruption. The fix results in an exception
in such cases (user ISR must explicitely save/enable/restore FPU).
* irq/irq.c, irq/irq.h: Modified to use rtems/irq.h.
PR 779/bsp
* clock/p_clock.c, irq/irq.c, irq/irq.h, irq/irq_init.c,
network/network.c: add parameter to new exception interrupt handlers
in powerpc bsps
* console/console.c, include/bsp.h, irq/irq.c, network/network.c,
startup/bspstart.c: Convert to using c99 fixed size types.
* irq/irq.h: Correct typo.
* Makefile.am: Merge-in clock/.cvsignore, console/.cvsignore,
irq/.cvsignore, network/.cvsignore, startup/.cvsignore,
vectors/.cvsignore. Use automake compilation rules.
* clock/.cvsignore, console/.cvsignore, irq/.cvsignore,
network/.cvsignore, startup/.cvsignore, vectors/.cvsignore: Remove.
* wrapup/Makefile: Reflect changes above.
* irq/Makefile.am: Add PREINSTALL_DIRS.
* vectors/Makefile.am: Add PREINSTALL_DIRS.
* wrapup/Makefile.am: Reflect changes to libcpu.
* irq/Makefile.am: Ditto.
* start/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
* vectors/Makefile.am: Ditto.
* clock/Makefile.am: Eliminate VPATH.
* console/Makefile.am: Eliminate VPATH.
* irq/Makefile.am: Eliminate VPATH.
* network/Makefile.am: Eliminate VPATH.
* startup/Makefile.am: Eliminate VPATH.
* irq/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* vectors/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* irq/Makefile.am: Add preinstallation dirstamp support.
* network/Makefile.am: Cosmetics.
* vectors/Makefile.am: Add preinstallation dirstamp support.
* irq/Makefile.am: Remove all-local: $(ARCH).
PR 510/bsps
* irq/irq.h: Add extern C wrapper.
* clock/p_clock.c, include/bsp.h, include/coverhd.h, irq/irq.c,
irq/irq.h, irq/irq_asm.S, irq/irq_init.c, network/if_hdlcsubr.h,
startup/bspstart.c, startup/setvec.c, vectors/vectors.h,
vectors/vectors_init.c: URL for license changed.
irq/Makefile.am: Reflect having moved automake.
* irq/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Remove SORDID_HACK. Eliminate *_O_FILES.
* vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* irq/irq.c: Removed warnings.
* console/console.c, irq/irq.c, network/if_hdlcsubr.c,
network/if_hdlcsubr.h, network/network.c, vectors/vectors_init.c:
Removed warnings.
* irq/irq.c, irq/irq_asm.S, startup/bspstart.c: Fixed typos and
removed warnings.
* irq/irq.c, irq/irq_asm.S, irq/irq_init.c: Per PR288, add support
for _ISR_Nest_level.
* irq/Makefile.am: Use .$(OBJEXT) instead of .o.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* irq/irq.c: Reflect changes to <rtems/score/cpu.h>.
* irq/irq_asm.S: Ditto.
* network/network.c: Include <rtems/bspIo.h>.
* start/start.S: Include <asm.h> instead of "asm.h".
* vectors/vectors.S: Reflect changes to <rtems/score/cpu.h>.
* vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* clock/p_clock.c: Include rtems/bspIo.h instead of bspIo.h.
* console/console.c: Include rtems/bspIo.h instead of bspIo.h.
* irq/irq_init.c: Include rtems/bspIo.h instead of bspIo.h.
* aclocal.m4: Regenerated.
* configure.ac, include/Makefile.am, irq/Makefile.am,
vectors/Makefile.am: Updated to autoconf 2.52.
* include/.cvsignore: Added newly generated files.
* include/bsp.h: Added include of bspopts.h.
* mpc8260ads added as new BSP. tm27 reported not to run
at this time.
* ChangeLog, Makefile.am, README, aclocal.m4, bsp_specs,
clock/.cvsignore, clock/Makefile.am, clock/p_clock.c, configure.in,
console/Makefile.am, console/console.c, include/Makefile.am,
include/bsp.h, include/coverhd.h, irq/.cvsignore, irq/Makefile.am,
irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c,
network/Makefile.am, network/README, network/if_hdlcsubr.c,
network/if_hdlcsubr.h, network/network.c, start/Makefile.am,
start/start.S, startup/Makefile.am, startup/bspstart.c,
startup/cpuinit.c, startup/linkcmds, startup/setvec.c, times,
vectors/.cvsignore, vectors/Makefile.am, vectors/vectors.S,
vectors/vectors.h, vectors/vectors_init.c, wrapup/Makefile.am:
New files.
