* | bsp/mpc55xx: Merge RSM6 variants into one | Sebastian Huber | 2013-02-06 | 1 | -31/+24 |
* | bsp/mpc55xx: Add BSP_DATA_CACHE_USE_WRITE_THROUGH | Sebastian Huber | 2013-01-28 | 1 | -1/+5 |
* | bsp/mpc55xx: Fix MMU configuration for RSM6 | Sebastian Huber | 2013-01-28 | 1 | -4/+4 |
* | bsp/mpc55xx: New BSP variants for RSM6 | Sebastian Huber | 2012-12-03 | 1 | -1/+33 |
* | bsp/mpc55xx: Use RTEMS_ARRAY_SIZE() | Sebastian Huber | 2012-12-03 | 1 | -1/+1 |
* | bsp/mpc55xx: Use BSP_START_DATA_SECTION | Sebastian Huber | 2012-12-03 | 1 | -5/+2 |
* | bsp/mpc55xx: Fix no-cache section load | Sebastian Huber | 2012-12-03 | 1 | -25/+33 |
* | bsp/mpc55xx: PR2077: Mapping for external flash | Peter Dufault | 2012-10-02 | 1 | -53/+6 |
* | bsp/mpc55xx: Add and use MPC55XX_CHIP_FAMILY | Sebastian Huber | 2012-10-02 | 1 | -1/+1 |
* | bsp/mpc55xx: New ECU508 BSPs | Sebastian Huber | 2012-07-18 | 1 | -0/+26 |
* | bsps/powerpc: Add no cache section | Sebastian Huber | 2012-04-24 | 1 | -1/+5 |
* | bsp/mpc55xxevb: Change early MMU settings | Sebastian Huber | 2012-04-24 | 1 | -12/+12 |
| | | | | | | Add internal SRAM sections with cache enabled to early MMU settings. The internal SRAM initialization will use the early MMU settings. This allows applications to use cache inhibited areas in the internal SRAM. | ||||
* | Support for MPC5643L. | Sebastian Huber | 2012-01-23 | 1 | -0/+134 |
Rework of the start sequence to reduce the amount assembler code and to support configuration tables which may be provided by the application. |
