path: root/c/src/lib/libbsp/powerpc/mpc55xxevb/i2c (follow)
* bsps/powerpc: Add probe handler to I2C driverSebastian Huber2013-01-091-2/+7
* bsp/mpc55xx: Add and use MPC55XX_CHIP_FAMILYSebastian Huber2012-10-021-1/+1
* 2011-08-31 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-08-311-5/+5
| | | | | | | | | | | | | | | | | | | | * startup/bspgetworkarea.c, startup/linkcmds.base: Removed files. * include/mpc55xx-config.h, make/custom/mpc5674fevb.cfg, startup/early-init.c, startup/ebi-cal-cs-config.c, startup/ebi-cs-config.c, startup/exc-vector-base.S, startup/fmpll-syncr-vals.c, startup/linkcmds.mpc5674fevb, startup/mmu-config.c, startup/siu-pcr-config.c: New files. * Makefile.am, preinstall.am: Reflect changes above. * startup/linkcmds.gwlcfm, startup/linkcmds.mpc5566evb, startup/linkcmds.phycore_mpc5554: Use linker command base file. * configure.ac: Support MPC5674F. Changed eSCI options. * clock/clock-config.c: Support MPC5674F. * i2c/i2c_init.c, network/smsc9218i.c, startup/sd-card-init.c: Update due to API changes. * include/bsp.h: Define BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGIN. * network/if_smc.c: Use HAS_SMC91111. * startup/start.S, startup/bspstart.c: Moved low-level initialization into new files. Overall cleanup.
* 2010-12-22 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-12-221-84/+42
| | | | | | | | | | | * configure.ac: Added I2C options. Fixed eMIOS prescaler. Use standard linker command file support. * include/bsp.h: Declare I2C initialization function. * i2c/i2c_init.c: Implementation. * make/custom/gwlcfm.cfg, make/custom/mpc5566evb.cfg, make/custom/mpc55xx.inc: Use standard linker command file support. * startup/bspstart.c: More board specific settings. * Makefile.am, preinstall.am: Reflect changes above.
* add support for mpc551x based GW_LCFM systemThomas Doerfler2010-03-251-0/+112
