Remove MPC55XX_ESCI_CONSOLE_MINOR.
Rework of the start sequence to reduce the amount assembler code and to
support configuration tables which may be provided by the application.
* make/custom/mpc5566evb_spe.cfg, make/custom/mpc5674fevb_spe.cfg,
startup/linkcmds.mpc5566evb_spe, startup/linkcmds.mpc5674fevb_spe,
startup/reset.c: New files.
* Makefile.am, preinstall.am: Reflect changes above.
* startup/early-init.c: Added missing section attribute.
* configure.ac, network/smsc9218i.c: New BSP options
SMSC9218I_EDMA_RX_CHANNEL and SMSC9218I_EDMA_TX_CHANNEL. Enable reset
at cleanup.
* startup/bspgetworkarea.c, startup/linkcmds.base: Removed files.
* include/mpc55xx-config.h, make/custom/mpc5674fevb.cfg,
startup/early-init.c, startup/ebi-cal-cs-config.c,
startup/ebi-cs-config.c, startup/exc-vector-base.S,
startup/fmpll-syncr-vals.c, startup/linkcmds.mpc5674fevb,
startup/mmu-config.c, startup/siu-pcr-config.c: New files.
* startup/linkcmds.gwlcfm, startup/linkcmds.mpc5566evb,
startup/linkcmds.phycore_mpc5554: Use linker command base file.
* configure.ac: Support MPC5674F. Changed eSCI options.
* clock/clock-config.c: Support MPC5674F.
* i2c/i2c_init.c, network/smsc9218i.c, startup/sd-card-init.c: Update
due to API changes.
* include/bsp.h: Define BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGIN.
* network/if_smc.c: Use HAS_SMC91111.
* startup/start.S, startup/bspstart.c: Moved low-level initialization
into new files. Overall cleanup.
* make/custom/phycore_mpc5554.cfg, startup/linkcmds.phycore_mpc5554,
network/if_smc.c: New files.
* configure.ac: Add support for the Phytec PhyCORE MPC5554. Includes:
- HAS_SMC91111 to indicate a BSP has that neworking.
- SMC91111_ENADDR_IS_SETUP so that it skips code to set up the MAC
address.
- MPC55XX_CLOCK_EMIOS_CHANNEL to permit one to set which eMIOS
channel to use for the clock.
- MPC55XX_BOOTFLAGS: Skips two words above the RCHW in the startup
for use in skpping over the MMU setup. Required for debugging via a
cheap emulator where code is loaded into RAM and then mapped in as
flash.
- BOARD_PHYCORE_MPC5554 If defined, use custom settings for the
Phytec PhyCORE MPC5554 SOM.
* clock/clock-config.c: Modify so that the EMIOS channel used for the
clock can be selected at configuration time. For MPC5544 only:
- Conditionally skip access to a register that faults if accessed on
the MPC5554
- Do not set the control register mode as was done for GW_LCFM
support, it breaks interrupts.
* make/custom/mpc55xx.inc: Make it possible to override the soft-float
to set the type of floating point BSP will use.
* startup/start.S: Add support for the "boot flags", two long-words
that I manipulate with the debugger to skip over MMU setup. Use an
external for the start of external SRAM instead of the hardwired
number 0x20000000. Disable write access to the internal flash.
* configure.ac, startup/start.S: Use standard cache BSP options.
* Makefile.am, preinstall.am, startup/start.S: Use standard zero
function.
* startup/linkcmds.base: Reserve enough space for the exception
minimum prologues. Changed start section name.
* startup/bspstart.c: Removed superfluous cache initialization.
* configure.ac: Fixed option default values.
* configure.ac: Added I2C options. Fixed eMIOS prescaler. Use
standard linker command file support.
* include/bsp.h: Declare I2C initialization function.
* i2c/i2c_init.c: Implementation.
* make/custom/gwlcfm.cfg, make/custom/mpc5566evb.cfg,
make/custom/mpc55xx.inc: Use standard linker command file support.
* startup/bspstart.c: More board specific settings.
* configure.ac: Remove AC_CHECK_SIZEOF([void *]).
* configure.ac: Added AC_CHECK_SIZEOF macro.
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
added support for an optional separate heap area.
* configure.ac: Remove RTEMS_AMPOLISH3.
updated haleakala BSP
added MPC55xx BSP
