PR 349/bsps
* openpic/Makefile.am, pci/Makefile.am:
- install the 'openpic.h' and 'pci.h' headers
- avoid a name clash by renaming 'vsprintf' & friends
to 'k_vsprintf' etc.
- let 'rtemsReboot' print a stack trace (in case an 'assert' failed)
- irq.c:
* fix: remove implicit assumption that ISA interrupt vectors start
at 0
* add BSP hook to let a VME interrupt acknowledge the PCI/openpic
IRQ. (SEE ALSO THE ppc-sharedbsp-vme.diff patch)
- fix: EABI compliance; isr/exception lowlevel handlers must not
clobber R2 or R13
- fix: openpic_init was called with the polarity/senses tables
swapped (fixed wrong order of arguments)
- cosmetics: use new _read_SPRXX() _write_SPRXX() macros
* bootloader/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* irq/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* motorola/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* openpic/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* pci/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* residual/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* bootloader/Makefile.am: Use .$(OBJEXT) instead of .o.
* irq/Makefile.am: Use .$(OBJEXT) instead of .o.
* motorola/Makefile.am: Use .$(OBJEXT) instead of .o.
* openpic/Makefile.am: Use .$(OBJEXT) instead of .o.
* pci/Makefile.am: Use .$(OBJEXT) instead of .o.
* residual/Makefile.am: Use .$(OBJEXT) instead of .o.
* bootloader/Makefile.am: Remove AUTOMAKE_OPTIONS.
* motorola/Makefile.am: Remove AUTOMAKE_OPTIONS.
* openpic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* pci/Makefile.am: Remove AUTOMAKE_OPTIONS.
* residual/Makefile.am: Remove AUTOMAKE_OPTIONS.
* vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* residual/Makefile.am: Use 'PREINSTALL_FILES ='.
* vectors/Makefile.am: Use 'PREINSTALL_FILES ='.
* pci/Makefile.am: Use 'PREINSTALL_FILES ='.
* openpic/Makefile.am: Use 'PREINSTALL_FILES ='.
* bootloader/Makefile.am: Use 'CLEANFILES ='.
* bootloader/Makefile.am, clock/Makefile.am, console/Makefile.am,
irq/Makefile.am, motorola/Makefile.am, openpic/Makefile.am,
pci/Makefile.am, residual/Makefile.am, start/Makefile.am,
startup/Makefile.am, vectors/Makefile.am, wrapup/Makefile.am:
Include compile.am
converted to automake.
