These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
for details.
* configure.ac, startup/bspstart.c, include/coverhd.h: Use standard
cache BSP options.
* console/console.c, irq/irq.c:
* beatnik/include/bsp.h, beatnik/irq/irq.h, beatnik/pci/gt_pci_init.c,
ep1a/console/polled_io.c, ep1a/irq/openpic_xxx_irq.c,
gen5200/include/irq.h, gen5200/irq/irq.c, gen5200/startup/bspstart.c,
haleakala/irq/irq.c, mbx8xx/irq/irq.c, mbx8xx/irq/irq.h,
motorola_powerpc/include/bsp.h, mpc8260ads/irq/irq.c,
mpc8260ads/irq/irq.h, mvme3100/include/bsp.h, mvme3100/irq/irq.h,
mvme3100/start/start.S, mvme5500/include/bsp.h, mvme5500/irq/irq.h,
psim/include/bsp.h, psim/include/coverhd.h, psim/irq/irq.h,
psim/shmsupp/addrconv.c, psim/shmsupp/getcfg.c,
psim/startup/linkcmds, psim/tools/psim-gdb-top.in,
psim/tools/psim-top.in, psim/tools/runtest-top.in, qemuppc/irq/irq.h,
score603e/irq/irq.c, shared/bootloader/bootldr.h,
shared/bootloader/em86.c, shared/bootloader/em86real.S,
shared/bootloader/exception.S, shared/bootloader/head.S,
shared/bootloader/lib.c, shared/bootloader/misc.c,
shared/bootloader/mm.c, shared/bootloader/pci.c,
shared/console/console.c, shared/console/consoleIo.h,
shared/console/inch.c, shared/console/keyboard.h,
shared/console/polled_io.c, shared/irq/i8259.c, shared/irq/irq.h,
shared/irq/openpic_i8259_irq.c, shared/motorola/motorola.c,
shared/motorola/motorola.h, shared/openpic/openpic.c,
shared/openpic/openpic.h, shared/pci/pci.c,
shared/residual/residual.c, shared/start/start.S, ss555/irq/irq.h:
Fix typo where license said found in found in.
* console/console.c: Add BSP_poll_char.
* configure.ac: Remove AC_CHECK_SIZEOF([void *]).
* configure.ac: Added AC_CHECK_SIZEOF macro.
* include/irq-config.h: Removed file.
* Makefile.am, preinstall.am: Reflect change above.
* include/irq.h: Moved defines from 'include/irq-config.h'.
* console/console.c, ide/pcmcia_ide.c, startup/bspstart.c,
startup/imbx8xx.c: Fix some warnings.
* irq/irq.h: Add BSP_irq_enabled_at_cpm.
* network/network.c: Remove local decl of BSP_irq_enabled_at_cpm.
* make/custom/mbx8xx.inc: Remove RTEMS_BSP_FAMILY.
* make/custom/mbx8xx.inc: New (Renamed from mbx8xx.cfg).
* make/custom/mbx8xx.cfg: Removed.
* make/custom/mbx821_001.cfg, make/custom/mbx821_002b.cfg,
make/custom/mbx821_002.cfg, make/custom/mbx860_001b.cfg,
make/custom/mbx860_002.cfg, make/custom/mbx860_005b.cfg,
make/custom/mbx860_1b.cfg:
Include make/custom/mbx8xx.inc.
* make/custom/mbx821_001.cfg: New (relocated from /make/custom).
* make/custom/mbx821_002b.cfg: New (relocated from /make/custom).
* make/custom/mbx821_002.cfg: New (relocated from /make/custom).
* make/custom/mbx860_001b.cfg: New (relocated from /make/custom).
* make/custom/mbx860_002.cfg: New (relocated from /make/custom).
* make/custom/mbx860_005b.cfg: New (relocated from /make/custom).
* make/custom/mbx860_1b.cfg: New (relocated from /make/custom).
* make/custom/mbx8xx.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* ep1a/startup/linkcmds, mbx8xx/startup/linkcmds,
score603e/startup/linkcmds, shared/startup/linkcmds,
ss555/startup/linkcmds: Fix typos in .eh_frame sections.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* startup/linkcmds: Correct name of ENTRY.
* startup/start.S: Update for boot_card command line change.
PR 1385/cpukit
* irq/irq_asm.S: When the type rtems_boolean was switched to the C99
bool, the size changed from 4 bytes to 1 byte. The interrupt
dispatching code accesses two boolean variables for scheduling
purposes and the assembly implementations of this code did not get
updated.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* Makefile.am: Eliminate bsp.am.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* include/bsp.h: Remove unnecessary boilerplate comments.
* include/bsp.h: Eliminate definitions of BSP_LIBIO_MAX_FDS since this
is NOT used anywhere.
* Makefile.am, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* startup/bspgetworkarea.c: Removed.
* startup/bspstart.c: Remove unnecessary includes of
rtems/libcsupport.h and rtems/libio.h.
* startup/bspstart.c, startup/bspstart.c.nocache: Add use of
bsp_get_work_area() in its own file and rely on BSP Framework to
perform more initialization.
* Makefile.am, configure.ac, startup/bspstart.c, startup/linkcmds:
Create bsp_get_work_area() into its own file and use BSP Framework to
* startup/bspgetworkarea.c: New file.
