path: root/c/src/lib/libbsp/powerpc/mbx8xx/startup (follow)
* 2002-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-011-0/+1
| | | | | * clock/p_clock.c, console/console.c, startup/bspstart.c: Removed warnings.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-111-2/+2
| | | | | | | | | | * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * irq/Makefile.am: Use .$(OBJEXT) instead of .o. * network/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * vectors/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-07-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-201-0/+2
| | | | * startup/Makefile.am: Add bsplib_DATA = linkcmds.
* 2001-05-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-05-091-1/+4
| | | | | | | | * startup/linkcmds: In support of gcc 3.1, added one of more of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*, .gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections and direction of segments to memory regions may also have been addressed. This was a sweep across all BSPs.
* 2002-04-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-171-0/+2
| | | | * startup/bspstart.c: Include <libcpu/cpuIdent.h>, <rtems/bspIo.h>.
* 2001-04-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-081-0/+1
| | | | * startup/linkcmds: Per PR170, PR171, and PR172 add .eh_frame
| | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * console/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * irq/Makefile.am: Remove AUTOMAKE_OPTIONS. * network/Makefile.am: Remove AUTOMAKE_OPTIONS. * startup/Makefile.am: Remove AUTOMAKE_OPTIONS. * vectors/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-124-4/+0
| | | | | | * clock/p_clock.c, include/bsp.h, include/coverhd.h, startup/bspstart.c, startup/bspstart.c.nocache, startup/setvec.c, startup/start.S: Fixed typo.
* 2000-06-08 Eric Valette <valette@crf.canon.fr>Joel Sherrill2001-06-081-1/+6
| | | | | | | | | | | | | | | | * console/console.c, include/commproc.h, startup/start.S: The printk/printf did not work when loaded by EPPCBUG. They did work when loaded with the BDM debugger. I suspected EPPBUG made some nasty things like patching Communication processor microcode... Anyway, the attached patch: 1) Enables to have printk nearly immediately after boot, 2) Make printf work automagically (I do not know why except I make a different initialization for printk that should be overwritten by console init later ?) I let the default to be using EPPCBUG embedded firmware to boot and using this printk early enabler code (LOADED_BY_EPPCBUG and EARLY_CONSOLE) are on.
* 2001-03-30 Eric Valette <valette@crf.canon.fr>Joel Sherrill2001-04-066-13/+73
| | | | | | | | | | | | | | | * clock/.cvsignore, clock/Makefile.am, clock/p_clock.c, include/8xx_immap.h, include/commproc.h, include/mbx.h, irq/.cvsignore, irq/Makefile.am, irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c, vectors/.cvsignore, vectors/Makefile.am, vectors/vectors.S, vectors/vectors.h, vectors/vectors_init.c: New files. * Makefile.am, configure.in, console/console.c, include/Makefile.am, network/network.c, startup/Makefile.am, startup/bspstart.c, startup/imbx8xx.c, startup/linkcmds, startup/mmutlbtab.c, startup/start.S, wrapup/Makefile.am: The modifications to this BSP reflect the conversion of the mpc8xx CPU to the "new exception processing model."
* 2000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-011-17/+3
| | | | | | | | * startup/bspstart.c, startup/bspstart.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. Header file order was cleaned up while doing this. Also removed obsolete references to STACK_CHECKER_ON.
| | | | | | | | * startup/bspstart.c, startup/bspstart.c.nocache: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. Header file order was cleaned up while doing this. Also removed obsolete references to STACK_CHECKER_ON.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-4/+5
| | | | | * console/Makefile.am, network/Makefile.am, startup/Makefile.am, wrapup/Makefile.am: Include compile.am
* 2000-08-11 Charles-Antoine Gauthier <charles.gauthier@nrc.ca>Joel Sherrill2000-08-251-7/+13
| | | | | | | | | * README: * console/console.c: * include/bsp.h: * network/network.c: * startup/bspstart.c: Add support for configuration parameters in NVRAM
* Properly pass argc, argc, and environp to boot_card.Joel Sherrill2000-08-021-0/+4
* Fixed typo.Joel Sherrill2000-07-101-1/+1
* Patch from Eric Valette <valette@crf.canon.fr> and Yacine El KolliJoel Sherrill2000-07-062-13/+107
| | | | <elkolli@crf.canon.fr> to add support for the mbx860_005b.
* Patch from John Cotton <john.cotton@nrc.ca> to correct cacheJoel Sherrill2000-06-141-2/+2
| | | | | | routine naming to follow RTEMS package/object.method rule. This patch also eliminated calls to the obsolete routine m68k_enable_caching.
* Added .cvsignore.Joel Sherrill2000-06-131-0/+2
* Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine GauthierJoel Sherrill2000-06-128-0/+1790
<charles.gauthier@iit.nrc.ca>, and Darlene A. Stewart <Darlene.Stewart@nrc.ca> to add support for a number of very significant things: + BSPs for many variations on the Motorola MBX8xx board series + Cache Manager including initial support for m68040 and PowerPC + Rework of mpc8xx libcpu code so all mpc8xx CPUs now use same code base. + Rework of eth_comm BSP to utiltize above. John reports this works on the 821 and 860
