* | bsp/gen5200: Fix i2c.h and i2cdrv.h installation | Sebastian Huber | 2018-01-19 | 2 | -2/+2 |
| | | | | | | Install these files only as <bsp/i2c.h> and <bsp/i2cdrv.h>. Update #3254. | ||||
* | libchip: Simplify RTC driver | Sebastian Huber | 2016-07-04 | 1 | -2/+0 |
* | bsp/gen5200: Fix warnings | Sebastian Huber | 2014-10-10 | 1 | -3/+3 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 3 | -6/+6 |
* | score: Add RTEMS_FATAL_SOURCE_BSP | Sebastian Huber | 2014-02-19 | 1 | -1/+2 |
| | | | | | | Merge RTEMS_FATAL_SOURCE_BSP_GENERIC and RTEMS_FATAL_SOURCE_BSP_SPECIFIC into new fatal source RTEMS_FATAL_SOURCE_BSP. This makes it easier to figure out the code position given a fatal source and code. | ||||
* | bsp/gen5200: Add and use mpc5200_fatal() | Sebastian Huber | 2013-02-20 | 1 | -3/+2 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-07-19 | 2 | -4/+0 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-29 | 1 | -5/+5 |
* | 2009-10-22 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-22 | 1 | -1/+1 |
| | | | | | | * clock/clock.c: Add missing prototypes. Remove argument from clockOff(). * tod/pcf8563.c: Add missing const. | ||||
* | Convert to "bool". | Ralf Corsepius | 2008-09-06 | 1 | -6/+6 |
* | applied patches for PR1117/1118/1119/1120 | Thomas Doerfler | 2006-07-09 | 1 | -2/+2 |
* | Cleanup CVS data. | Ralf Corsepius | 2006-01-01 | 3 | -57/+0 |
* | Misc include file fixes. | Ralf Corsepius | 2005-12-31 | 1 | -1/+5 |
* | New (CVS import Thomas Doerfler <Thomas.Doerfler@embedded-brains.de>'s | Ralf Corsepius | 2005-12-31 | 3 | -0/+488 |
submission). |
