* network/network.c: Removed warnings.
* canbus/canbus.c, clock/p_clock.c, console/console.c,
network/network.c, startup/bspstart.c: Removed warnings.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* canbus/Makefile.am: Use .$(OBJEXT) instead of .o.
* irq/Makefile.am: Use .$(OBJEXT) instead of .o.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* irq/irq.c: Reflect changed to <rtems/score/cpu.h>.
* irq/irq_asm.S: Ditto.
* vectors/vectors.S: Ditto.
* vectors/vectors_init.c: Include <rtems/bspIo.h>.
* irq/irq.c: Define loopCounter iff DISPATCH_HANDLER_STAT is set.
* startup/bspstart.c: include <bsp/irq.h>, <libcpu/cpuIdent.h>,
<rtems/bspIo.h>
* configure.ac: Add BSPOPTS_*(DISPATCH_HANDLER_STAT).
* startup/linkcmds: Per PR170, PR171, and PR172 add .eh_frame
* canbus/Makefile.am: Remove AUTOMAKE_OPTIONS.
* vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* console/console.c: Include rtems/bspIo.h instead of bspIo.h.
* configure.ac: Remove RTEMS_ENABLE_NETWORKING.
* Makefile.am: Add @exceptions@ to SUBDIRS.
* configure.ac: Add RTEMS_BSPOPTS_*(UARTS_IO_MODE),
RTEMS_PPC_EXCEPTIONS([new]).
* include/Makefile.am: Convert PREINSTALL_FILES to
TMPINSTALL_FILES, include force-preinstall.am.
* irq/Makefile.am: remove irq.h from EXTRA_DIST.
* wrapup/Makefile.am: Apply @exceptions@.
* include/bsp.h: Modify Install_tm27_vector() so this BSP will link tm27.
* startup/linkcmds: Fix definition of .init and .fini sections so this
BSP will properly link with new __USE_INIT_FINI__ support.
* startup/linkcmds: Added _init and _fini.
* vectors/Makefile.am: Remove bogus VPATH.
* clock/p_clock.c: Fixed typo.
* configure.in: Remove.
* irq/Makefile.am: Use 'PREINSTALL_FILES ='.
* vectors/Makefile.am: Use 'PREINSTALL_FILES ='.
* network/network.c: Fix to account for return value when
installing interrupts handler.
* include/bsp.h: Added include of <bsp/vectors.h>
* vectors/vectors.h: Corrected typos.
* clock/.cvsignore, clock/Makefile.am, clock/p_clock.c,
include/8xx_immap.h, include/commproc.h, irq/.cvsignore,
irq/Makefile.am, irq/irq.c, irq/irq.h, irq/irq_asm.S,
irq/irq_init.c, vectors/.cvsignore, vectors/Makefile.am,
vectors/vectors.S, vectors/vectors.h,
vectors/vectors_init.c: New file.
* Switch the eth_comm BSP to use the "new exception processing model."
* Makefile.am, configure.in, console/console.c,
include/Makefile.am, include/bsp.h, network/network.c,
startup/Makefile.am, startup/bspstart.c, startup/linkcmds,
wrapup/Makefile.am: Switch the eth_comm BSP to use the
* startup/bspstart.c: assoc.h, error.h, libio_.h, libio.h, and
libcsupport.h moved from libc to lib/include/rtems and
Also removed obsolete references to STACK_CHECKER_ON.
* console/console.c: Add mbx8xx_console_get_configuration() which
returns either nvram configuration or a static equivalent.
* startup/linkcmds: Added lines so DWARF debug information
would be available. Otherwise gdb complains that the offsets
for the debug info are incorrect and doesn't load the files.
* canbus/Makefile.am, console/Makefile.am, network/Makefile.am,
start/Makefile.am, startup/Makefile.am, wrapup/Makefile.am: Include
compile.am
