* console/config.c, console/console.c, console/console.h,
console/ns16550cfg.c, console/ns16550cfg.h, include/bsp.h,
include/tm27.h, irq/irq_init.c, irq/openpic_xxx_irq.c,
pci/no_host_bridge.c: File head clean up.
* console/debugio.c: Removed.
* Makefile.am, configure.ac, console/alloc360.c, console/console.c,
console/console.h, console/m68360.h, console/mc68360_scc.c,
console/ns16550cfg.c, console/rsPMCQ1.c, console/rsPMCQ1.h,
include/bsp.h, irq/irq_init.c, vme/VMEConfig.h: Initiate update and
testing. Add missing files. Does not run hello yet.
* console/debugio.c, console/polled_io.c, irq/openpic_xxx_irq.c: New files.
* Makefile.am, irq/irq.c (removed), irq/irq_init.c:
Use shared exception/interrupt support from
libcpu/new-exceptions/bspsupport. NOTE: CHANGES MUST BE
TESTED ON REAL HARDWARE.
* ep1a/irq/irq.c, gen5200/irq/irq.c, gen83xx/irq/irq_init.c,
mbx8xx/irq/irq.c, mpc8260ads/irq/irq.c, mvme5500/irq/irq.c,
psim/irq/no_pic.c, score603e/irq/irq.c, shared/irq/irq_supp.h,
shared/irq/openpic_i8259_irq.c, virtex/irq/irq_init.c:
let C_dispatch_irq_handler() return zero to indicate to
low-level exception handling code that the exception
was handled (not used yet).
* irq/irq_init.c: added new args to openpic_init().
This BSP probably needs them (8245 has an EPIC).
I would be surprised if the PCI interrupts with the
old code actually worked...
* irq/irq.h, irq/irq_init.c: Removed the definition
of ASM_IRQ_VECTOR_BASE; this symbol was only use to
initialize the irqBase member of the rtems_irq_global_settings
struct. However, irqBase is an rtems_irq_symbolic_name,
so using BSP_LOWEST_OFFSET is more appropriate.
* ep1a/irq/irq.c, gen5200/irq/irq.c, mbx8xx/irq/irq.c,
mpc8260ads/irq/irq.c, mvme5500/irq/irq.c, psim/irq/irq.c,
score603e/irq/irq.c, shared/irq/irq.c:
test for non-NULL-ness before calling 'on'/'off'
methods so that users don't have to provide
no-ops if they don't want this feature.
PR 1257/bsps
* irq/irq.c: Code outside of cpukit should use the public API for
rtems_interrupt_disable/rtems_interrupt_enable. By bypassing the
public API and directly accessing _CPU_ISR_Disable and
_CPU_ISR_Enable, they were bypassing the compiler memory barrier
directive which could lead to problems. This patch also changes the
type of the variable passed into these routines and addresses minor
style issues.
* console/rsPMCQ1.c, irq/irq.c: Modified to use rtems/irq.h.
* irq/irq_init.c, startup/bspstart.c: Name modification for generic pci
interface
* irq/irq.c, start/start.S: Removed warnings
* acinclude.m4: Initial release of ep1a bsp
* ep1a/Makefile.am, ep1a/bsp_specs, ep1a/configure.ac,
ep1a/console/alloc360.c, ep1a/console/console.c,
ep1a/console/console.h, ep1a/console/init68360.c,
ep1a/console/m68360.h, ep1a/console/mc68360_scc.c,
ep1a/console/ns16550cfg.c, ep1a/console/ns16550cfg.h,
ep1a/console/rsPMCQ1.c, ep1a/console/rsPMCQ1.h, ep1a/include/bsp.h,
ep1a/irq/irq.c, ep1a/irq/irq_init.c, ep1a/pci/no_host_bridge.c,
ep1a/start/start.S, ep1a/startup/bspstart.c, ep1a/startup/linkcmds,
ep1a/vme/vmeconfig.c: New files.
