* scv64/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* sonic/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* tod/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* clock/clock.c: Removed warnings.
* startup/genpvec.c, tod/todcfg.c: Removed warnings.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* scv64/Makefile.am: Use .$(OBJEXT) instead of .o.
* sonic/Makefile.am: Use .$(OBJEXT) instead of .o.
* tod/Makefile.am: Use .$(OBJEXT) instead of .o.
* start/Makefile.am: Eliminate PGMS.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* startup/linkcmds: Per PR170, PR171, and PR172 add .eh_frame
* scv64/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sonic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tod/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: Remove RTEMS_ENABLE_NETWORKING.
* Makefile.am: Add @exceptions@ to SUBDIRS.
* configure.ac: Apply RTEMS_BSPOPTS_*(*) to merge-in settings from
make/custom/dmv177.cfg;
Rename PPC_USE_INSTRUCTION_CACHE to DMV177_USE_INSTRUCTION_CACHE,
Add RTEMS_PPC_EXCEPTIONS([old]).
* include/Makefile.am: include force-preinstall.am.
* startup/bspstart.c: Rename PPC_USE_INSTRUCTION_CACHE to
DMV177_USE_INSTRUCTION_CACHE.
* wrapup/Makefile.am: Apply @exceptions@.
* startup/linkcmds: Added _init and _fini.
* clock/clock.c, console/debugio.c, include/dmv170.h, startup/setvec.c,
startup/vmeintr.c: Fixed typo.
* configure.in: Remove.
* configure.in: Remove CONSOLE_USE_POLLED, HAS_RTC.
* configure.in: Add bspopts.h, AC_DEFINE CONSOLE_USE_INTERRUPTS,
* include/.cvsignore: Add bspopts.h*, stamp-h*, coverhd.h, tod.h.
* include/Makefile.am: Use *_HEADERS instead of *H_FILES, New
treatment of tod.h, coverhd.h.
* include/bsp.h: Add include bspopts.h.
* startup/genpvec.c: #include <chain.h> instead of "chain.h".
* clock/Makefile.am, console/Makefile.am, scv64/Makefile.am,
sonic/Makefile.am, start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, tod/Makefile.am, wrapup/Makefile.am: Include
compile.am
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
from score/cpu to libcpu because the determination of which to use is
based on RTEMS_CPU_MODEL. Thus it can not be determined based solely on
multilib information.
that contains:
* Removes MKLIB
handling)
converted to automake.
