* clock/ckinit.c, shmsupp/getcfg.c, shmsupp/lock.c,
startup/bspstart.c, timer/timer.c, timer/timerisr.c: Convert to
using c99 fixed size types.
shmsupp/Makefile.am, startup/Makefile.am, timer/Makefile.am,
wrapup/Makefile.am. Use automake compilation rules.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove.
* shmsupp/Makefile.am: Cosmetics.
* shmsupp/Makefile.am: Remove all-local: $(ARCH).
* clock/ckinit.c, console/console.c, include/bsp.h, shmsupp/addrconv.c,
shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c,
startup/bspclean.c, startup/bspstart.c, startup/linkcmds,
startup/main.c, startup/setvec.c, timer/timer.c, timer/timerisr.c:
URL for license changed.
shmsupp/Makefile.am: Reflect having moved automake.
* shmsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
* shmsupp/lock.c: Renamed delay() to rtems_bsp_delay().
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Include
compile.am
converted to automake.
that converts the no_cpu directory to automake.
Renamed file shmsupp/intr.c in some BSPs to shmsupp/cause_intr.c to
avoid conflict with rtems/src/intr.c (Classic API Interrupt Manager).
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
be resolved.
