path: root/c/src/lib/libbsp/mips (follow)
* 2001-05-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-2410-12/+38
| | | | | | | * configure.in: Add bspopts.h. * include/bsp.h: Include bspopts.h. * include/.cvsignore: Add bspopts.h*, coverhd.h, stamp-h*. * include/Makefile.am: Use *_HEADERS instead of *H_FILES.
* 2001-05-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-245-6/+22
* 2001-05-24 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2001-05-243-15/+96
| | | | | | * Assisted in design and debug by Joel Sherrill <joel@OARcorp.com>. * start/regs.S, start/start.S: Now works on Mongoose-V. Missed in previous patch.
* 2001-05-22 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2001-05-226-64/+142
| | | | | | | | | * Assisted in design and debug by Joel Sherrill <joel@OARcorp.com>. * clock/clockdrv.c, console/conscfg.c: Corrected. * include/bsp.h: Support for tm27 and addition of CPU_CLOCK_RATE. * startup/bspstart.c: Properly set initial status register and pending interrupts. * timer/timer.c: Works now.
* 2001-05-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-111-0/+4
| | | | * configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]).
* 2001-05-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-115-3/+11
* 2001-05-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-05-112-5/+31
| | | | | * tools/runtest: Add functionality to avoid letting simulator run too long.
* 2001-05-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-05-072-2/+26
| | | | | * console/conscfg.c: Added an entry for the second serial port.
* 2001-04-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-205-90/+73
| | | | | | | | | | | | | | | * include/bsp.h (Clear_tm27_intr): Stop the timer and disable the interrupt. This was not quite right before and we were getting uncontrolled interrupt nesting in tm27. * timer/timer.c (Timer_Initialize): Added an extra reset and changed the ITMR register so we will never get an interrupt. (Read_timer): Fixed so the timer actually stops before it is read. Before some times reported were outraguously high. * start/start.S: Major clean including using stack in linkcmds, deleting unused code, and zeroing the BSS using the linkcmds information. * startup/linkcmds: Put heap in lower memory than workspace and move _clear_end so both are zeroed.
* 2001-04-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-202-1/+6
| | | | | * clock/clockdrv.c: Account for the fact that ClockRate is in cycles not megahertz.
* 2001-04-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-164-129/+30
| | | | | * start/start.S, startup/bspstart.c, startup/linkcmds: Cleanup that was not merged from the simple non-RTEMS program.
* 2001-04-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-162-5/+19
| | | | | | * start/start.S, startup/bspstart.c, startup/linkcmds: Modifications made with Gregory Menke <gregory.menke@gsfc.nasa.gov> as he debugged this BSP using a logic analyzer.
* 2001-04-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-163-81/+130
* 2001-03-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-03-142-0/+12
| | | | * console/console.c: Added printk() support.
* 2001-03-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-03-147-10/+22
| | | | | * clock/clockdrv.c, console/conscfg.c, include/bsp.h, start/start.S, startup/bspstart.c, timer/timer.c: Comments corrected.
* 2001-02-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-03-1428-0/+1400
| | | | | | | | | | | | | | * The Generic Mongoose-V BSP uses only the peripherals found on the Synova Mongoose-V CPU. This is a radiation hardened CPU based on the LSI Logic 33K. * .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.in, clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c, console/.cvsignore, console/Makefile.am, console/conscfg.c, include/.cvsignore, include/Makefile.am, include/bsp.h, start/.cvsignore, start/Makefile.am, start/regs.S, start/start.S, startup/.cvsignore, startup/Makefile.am, startup/bspstart.c, startup/linkcmds, timer/.cvsignore, timer/Makefile.am, timer/timer.c, wrapup/.cvsignore, wrapup/Makefile.am: New files.
* 2001-01-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-123-13/+46
| | | | | | * include/bsp.h, timer/timer.c: Updated so timer appears to work and support tm27. I would prefer to time a software interrupt rather than an use an extra timer though.
* 2001-01-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-093-5/+13
| | | | | * clock/clockdrv.c: Clean up. * include/bsp.h: Uncomment and fix set_vector() prototype.
* 2001-01-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-083-6/+17
| | | | | * start/start.S: init_exc_vecs is now called mips_install_isr_entries. * wrapup/Makefile.am: Corrected to reflect new libcpu structure.
* 2001-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-032-2/+4
| | | | * console/console-io.c: Removed unused variable initialized.
* 2001-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-034-15/+22
| | | | | | * clock/Makefile.am: Fixed reference to ckinit.c. * clock/clockdrv.c: Enabled fast idle. * console/console-io.c: Added console_initialize_hardware().
* 2000-12-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-195-0/+118
| | | | | | * timer: New subdirectory. * timer/.cvsignore, timer/Makefile.am, timer/timer.c: New files. * tools/ChangeLog: New file.
* 2000-12-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-1913-20/+351
| | | | | | | | | | | | | | | * Makefile.am: Added tools subdirectory and removed commented out line. * configure.in: Added tools subdirectory. * tools: New subdirectory. * tools/.cvsignore, tools/Makefile.am, tools/configure.in, tools/runtest: New files -- based on powerpc/psim. * clock/clockdrv.c: Guessed new value for clock tick. Need to add fast idle support. * include/bsp.h: tm27 support initiated. * start/start.S: Fixed frame/endframe problems on _sys_exit. * startup/bspstart.c: Increased Workspace size to 4 MBYTES! * linkcmds: Increased Workspace size to 4 MBYTES! * Most tests appear to run correctly!
* 2000-12-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-137-4/+46
| | | | | | | | | | | | * README: Updated. We are now vectoring a clock tick ISR handler. But RTEMS is not returning from the ISR properly. * clock/clockdrv.c: Now causes interrupts but has not been calibrated. * include/bsp.h: Use <libcpu/tx3904.h> * startup/Makefile.am: Add setvec.c from shared. * startup/bspstart.c: Initialize the status register (SR) so no interrupts are masked but global interrupts (SR_IEC) are off. Added call to install the ISR prologue code. * wrapup/Makefile.am: Pick up more pieces from libcpu.
* 2000-12-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-112-0/+20
| | | | | * startup/bspclean.c: New file to explicitly invoke _sys_exit(). * README: Updated.
* 2000-12-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-063-19/+51
| | | | | * README: Updated to reflect status. * startup/linkcmds: Added .ctor and .dtor sections to no avail.
* 2000-11-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-304-11/+33
| | | | | | | * README: Updated to reflect current status. Misaligned reference during initialization may be compiler problem. * console/console-io.c: Added support for printk(). * startup/linkcmds: Reserve 512K for RTEMS Workspace.
* 2000-11-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-272-1/+7
| | | | | | * startup/linkcmds: Fix typo and add extra 0 to base address. Now runs until printf() tries to put a character and then it locks up checking a status bit that does not change.
* 2000-11-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-272-1/+5
| | | | * configure.in: Change mips64orion reference to mips.
* 2000-11-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-2525-0/+1170
| | | | | | | | | | | | | * The JMR BSP is for a Toshiba TX39 evaluation board but can also be used with the mips simulator in gdb. * .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.in, clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c, console/.cvsignore, console/Makefile.am, console/console-io.c, include/.cvsignore, include/Makefile.am, include/bsp.h, start/.cvsignore, start/Makefile.am, start/regs.S, start/start.S, startup/.cvsignore, startup/Makefile.am, startup/bspstart.c, startup/linkcmds, wrapup/.cvsignore, wrapup/Makefile.am: New files.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-094-2/+10
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-024-2/+10
* 2000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-012-4/+9
| | | | | | | * startup/bspstart.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. Header file order was cleaned up while doing this.
* 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-274-2/+12
* 2000-10-24 Alan Cudmore <alanc@linuxstart.com> andJoel Sherrill2000-10-245-24/+48
| | | | | | | | | | | | | | | | | | | Joel Sherrill <joel@OARcorp.com> * This is a major reworking of the mips64orion port to use gcc predefines as much as possible and a big push to multilib the mips port. The mips64orion port was copied/renamed to mips to be more like other GNU tools. Alan did most of the technical work of determining how to map old macro names used by the mips64orion port to standard compiler macro definitions. Joel did the merge with CVS magic to keep individual file history and did the BSP modifications. Details follow: * console/led.S: Switch from using <idtmon.h> to <asm.h>. * console/start.S: Switch from using <idtmon.h> to <asm.h>. Added define of PMON stacksize. * console/idtmem.S: Switch from using <idtmon.h> to <asm.h>. Also reworked conditionals to use gcc predefines. * console/idttlb.S: Ditto.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-056-0/+10
| | | | | * console/Makefile.am, liblnk/Makefile.am, start/Makefile.am, startup/Makefile.am, wrapup/Makefile.am: Include compile.am
* Adding ChangeLogs.Joel Sherrill2000-08-102-0/+6
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-1210-17/+26
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-138-0/+38
| | | | adds .cvsignore.
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-082-3/+4
* Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff fromJoel Sherrill2000-01-316-0/+201
| | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> that contain: * Modifications, (minor) corrections, cleanups to most existing Makefile.ams * Adds automake support to all remaining BSPs which have not yet been converted to automake. * Makefile.am for all remaining wrapup/Makefile.ams
* Patch rtems-rc-20000118-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-311-2/+0
| | | | | | | | | | | | | | that contains: * cleanups to configuration files * A reworked gccnewlib.spec.in: I have reformated it for enhanced readability and added more rtems-base packages. It now should be free of any installation conflicts (If there still remain some, they should be regarded as bugs). * A fix to the bin2boot RTEMS_BSP issue (make RTEMS_BSP="pc386 pc486" now works). * removes libbsp/bare/wrapup * Further cleanups
* Patch rtems-rc-20000104-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-102-0/+57
| | | | | | | | that converts the mips64orion directory to automake. Ralf's Note: This patch demonstrates another kind of supporting the new style of configuration, which avoids having to port all Makefile.ins to automake, but to keep using most old style Makefile.ins.
* Patch rtems-rc-20000104-6.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-102-0/+29
* Renaming all BSP specific startXXX directories to use the same name (start).Joel Sherrill1999-11-191-2/+2
* Updated copyright notice.Joel Sherrill1999-11-176-12/+6
* The files in libcpu should not be directly dependent on any BSP. InJoel Sherrill1999-11-041-0/+1
| | | | | | | | | | | particular, using bsp.h, or getting information from the BSP which should properly be obtained from RTEMS is forbidden. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. The changes primarily eliminated the need to include bsp.h and peeking at BSP_Configuration. The use of Cpu_table in each BSP needs to be eliminated.
* Corrected to reflect new way of doing mips constructors.Joel Sherrill1999-04-161-6/+47
* Fixed include file paths.Joel Sherrill1999-03-311-3/+3
* Fixed paths to include files so this will build.Joel Sherrill1999-03-315-12/+12
