* mips-stub.c: Removed warnings.
* start/start.S, startup/bspstart.c: Removed warnings.
* mips-stub.c: Debugged & tweaked the gdb command processing,
zbreak stuff, breakpoint and step code. Implemented 'T' command
support and debugged remote gdb support w/ the Mongoose bsp.
Added the memory segment support.
* memlimits.h: Disabled all contents in favor of memory sement
support. This file could probably go away.
* rtems-stub-glue.c (rtems_gdb_index_to_stub_id()): New routine.
rtems_gdb_stub_get_register_from_context(): Implemented MIPS version.
rtems_gdb_stub_get_offsets(): Implemented MIPS version.
* README: Updated.
* startup/gdb-support.c: Added calls into the mips-support gdb stub
for configuring the memory regions. Any bsp that wants to use the
gdbstub will need to do something similar.
* startup/Makefile.am: Added shared/gdbstub directory to include path.
* ChangeLog: Corrected previous entry.
* shared/gdbstub/README: Added text.
* shared/gdbstub/mips-stub.c: Modified isr install routine to
capture all exceptions.
* start/start.S: Added kseg1 test to enable cache flush code
* bsp_specs: Added -qnostartfile to disable including bsp's start.o
* startup/bspstart.c: Made clear_cache actually work, tweaked cpu
init to only turn on whats needed.
* startup/gdb-support.c: Added calls to uart 2 for gdb stub I/O and
a handy init function.
* Significant modifications including adding thread support, the 'X'
command, and reorganizing so that target CPU independent routines
could be reused.
* gdb_if.h: Added numerous prototypes.
* mips-stub.c: Added thread support as well as 'X' command.
Also noticed that the 'P' command was from the mips protocol.
* rtems-stub-glue.c: New file. This file contains all generic
support which should be able to be reused on another target CPU.
* startup/Makefile.am: Added rtems-stub-glue.c to C_FILES.
* mips-stub.c (handle_exception): Prototype changed to be an RTEMS
entry point. Added comments about possible need to flush cache.
(mips_gdb_stub_install): New routine.
* startup/Makefile.am: Now compile the gdb stub.
* startup/bspstart.c: Fixed header block.
* startup/gdb-support.c: New file in stub state.
* Makefile, stubinit.S, r46kstub.ld, ioaddr.h: Removed as unused
with RTEMS.
* r46kstub.c: Renamed to mips-stub.c.
* mips-stub.c: New file -- was r46kstub.c.
* memlimits.h: New file was limits.h.
* limits.h: Removed.
* r4600.h: Eliminated need for this file.
* README: Updated.
* gdb_if.h: Added CVS Id.
* mips-stub.c: Attempt to deal with MIPS1 versus MIPS3.
* Merged r46kstub.c into RTEMS distribution without modification.
I got the code from Franz Fischer <Franz.Fischer@franz-fischer.de>
who had used this with an old version of RTEMS with the mips64orion
port of RTEMS. After adding this to the repository, I will tailor
this to work with the RTEMS exception processing model and trim
no longer needed parts.
* ChangeLog, gdb_if.h, ioaddr.h, limits.h, Makefile, mips_opcode.h,
r4600.h, r46kstub.c, r46kstub.ld, README, stubinit.S:
* include/lr33000.h, include/lr330x0.h, include/r3000.h, start/mg5.h:
New files missed in previous commit.
* timer/timer.c: Use rtems/bspIo.h not just bspIo.h.
* Update of BSP to address problems restarting, provide more
information during boot, and better handle ROM vs RAM images.
* README, include/bsp.h, start/regs.S, start/start.S,
startup/bspstart.c, startup/linkcmds, timer/timer.c: Updated
* configure.ac: Remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* console/console-io.c: Include rtems/bspIo.h instead of bspIo.h.
* console/console.c: Include rtems/bspIo.h instead of bspIo.h.
* console/conscfg.c: Include rtems/bspIo.h instead of bspIo.h.
* timer/timer.c: Include rtems/bspIo.h instead of bspIo.h.
* configure.in: Remove.
* acinclude.m4: New file.
* start/start.S: Invoke boot_card() not main().
* Makefile.am: Use 'TMPINSTALL_FILES ='.
* include/.cvsignore: Add bspopts.h*, coverhd.h, stamp-h*.
* Assisted in design and debug by Joel Sherrill <joel@OARcorp.com>.
* start/regs.S, start/start.S: Now works on Mongoose-V. Missed
in previous patch.
* clock/clockdrv.c, console/conscfg.c: Corrected.
* include/bsp.h: Support for tm27 and addition of CPU_CLOCK_RATE.
* startup/bspstart.c: Properly set initial status register and
pending interrupts.
* timer/timer.c: Works now.
* tools/runtest: Add functionality to avoid letting simulator
run too long.
* console/conscfg.c: Added an entry for the second
serial port.
* include/bsp.h (Clear_tm27_intr): Stop the timer and disable
the interrupt. This was not quite right before and we were
getting uncontrolled interrupt nesting in tm27.
* timer/timer.c (Timer_Initialize): Added an extra reset and
changed the ITMR register so we will never get an interrupt.
(Read_timer): Fixed so the timer actually stops before it
is read. Before some times reported were outraguously high.
* start/start.S: Major clean including using stack in linkcmds,
deleting unused code, and zeroing the BSS using the linkcmds
information.
* startup/linkcmds: Put heap in lower memory than workspace
and move _clear_end so both are zeroed.
* clock/clockdrv.c: Account for the fact that ClockRate is
in cycles not megahertz.
* start/start.S, startup/bspstart.c, startup/linkcmds:
Cleanup that was not merged from the simple non-RTEMS program.
Modifications made with Gregory Menke <gregory.menke@gsfc.nasa.gov>
as he debugged this BSP using a logic analyzer.
* console/console.c: Added printk() support.
* clock/clockdrv.c, console/conscfg.c, include/bsp.h, start/start.S,
startup/bspstart.c, timer/timer.c: Comments corrected.
* The Generic Mongoose-V BSP uses only the peripherals found on
the Synova Mongoose-V CPU. This is a radiation hardened CPU
based on the LSI Logic 33K.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.in,
clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c,
console/.cvsignore, console/Makefile.am, console/conscfg.c,
start/.cvsignore, start/Makefile.am, start/regs.S, start/start.S,
startup/.cvsignore, startup/Makefile.am, startup/bspstart.c,
startup/linkcmds, timer/.cvsignore, timer/Makefile.am, timer/timer.c,
wrapup/.cvsignore, wrapup/Makefile.am: New files.
* include/bsp.h, timer/timer.c: Updated so timer appears to
work and support tm27. I would prefer to time a software
interrupt rather than an use an extra timer though.
* clock/clockdrv.c: Clean up.
* include/bsp.h: Uncomment and fix set_vector() prototype.
