* Makefile.am: Change to one file per line. Clean up.
* ChangeLog, Makefile.am: Add bsp_reset() stub.
PR 1917/bsps
* Makefile.am, console/conscfg.c: Modifications to add dynamic tables
for libchip serial drivers.
* Makefile.am: Fix broken path to clockdrv_shell.h.
* Makefile.am, configure.ac: runtest for this BSP obsoleted by
rtems-testing/sim-scripts support. Please use those scripts.
* configure.ac: Remove RTEMS_CANONICAL_TARGET_CPU.
* include/tm27.h:
* startup/bspstart.c, timer/timer.c:
* timer/timer.c: Include <rtems/btimer.h>.
* csb350/clock/clockdrv.c, csb350/network/network.c,
csb350/start/start.S, csb350/timer/timer.c,
genmongoosev/clock/clockdrv.c, genmongoosev/timer/timer.c,
jmr3904/timer/timer.c, jmr3904/tools/runtest.in: Fix typo where
license said found in found in.
* startup/bspstart.c: Add include to fix warning.
PR 1599/cpukit
* shared/irq/exception.S: Rename _Context_Switch_necessary to
_Thread_Dispatch_necessary to more properly reflect the intent.
* shared/irq/exception.S: Removed _ISR_Signals_to_thread_executing
declaration.
PR 1573/cpukit
* shared/irq/exception.S: Add a per cpu data structure which contains
the information required by RTEMS for each CPU core. This
encapsulates information such as thread executing, heir, idle and
dispatch needed.
* Makefile.am, preinstall.am: Fix typo.
* shared/liblnk/lnklib.S, shared/liblnk/pmon.S, shared/liblnk/regs.h,
shared/startup/idtmem.S, shared/startup/idttlb.S: New files.
* Makefile.am, preinstall.am: Many files were duplicated across MIPS
BSPs. Now those which were directly copied are shared.
* liblnk/lnklib.S, liblnk/pmon.S, liblnk/regs.h, startup/idtmem.S,
startup/idttlb.S: Removed.
* liblnk/lnklib.S, liblnk/pmon.S, liblnk/regs.h, startup/idtmem.S:
Removed.
* Makefile.am, preinstall.am, start/start.S: Many files were duplicated
across MIPS BSPs. Now those which were directly copied are shared.
* start/regs.h: Removed.
* startup/usc.S: New file.
* shared/irq/exception.S: rbtx4925, rbtx4938, and hurricane had very
similar versions of exception. Now all use shared/irq/exception.S
* configure.ac: rbtx4925, rbtx4938, and hurricane had very similar
* Makefile.am, configure.ac: rbtx4925, rbtx4938, and hurricane had very
* startup/exception.S: Removed.
* shared/irq/exception.S: New file.
* Makefile.am: rbtx4925 and rbtx4938 had copies of the same file with
only minor differences. Both now use shared/irq/exception.S
* startup/exception.S: Minor changes to make more similar to the shared
version.
* startup/linkcmds: Now links all tests.
* shared/gdbstub/mips-stub.c: Remove warnings.
* startup/linkcmds: Needed to be assigned to a memory region.
* startup/linkcmds: Revert previous change. Remove .reginfo from .bss
section where it was present.
* start/start.S, startup/linkcmds: Revert previous change. Remove
.reginfo from .bss section where it was present.
* startup/linkcmds: Add NOLOAD to .bss to eliminate warnings.
* bsp_specs: Remove extra } to eliminate warning.
* start/start.S: Verify boot_card is invoked properly with argc, argv.
* console/conscfg.c: Include <unistd.h>.
* network/network.c (au1x00_emac_ioctl): Use ioctl_command_t.
* clock/clockdrv.c: Split hardware initialization code into
Clock_driver_support_initialize_hardware().
promCopyIcacheFlush.
* include/bsp.h: Add prototypes of promCopyDcacheFlush and
* startup/bspstart.c: Remove nested externs.
#include <libcpu/isr_entries.h.
* make/custom/rbtx4938.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/rbtx4925.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/jmr3904.cfg: Remove RTEMS_BSP_FAMILY.
