* | 2006-06-23 Worth Burruss <worth@motioncontrol.org> | Joel Sherrill | 2006-06-23 | 7 | -38/+101 |
| | | | | | | | | | | | | | | | | * Makefile.am, README, startup/init5235.c, startup/linkcmds, startup/linkcmdsflash, startup/linkcmdsram: Modify to the mcf5235 eval boards to either load and run from ram using the dBug moniter as the boot deviced (Board setup as shipped from the factory), or it allows the user to Boot his code from flash he loads onto the eval board. The code changes between the two are based on the selected linker script using a variable in the script. The options to the linker are used to override the default linker script and select which options to configure at boot either from flash, or from ram: -qnolinkcmds -T linkcmdsflash If no options are given the standard linker sript assumes dBug was used to set up the board and the user is going to load his program to RAM. | ||||
* | Allow single spurious FPGA interrupt. | Eric Norum | 2006-05-15 | 2 | -3/+9 |
* | Improve handling of unexpected FPGA interrupt conditions. | Eric Norum | 2006-05-15 | 2 | -3/+23 |
* | Add default exception handler. | Eric Norum | 2006-04-11 | 2 | -1/+57 |
* | Add missing reset cause bit. | Eric Norum | 2006-03-24 | 2 | -0/+5 |
* | Remove eof include file | Ralf Corsepius | 2006-03-17 | 27 | -27/+0 |
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 6 | -6/+18 |
| | | | | * startup/linkcmds: Add sections required by newer gcc versions. | ||||
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 20 | -21/+61 |
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 3 | -4/+9 |
| | | | | | * startup/linkcmds, startup/linkcmds_ROM: Add sections required by newer gcc versions. | ||||
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 8 | -12/+22 |
| | | | | | * startup/linkcmds, startup/linkcmdsflash, startup/linkcmdsram: Add sections required by newer gcc versions. | ||||
| | | | | | * startup/linkcmds, startup/linkcmds.flash: Add sections required by newer gcc versions. | ||||
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 4 | -6/+11 |
| | | | | | * startup/linkcmds, startup/linkcmds.bootp, startup/linkcmds.prom: Add sections required by newer gcc versions. | ||||
* | Avoid possible division by zero. | Eric Norum | 2006-02-06 | 3 | -2/+8 |
* | Formatting. | Joel Sherrill | 2006-02-01 | 1 | -2/+2 |
* | Add code to maintain CPU load average. | Eric Norum | 2006-01-29 | 4 | -6/+51 |
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 18 | -18/+18 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 18 | -0/+72 |
* | Remove all-local:. | Ralf Corsepius | 2006-01-12 | 18 | -36/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 18 | -18/+18 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 18 | -18/+0 |
* | Remove leftovers of consolex. | Ralf Corsepius | 2006-01-11 | 1 | -2/+0 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 10 | -283/+30 |
| | | | | * Makefile.am: Add preinstall.am. | ||||
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 27 | -683/+82 |
* | New. | Ralf Corsepius | 2006-01-11 | 18 | -0/+1092 |
* | 2006-01-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-08 | 2 | -2/+6 |
| | | | | * network/network.c: Remove warnings. | ||||
* | Add another 'extended BSP' routine which returns reboot status register ↵ | Eric Norum | 2005-12-19 | 2 | -0/+42 |
| | | | | information | ||||
* | 2005-11-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-12 | 4 | -8/+8 |
| | | | | * bsp_specs: Remove %cpp. | ||||
* | 2005-11-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-12 | 3 | -7/+8 |
| | | | | | * bsp_specs: Remove %cpp. * console/console.c: Eliminate obsolete types. | ||||
* | Clean up UART2 pin setup. Protect pin setup code. | Eric Norum | 2005-11-11 | 3 | -2/+12 |
* | Add code to set up pin assignments. | Eric Norum | 2005-11-08 | 2 | -2/+21 |
* | Remove assignation to U.S. Government. | Eric Norum | 2005-11-07 | 2 | -2/+0 |
* | Assign copyright to OAR since all files descend from OAR's source. | Eric Norum | 2005-11-07 | 11 | -23/+81 |
* | Fixed formatting. | Joel Sherrill | 2005-11-07 | 1 | -3/+3 |
* | 2005-11-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-07 | 1 | -0/+6 |
| | | | | | | * console/console.c: Eliminate unsigned32, unsigned8. * include/bsp.h: Eliminate unsigned32. * startup/bspstart.c: Eliminate unsigned32. | ||||
* | Eliminate unsigned32. | Ralf Corsepius | 2005-11-07 | 4 | -10/+10 |
* | Eliminate unsigned32, unsigned8. | Ralf Corsepius | 2005-11-07 | 1 | -3/+3 |
| | | | | | | * include/bsp.h: Eliminate unsigned32. * network/network.c: Several minor bug fixes. * startup/bspstart.c: Eliminate unsigned32. | ||||
* | Several minor bug fixes. | Ralf Corsepius | 2005-11-07 | 1 | -1/+6 |
* | Allow network to be locked at 100/Full. | Eric Norum | 2005-10-26 | 3 | -4/+25 |
* | Remove. | Ralf Corsepius | 2005-10-17 | 3 | -94/+0 |
* | 2005-10-17 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-17 | 3 | -28/+94 |
| | | | | | | * Makefile.am: Merge-in shared/Makefile.am. * ChangeLog: Merge-in shared/ChangeLog. * configure.ac: Remove shared/Makefile.am. | ||||
* | Silently return to bootstrap PROM. | Eric Norum | 2005-09-19 | 1 | -1/+0 |
* | Correct my email address. | Ralf Corsepius | 2005-09-19 | 1 | -8/+8 |
* | 2005-09-19 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-09-19 | 1 | -0/+4 |
| | | | | * network/network.c: Include <errno.h> instead of <sys/errno.h>. | ||||
* | Include <errno.h> instead of <sys/errno.h>. | Ralf Corsepius | 2005-09-19 | 1 | -1/+1 |
* | Add bsp_reset bootrom call. | Eric Norum | 2005-09-16 | 4 | -8/+7 |
| | | | | Call bsp_reset from bsp_cleanup(). | ||||
* | New file. | Joel Sherrill | 2005-08-17 | 1 | -0/+9 |
* | 2005-08-17 Mike Bertosh <mbertosh@motioncontrol.org> | Joel Sherrill | 2005-08-17 | 2 | -0/+6 |
| | | | | * acinclude.m4: Add the av5282 BSP. | ||||
* | 2005-08-17 Mike Bertosh <mbertosh@motioncontrol.org> | Joel Sherrill | 2005-08-17 | 20 | -0/+3969 |
| | | | | | | | | | * .cvsignore, Makefile.am, README, bsp_specs, configure.ac, clock/clock.c, console/console.c, include/bsp.h, include/bspopts.h.in, include/coverhd.h, include/tm27.h, network/network.c, start/start.S, startup/bspclean.c, startup/bspstart.c, startup/init5282.c, startup/linkcmds, startup/linkcmdsflash, startup/linkcmdsram, timer/timer.c: New files. | ||||
* | Add .gnu.linkonce.b | Eric Norum | 2005-07-24 | 2 | -1/+5 |
